Old Oct 15, 2012, 09:57 AM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Avonds Rafale or Grumania Eurofighter for 110 fan
I have been looking at both of these planes for my next project. I'm trying to stay around 15 pounds or lighter. EDF unit will be a Stumax 110-52 (1915 - 1.5Y) I got in a trade with a CC 110 HV ESC. The rest of the gear will be as light as possible (wire landing gear (dressed as struts), electric retracts, Zippy Compact 5800 12S batteries). I was wondering between the 2 planes which has the better flying characteristics, etc.
Paint scheme on the Eurofighter will be the Swiss Red/White that CARF has in their Eurosport Evolution. The Rafale will be in the White/Blue Avonds paint scheme.
Gamalier is offline Find More Posts by Gamalier
Old Oct 15, 2012, 01:27 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Have you seen this:
Avonds Rafale, schubeler 94HST on 12s (4 min 32 sec)
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Oct 15, 2012, 02:46 PM
Gamalier is offline
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Yes I did.
Old Oct 15, 2012, 03:34 PM
felix72 is offline
Find More Posts by felix72
Jets fly goooood!
felix72's Avatar
Italy, Lazio, Ariccia
Joined May 2004
I vote for the Grumania Eurofighter.
My opinion is that on the Eurofighter you will have a lower wing loading in general, so...less restriction on weight, but if you go heavier on the Rafale you will see the difference more.
I don't know the exact dimension of the Eurofighter compared to the Rafale but if you want to see an Eurofighter look here:
http://www.cmodels.it/modelli_jet/edf%20ef2000.htm
you can also find some video with different fan configuration (2x90, 110, etc...)
Gianluca
felix72 is offline Find More Posts by felix72
Old Oct 15, 2012, 03:53 PM
Gamalier is offline
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
The Eurosport has 48" WS x 62" Long ( 1220 mm x 1550 mm ) and finished weight is around 15.4 pounds ( 7000grams ). The Rafale has 50 " WS x 70" long ( 1260 mm x 1780 mm ) and the finished weight is around 16 pounds also. I guess this will be a matter of flying characteristics and looks be because both planes are pretty much identical in weight and measurements. The Rafale is a bigger plane and that is now tilting the scale a bit. I'm waiting in the quote for the Eurosport and I will have a decision.
Old Oct 15, 2012, 06:03 PM
bidule is online now
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
I just received the Grumania 1/10 Eurofighterhttp://www.grumania.com/xtcommerce/Jet-model-kits/1/10-Eurofighter:::2_9.html .Very nice fibre glass layup . No ducts intake are provided with this jet. I order the Schubeler HST 77 and some nice former xtra to be able to remove the wings .
The service from Ilja is top notch.
I will start building the jet in the winter. It's NOT an ARF
bidule is online now Find More Posts by bidule
Old Oct 15, 2012, 10:52 PM
felix72 is offline
Jets fly goooood!
felix72's Avatar
Joined May 2004
Yes...but I think that the Eurosport has a larger wing area thus a lower wing load
Gianluca
Old Oct 17, 2012, 02:00 PM
Gamalier is offline
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
I decided on the Eurosport. The Avonds Rafale empty fuselage is 3.5kg and given the fact that the Stumax 110-52 is not one of the most powerful fans out there I will like to assemble the lightest plane. The way I assemble them is either 1:1 power/thrust ratio or even higher. I have a 21 pound plane with a 25 pounds of thrust fan. That way I can take off from grass with no problem and cruise at 1/2 - 3/4 power and take dives at full power just for fun!!
Once I get the plane and some time off from work I will start and do a build thread.
Discussion rafale phillip avonds EDF 120mm converted gianni sanchez Large EDF Jets 35 Mar 22, 2014 04:56 PM
Discussion Avonds Rafale jacojet Electric Ducted Fan Jet Talk 41 May 12, 2012 07:27 AM
For Sale Grumania EUROFIGHTER and Wren44 100%NEW bmaaa Aircraft - Fuel - Jets (FS/W) 11 Aug 18, 2007 12:18 PM
Wanted Rafale Ducted Fan Avonds agustin Aircraft - Fuel - Jets (FS/W) 3 Apr 27, 2007 07:18 PM
