Canada, ON, Cottam
Joined Jan 2012
I forgot about the arming thing. We used servos on the cars, and pushing the trigger would push on an actual brake with the nitro ones. The rheostat would give brake, and the ESC would give brake too. I guess the planes are different. The cars are too.
Launch Ramp
This is totally an experiment. It is a launch ramp made of foam rollers. The foam is from a floaty noodle for the swimming pool. It has a 3/4" hole in the middle. The foam is super light and spins freely on 1/2" water pipe. I did a little test by goosing the throttle while still holding onto the top of the fuselage and let the airplane accelerate along the ramp. I only goosed about 1/4 throttle. It will go!! It has better than 1:1 thrust to weight and will literally jump vertically out of my hand. I have good confidence it will launch from this ramp.
Just a few more things and I'll be ready to box it up for shipping to Dad in Pennsylvania. Nothing is glued together yet so the airplane and the ramp can still fit in the box for shipping, that's why I am still using some blue tape here and there, which will go away of course. Also, I have the ailerons locked down with dummy pushrods. They still have an adjustable clevis, so it's easy to get them aligned neutral. I will wait to see how it flies before making them into flaps and coupled with the elevator. I'm thinking it won't be needed since the tail moment arm is so short. Derek
Leadout guides and handle
I am soooo close.
I got the leadout guide done. I wanted to make it as lightweight as possible and still have some adjustability, since I have no idea how much sweep will be needed. It's just a guess at this point. I will glue 2 short pieces of teflon tube into the "chosen" holes for maiden. I made it pseudo adjustable as in, try it and fly it. Then cut the leadouts and re-tie then into another set of holes. The centerline of the leadouts can sweep anywhere from 1/2" to about 3" behind the bellcrank. The bellcrank itself is 3/4" behind the CG. The fat ruler in the photo is 2" wide and the front edge is aligned with the center of the bellcrank. The bellcrank is just sitting on the wing for photo purposes - it resides inside the fuselage as shown before. The "handle" or whatever it might be called, is done on the transmitter. I did a 25 lb pull test, no problemo - can go lots more. The airplane all up weight is 2 lbs. Derek
Joined Jul 2012
Joined Jul 2012
Easy? It is quite difficult, on several levels. It is all done "close in" with little (or no) time to react to an adverse situation. Fast reflexes, the ability to instantly make a snap judgement as to what to do and carry it out (usually without thinking about it) and a "stick to it" attitude are among the parameters for success here. |
) that I have this Hawk balanced and trimmed good enough that I can just hold her straight and level for the first few battery packs.We shall see!! It will all be on video .Quote:
So my thought was, every bit of extra weight I add to the leadout guide, I have to compensate with same weight on the outboard wingtip. In the end, once I figure out the best location for the guides, I will probably cut off my guide and just install 2 small tubes. Anyway, that's my line of thinking. I'm all open for ideas. Derek |
Joined Jul 2012
"Here's my line of thinking. For an adjustable leadout guide, I had a few considerations. First, I have never seen one, so I don't know what others are doing. Second, anything I thought of myself that's truly adjustable would weigh more than what I came up with. Mine is still "adjustable" in a sense, just not in real time. I want to keep weight to an absolute minimum, so I look at every item. I have learned on my other electric R/C airplanes, if I pay attention to saving weight on every single component, it really adds up. I have other airplanes around this size on RC, and one in particular is 20% heavier than the other (say 2.4 lbs compared to 2.0 lbs). The performance of the 2.0 lb airplane is superior.
So my thought was, every bit of extra weight I add to the leadout guide, I have to compensate with same weight on the outboard wingtip. In the end, once I figure out the best location for the guides, I will probably cut off my guide and just install 2 small tubes. Anyway, that's my line of thinking. I'm all open for ideas". They are pretty simple- light too. A basic design is a "traveling block" that holds both leadouts and slides back and forth in a slot in the leadout guide. A binding screw is used to fix the block in the desired position. You can buy them ready made from various C/L suppliers, I think Brodak has them in their catalog. Here's one: http://brodak.com/control-line-parts...-up-psp-3.html |
All boxed up and on it's way to PA!
I did a few final things this morning and packed it all back in the original box, including the new transmitter. That box made it all the way from China to Florida, so just one more leg of the journey to Pennsylvania. I put the launch ramp parts in a 2nd box.
When the airplane arrives in PA, the only thing to do is glue on the 2 stabs, the rudder and the nosecone. I'm flying up to PA on Wed., Oct 31 and arrive at 10:48 am. There is a good chance, weather permitting, to get a flight in that afternoon. I return home on Monday Nov 5th. So we get about 4-1/2 days and hope the weather is good. The sad news is I won't have anything new to post until then .I will be taking a tiny video "wing cam" to mount on the airplane, along with 2 ground video cameras and a helmet video cam . I'll also have my laptop, so the intention is to post videos each night onto Youtube and link them here. That's the plan anyway.Derek
I see another one here. The disadvantage I have is very little C/L flying experience. So I probably don't appreciate how important this device can be. Brodak's description says: "Adjustable leadouts are an inexpensive way to dramatically improve the performance and handling of your airplane. Nearly every airplane must be trimmed out for flying and to improve performance. In addition, adjustable leadouts enable you to adjust to varying flying conditions, resulting in better overall handling and response. Brodak control-line airplane kits include detailed step-by-step instructions on how to install adjustable leadouts during the construction process." At least I will be able to do it manually. Can you describe what I should be looking for during flight to know which way, if any, the guides should be adjusted? How do I know when it's right? What is a good safe "starting point"? Also, is there a good way to do a pre-flight check for guide location, like hang the airplane from the lines and see how much the nose angles downward. What should I look for? Also, Brodak says "adjust to varying flying conditions". I just presumed there was one "right" position for a given airplane (other than carrier). I presume they mainly refer to wind (what else varies?). How would you set the guides for calm versus windy? I would guess you move the guides back during higher wind to get more outward pull? To me, this is the biggest unknown regarding setup. Derek |
United States, GA, Roswell
Joined Mar 2008
I would like to sugest to install the landing gear. Jets do not have the thrust to get you out of trouble. You need to build up speed to get the bird in the air and that ramp to me is way too short to get the job done.
Put the gear on let it stay on the ground and build up speed and slowly give up elevator and slip it off the ground. Take your time. And see if you can do it on a paved runway. |
Joined Jul 2012
A very simple adjustable line guide is to make the series of holes as you did, with brass thimbles over the lines a press fit in them. A slot just big enough to allow the lines to pass is cut down the centerline of the series of holes. To change the line rake, you just press the thimbles out and move the lines to whichever new set of holes you want to use, and press the thimbles back into that set of holes. It is an OLD system. |
| Thread Tools | |
| Sold BAE HAWK (Fiberglass Version) 90mm EDF Plug N Play 49" wingspan!!! Retracts!!! (RTF) | kclements | Aircraft - Electric - Jets (FS/W) | 21 | Sep 03, 2012 10:26 PM |
| Discussion Bae System Hawk 1.55m for 90-100 EDF | kin | Electric Ducted Fan Jet Talk | 8 | Jun 24, 2012 12:28 AM |
| Question Jet Legend BAE Hawk Turbine->EDF Conversion? | neversommer | Electric Ducted Fan Jet Talk | 4 | Apr 21, 2012 09:52 PM |
