Dec 05, 2003, 10:50 PM
Toronto Canada
Joined Dec 2002
There is an article in the February 1982 issue of Model Airplane News by Andy Lennon in which he plots the lift/drag ratios of various airfoils, including a flat plate, curved plate and semi-symmetrical.
It turns out that at low Reynold's numbers (<40,000), curved plates are best, followed by flat plates and finally semi-symmetrical.
At higher Reynold's numbers (>120,000), the lift/drag ratio of the semi-symmetrical has significantly improved, while the curved plate and flat plate remain roughly the same as they were at 40,000.
The formula for Reynold's number at sea level is
Speed(mph) X Chord(in) X 780
At low speeds curved plate and flat plate are best.
At higher speeds the semi-symmetrical is best.
The key factor in the curved and flat plates, however, is the fact that they are linear and their performance does not change with speed.
A semi-symmetrical airfoil can give a nasty surprise when coming in for landing because the lift that it provides decreases not only because of the decrease in speed, but because of the decrease in performance at low speeds.
This helps explain the terrific performance of all the IFO's, Sukalyns and 3dExtras.
