Old Oct 15, 2012, 10:41 AM
skatun is offline
Find More Posts by skatun
Joined May 2008
CNC Mould
Hi
I am building a large scale glider, wingspan 10m. I am currently putting up up a cnc mill with 6m length and 1.5m width.
The problem is how can i make realtively cheap good mould for the fuselage and wings.
So here is 2 options i have considered:
1 Mill it out of styrofoam with 3mm to deep cuts, then add 2*160g glasfiber, then gelcoat, and then remill to accurate depth and then polish
2 Mill it out of POM directly to correct depth and then polish it
3: Other options
Regards Kim
skatun is offline Find More Posts by skatun
Old Oct 15, 2012, 08:49 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Corian/LG Himac etc.
samc99us is offline Find More Posts by samc99us
Old Oct 15, 2012, 09:13 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
How many parts are you expecting to produce from the molds?
wyowindworks is offline Find More Posts by wyowindworks
Old Oct 18, 2012, 06:12 AM
LOONY BOY is offline
Find More Posts by LOONY BOY
Canberra
Joined Nov 2003
I'm just getting into RC mold making.
How would 6061 aluminum go?
Main problem would be warping whilst machining.
Price is quite reasonable.
Just checked out the Corian, very interesting have never heard of it.
LOONY BOY is offline Find More Posts by LOONY BOY
Old Oct 18, 2012, 06:31 AM
skatun is offline
Joined May 2008
Hi
We want to make at least 10models.
Can you just polish corian and then laminate in it?
Kim
Old Oct 28, 2012, 01:07 PM
1900 Driver is offline
Find More Posts by 1900 Driver
1900 Driver's Avatar
United States, CA, Santa Barbara
Joined Mar 2009
6061 would make some amazing moulds I would think! And they can produce a lot of parts. I do know they are easily scratched and tough to repair.
1900 Driver is offline Find More Posts by 1900 Driver
Old Oct 28, 2012, 02:03 PM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
For aluminum, cast tooling plate is really nice.
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Oct 31, 2012, 11:38 AM
orrinade is offline
Find More Posts by orrinade
Joined Nov 2010
Corian
Corian is my choice but take good care of them as they are brittle and do brake.
It can be machined fast and is very easy to polish, especially if you do small step over.
Take a look at a finished cnc'd part, a sanded part and a polished part in the pics.
One thing to note is to build yourself clamps to evenly distribute the load.
Square tubing is perfect.
Regards
Orrin
orrinade is offline Find More Posts by orrinade
Old Nov 01, 2012, 06:42 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Say I wanted to build a cnc mould, and wanted to get someone to turn my sketches into a cad design, then pay a machinist to make my moulds from corian- where is most of the cost, the cad design or the machining? Id love to do this one day.
josh18 is offline Find More Posts by josh18
Old Nov 02, 2012, 05:16 AM
sunnybreeze is offline
Find More Posts by sunnybreeze
Joined Oct 2010
Josh,
That's a hard question to answer. It all depends on the detail of the CAD work. The average CAD design is $40.us per hour. A simple design can be 1-2 hours. As far as mold making I charge $1.00us per minute run time. Again depending on the size of the mold you can get hundreds of dollars into a mold fast.
Hope this helps
Steve in Maine.
sunnybreeze is offline Find More Posts by sunnybreeze
Old Nov 03, 2012, 02:53 PM
bgriggs is offline
Find More Posts by bgriggs
Make something. Anything!
bgriggs's Avatar
Syracuse Hancock, New York, United States
Joined Jul 2003
Regards
Orrin
Could you tell me more about the preparation of the corian molds. How are you sanding and polishing them after finish machining?
I'm very interested I have a CNC and some corian.
Bill
bgriggs is offline Find More Posts by bgriggs
Old Nov 05, 2012, 03:21 AM
orrinade is offline
Joined Nov 2010
Bill here is the first part,
I'll add the next step for the sanding and polishing.
Part 1 - Preparation of corian before machining.
Hi,
First step is to check that the corian is the correct thickness and and has extra material for structural support.
It would be a good idea to mount it to a non-warping surface to give rigidity.
I would then place the piece that is slightly oversize onto the sacrificial board.
I have a sacrificial board at the bottom fastened to the surface bedof the cnc table.
I will sometimes mill two sides that are perfectly aligned to the zero of the cnc program.
This allows me to consistently machine the same place if I have need to.
You can make holes to take metal dowel pins that are used to align to your surface and them pull them out when the corian is mounted.
This gives me very little to no-error if I have to re-machine an area.
I would have programmed 6 holes that are used to hold the work peace down.
I drill 3mm holes for the screws that I use and then a countersunk hole approximately 7mm in diameter so that the screws are well under the maximum depth of the machine cut to be used.
After all this has been done I will fasten the corian work peace down.
I will then set my z-zero using a piece of paper under the front of the bit just touching the paper.
In other words it must hold the paper but not be all the way through. This will give you a very small space which can be measured with a vernier caliper, or you could start the spindle and move it very slow until you notice cutting.
Zero the z-axis.
Take the z-zero up to 10mm and re-zero, now do a dry run to ensure the tool path is doing what you intended.
If you are happy take down by 10mm and re-zero, now you should be able to run the program and not have any surprises.
This is the only setup that I use and is not necessary everyone’s choice.
Part 2 to come.
Old Nov 05, 2012, 05:28 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Josh,
I tell people to estimate a thousand dollars plus materials and you'll probably be safe. You can probably get it done cheaper, and some will charge more.
Usable molds aren't always easy to make the first try though. I'm on my fourth or fifth set now and they get better every time... that's with me doing CAD, me doing CAM, and me doing machining through part manufacture. If you're having others do pieces and parts of the work, expect that some things will have to be reworked along the way.
tom43004 is offline Find More Posts by tom43004
Old Nov 05, 2012, 07:19 PM
bgriggs is offline
bgriggs's Avatar
Joined Jul 2003
Thanks for the detail on the setup. I am familiar with the process you described but others may not be. What I was wondering about was the steps you went through after you had done your finish toolpath.
Please feel free to continue with part 2 as planned. I find I learn something from everyone. For instance your sacrificial board idea.
Bill
Old Nov 12, 2012, 09:00 AM
Seppos is offline
Find More Posts by Seppos
Australia, QLD, Brisbane
Joined Nov 2011
Nice description of the process! - also looking forward to part 2
Just about to embark on some corian routing for some glider moulds - never worked with corian before.. How are you finding tool life? - is HSS enough or would you recommend carbide?
Haven't run across feed/speed info yet - if you have any recommendations, that would be great!...
Also, any pointers on toolpath generation with the amount of overlap/pass/finishing cutter size to get a nice result for sanding/polishing ?
Thanks in advance!
Seppos is offline Find More Posts by Seppos
Discussion Using fibregrass moulds to mould depron midrian Scratchbuilt EDFs 7 Dec 12, 2010 05:10 AM
Discussion Making CNC Wing Mould Questions 1Freak Composites Fabrication 7 Feb 16, 2007 12:52 AM
Idea Hollow moulded wings ,but without a mould avago Composites Fabrication 15 Oct 28, 2006 06:52 AM
