Old Oct 15, 2012, 09:19 PM
Daravon is offline
Find More Posts by Daravon
TRB
United States, TX, Richardson
Joined Oct 2005
SPAD parkflyer?
I used to fly a slow stick a lot back in college. I want to get back into RC, but I can't find a single shop that has any slow sticks in stock. Does anyone have any designs for SPADs that are 'floaty' enough to be flown in small areas like a park flyer?
Daravon is offline Find More Posts by Daravon
Old Oct 15, 2012, 10:31 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Just use the Blue Fan Fold foam. There are many threads on using it. FFF is lighter than coroplast and good for indoors too. It is still plastic to sneak into the SPAD rules. The brushless LiPo setup works great, and you can design your own plane and throw it out if it doesn't work, because it is so cheap.
aspeed is offline Find More Posts by aspeed
Old Oct 16, 2012, 06:36 AM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Lookup in the foamy categories here in the forum about the Blue Baby plane, it uses fan fold foam and is quite easy to build and it flies good too. Another good choice is the Nutball too.
earlwb is online now Find More Posts by earlwb
Old Oct 16, 2012, 08:12 AM
dedStik is online now
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I made one of these from the blue fan fold foam.
I've not flown it yet, but it doesn't get much simpler than that.
dedStik is online now Find More Posts by dedStik
Old Oct 16, 2012, 09:41 AM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Russ' Trainer Type Plane: http://www.rcgroups.com/forums/showthread.php?t=1281056
Easy to build and a great little floater.
JohnsPop is offline Find More Posts by JohnsPop
Old Oct 16, 2012, 12:57 PM
Daravon is offline
TRB
Joined Oct 2005
Thanks everyone. The ESP3D looks really easy and cheap but I'm not confident of my skills anymore! I sure wish I had kept my slow stick motor and mount.
Old Oct 21, 2012, 10:01 AM
MrClean is offline
Find More Posts by MrClean
Somewhere near Parkville, Mo.
Joined May 2004
Espad is a simple build and not that hard to get back into flying. AMain hobbies lists the Ember at 80 bucks.
I was flying way after dark with my Night Vapor which you can buy from any Hobbytown and buy support parts and extra batteries there as well.
Both of these airplanes are little to know breeze flyers and would work at inside flying events. With no breeze though they are a lot of fun. I was flying around, over and through my grand-daughters swingset. The Vapor I linked is RTF, it has it's own transmitter in the box. This is spend money and fly not build. I'm trying to remember but for right around 100 bucks you can buy a quadcopter. That's also low to no wind flying but it's quad flying not the more relaxing, conventional plane (non 3D) flying.
If you're not trying to fly in your backyard and actually have some space, go with either the SnoBall which is easy 3 channel control or the Nutbar (www.flitetest.com) both are about the same layout, the Nutbar has a swapable fuse so you can move power/receiver around to a more capable airframe. Those are made from Dollar tree foam board as well WHICH costs a dollar a sheet and is in their yardsale department.
Like many things, your question isn't answerable with only an option. It's trying to pick which one of the many options YOU like the best.
And don't worry about your flying/building skills. That stuff will come right back to you and will do so even faster when you're not worried about the cost of the airplane due to them being cheap, easy to replace/fix units. You'll be landing inverted in no time.
A little while after that, you'll probably even be able to do it on purpose!
MrClean is offline Find More Posts by MrClean
Old Apr 24, 2013, 01:24 PM
isvana is offline
Find More Posts by isvana
Random Flier
Oxford (UK) and Mtn View CA (USA)
Joined Nov 2002
semiSPAD
I guess I have a SPAD parkflyer - in that the wing is thin corrugated plastic. Its got a foam fuselage though - its basically a GWS EasyBug with the thin foam wing (RIP) replaced by the plastic one (+ some CF support rods). Sp400 geared motor for 3S LiPo power. Removable tail fin. Great suitcase plane!
isvana is offline Find More Posts by isvana
Article ElectriFly Spad XIII WWI Parkflyer ARF Review Michael Heer Scale ARF/RTF 172 Aug 23, 2015 08:56 AM
Help! Spad parts msgt81 Parkflyers 6 Feb 13, 2013 09:33 PM
Discussion NERF Bat SPAD - First SPAD tlr-boise SPAD - Simple Plastic Airplane Designs 35 Jun 06, 2011 09:52 AM
