This thread is privately moderated by Nightstone, who may elect to delete unwanted replies.
Old Oct 15, 2012, 01:21 AM
Nightstone is offline
Find More Posts by Nightstone
20 years on the Internet
Nightstone's Avatar
United States, AZ, Phoenix
Joined May 2012
Spektrum Brownouts
I have been having disconnect issues since the beginning of my journey into this sport. I have totaled 2 planes due to this and damaged a few others. I have not posted about this issue in any thread do to all the controversy surrounding it. Anything from its a myth to user error to 2.4ghz sucks etc.
Every time its happened I have tested every aspect of the plane fully afterwards. ESC, Motor, Receiver, Batteries, Connections. Everything always checks out okay. I have even went as far as load testing batteries. Nothing ever shown up as bad.
After my own experiences I finally came to the conclusion that folks in the brownout threads may have a point about voltage drops, ESC and reboots. To that end I went and put an order in for 10 Turnigy Becs. The 2 I already have were transferred over to 2 test planes that I will be flying for the next 2 weeks or more if needed to see if I Brownout.
I will post my results here as well as a video of my wing tester plummeting to the ground and then pulling up about a foot or so from the ground. I also have a video of my mini F-22 plummeting from the sky. I did get control back on that one but it was too late and I totaled the plane.
Nightstone
Nightstone is offline Find More Posts by Nightstone
Old Oct 15, 2012, 07:53 AM
seojeff is offline
Find More Posts by seojeff
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
BEC is the answer, I put one in every plane now and I never have brownouts anymore.
seojeff is offline Find More Posts by seojeff
Old Oct 16, 2012, 01:54 AM
Nightstone's Avatar
Joined May 2012
I really really ( Did I mention really ) hope so. This is one issue that needs to go for good. Will keep this thread updated on how it goes.
Thanks for the post.
Nightstone
Old Oct 16, 2012, 01:58 AM
Nightstone's Avatar
Joined May 2012
Brownout log
Will update this as to how the brown out issue is going. I am using Becs on 2 planes and cycling the same batteries through both. First flight I generally take it easy to get my bearings. Second flight is usually all out.
10/15/12 4 flights today. 2 on each plane. No brownouts. Planes seemed to run smoother than ussual ( may be in my head ).
10/16/12 4 flights today. No issues. Smooth as can be. I'm getting better at landing a faster heavier plane in turbulent winds ( No bent landing gear for a while now ).
10/17/12 4 Flights again today. Everything is going fine. No disconnects.
10/18/12 2 Flights today. No issues. Not feeling well.
10/19/12 4 Flights today. No issues.
10/20/12 2 flights today. 1 LOSS OF BROWNOUT/MOTOR . 2nd flight of the day. Running on 3 servos Rud/Ele/Ail. First time I have run this plane on 3 servos. Browned out on the motor about 4 or so minutes into the flight. Knew it immediately ( Loss in altitude ). Lasted 4-5 secs and then motor restarted. Reciever Light was blinking upon landing. Battery was at 6.79. These are new Turnigy nano techs. Had control the whole time it happened. A week ago this would have been a crash when you factor in how low I was ( I would not have had the altitude to recover ). The external Bec has paid for itself. I'm a believer. I have a vid if anyone is interested.
10/21/12 1 Flight today. Kinda short. Really rough 10mph plus winds. Bad landing ( Got a down gust just before touching down ).
10/22/12 2 Long flights today ( Used the big batteries ) No issues.
10/23/12 3 Flights today - No brownouts
10/24/12 2 flights today - Real windy where i'm at so was a bit limited. No issues.
10/26/12 2 flights today - No brownouts. First 2 flights on my DX8
10/27/12 Brownouts seem to be gone. Will report any here that occur. That's it for now.
Will continue testing and recording.
Nightstone
Old Oct 16, 2012, 08:45 AM
seojeff is offline
seojeff's Avatar
Joined Aug 2011
I had at least 3 crashes due to brownouts before finally realized that's what I needed to do. You can tell, if you're using OrangeRX, by the light on the rx when you land if you had a brownout. Those cheap BECs work fine for me eliminating those. I've yet to have one fail.
Nightstone
Old Oct 16, 2012, 10:55 PM
Nightstone's Avatar
Joined May 2012
Thanks for the flashing light info. I did not know that was what it indicated. I have both Orange RX and 3 spectrum receivers. Will keep an eye out for flashing on landing.
I also read that you should always power off the radio between battery's. I'm going to start doing that too...
On the bec side I have 2 HK's and 10 Turnigy's on the way. Hopefully that will fully cure the issue.
Nightstone
Old Oct 17, 2012, 07:48 AM
seojeff is offline
seojeff's Avatar
Joined Aug 2011
It's not the same for every receiver but I know for the 6ch OrangeRx the light flashes in normal mode so if you land and the light is solid then you had a brownout during that flight.
Nightstone
Old Oct 17, 2012, 10:44 AM
SCVJeff is online now
Find More Posts by SCVJeff
Joined Mar 2009
Are you sure it's just brownout and not loss of link that MAY indicate brownout, but also a few other things that might force a Rx reset?
SCVJeff is online now Find More Posts by SCVJeff
Old Oct 17, 2012, 12:29 PM
seojeff is offline
seojeff's Avatar
Joined Aug 2011
Honestly, I'm not 100% sure and there is no official manual for that RX.
Old Oct 17, 2012, 04:51 PM
Nightstone's Avatar
Joined May 2012
Testing it
From my own testing last night... Turn receiver on. Plug battery in. Orange RX = solid red. With Receiver still on switch battery and Orange RX will blink but controls still active. So the blinking is caused by a disconnect. What kind of a disconnect is anyone's guess ( Esc, battery, signal loss, Etc ).
Nightstone
Old Oct 17, 2012, 05:40 PM
Nightstone's Avatar
Joined May 2012
My research on this issue and my current understanding...
1.) Anything electronic with posted stats can be wrong, misrepresented by the vendor, faulty etc.
2.) A 2A linear bec ( Or one at any rating ) may not be able to function at stated amperage and may in fact be operating at considerably lower max amperage. These are the becs that are included with the cheap ESC's we buy.
3.) A cheap esc is just that. Its cheap and may or may not work as advertised at advertised amperage. See my video where a 30A esc catches fire at 20A or so amps.
4.) Servo amperage draw is variable depending on the plane, flight conditions, load, quality, etc.
5.) Batteries may or may not work as advertised. Damaged, worn out, faulty, Manufacturer misrepresented batteries may have nasty voltage/amperage drops.
So here I am a small foamy home builder. I build a plane like my DSE. It has really huge elevons. Plane has 2 servos, Esc with a 2a bec and a reciever. Battery is a 3s. Small foamy motor.
Its a nice windy day and off I go to fly. 3/4 through the flight I get a disconnect. plane goes down and i'm left scratching my head.
So what went wrong. The huge elevons are putting alot of stress on the servos raising amperage demands to the bec. add to that a windy day and more stress on the elevons. I'm now drawing more amperage out of those 2 servos than I would on a normal tame plane. I am now exceeding the amperage the bec can handle. Things are starting to heat up. Because its windy i'm running my motor alot harder pulling more amperage. Esc heats up. Bec heats up. Poof = we have a disconnect. Plane goes down.
As a foamy builder's we often build planes that really push the electronics, motor and servos. Often its not scientific ( That looks cool lets try it ). Control surfaces are often much bigger than needed ( Bigger is always better right? ). The list goes on... The end result for me is that I am pushing things and the end result is disconnects.
Anyways... This is my understanding of whats going on. We will see what happens here over the next few weeks.
Nightstone
Discussion Spektrum 6100 Brownout with video! Mcdyvie Power Systems 20 Sep 20, 2009 09:01 AM
Question Possible Spektrum brownout/reboot? ajreynolds Radios 15 Aug 16, 2008 10:11 AM
Help! Spektrum 6100E Brownout and capacitors mjljr Electric Plane Talk 24 Jun 02, 2008 12:48 AM
Cool Look what Toddsmodels.com is selling now. Spektrum v1.6 6100's. Brownout fix! cryhavoc38 Radios 461 Apr 21, 2008 12:22 PM
Question Spektrum AR 6100 v1.6 - Brownout fix Jurgen Heilig Radios 31 Mar 09, 2008 07:43 PM
