Old Oct 14, 2012, 07:57 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Question
What do you do with a new brushless motor before you use it for the first time?
What do you typically do and check when you receive a new “inexpensive” brushless motor prior to use? A little light oil on the bearings, make sure it spins freely, solder or re-solder the wires? Would you do anything else prior to spooling it up for the first time?
Kcal is offline Find More Posts by Kcal
Old Oct 14, 2012, 08:00 PM
jmolwitz is offline
Find More Posts by jmolwitz
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
It should be good to go , no break in necessary . Just a quick test to see if it's turning in the right direction .
jmolwitz is offline Find More Posts by jmolwitz
Old Oct 15, 2012, 01:23 AM
fissio is offline
Find More Posts by fissio
Suomi, HKI
Joined Oct 2011
Do these small motors use vaseline or some grease for lubricating? incase they do, wouldnt that oil flush/melt the grease out of the bearing?
fissio is offline Find More Posts by fissio
Old Oct 15, 2012, 01:47 AM
Gimpdiggity is offline
Find More Posts by Gimpdiggity
Valiant Poultry
Gimpdiggity's Avatar
United States, MI, Jackson
Joined Apr 2012
I don't do anything. Like jmolwitz, I check to make sure that they are turning the right direction, then let 'em rip!!!
Gimpdiggity is offline Find More Posts by Gimpdiggity
Old Oct 15, 2012, 08:44 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
You must first hold it over your head and dance in a circle , three times to the left , four times to the right , or is it four times to the left . Then install it and have FUN .
highflyerbill is offline Find More Posts by highflyerbill
Old Oct 16, 2012, 03:09 PM
cosey321 is offline
Find More Posts by cosey321
Joined Sep 2012
Might be quite a fun ^-^ thread))
cosey321 is offline Find More Posts by cosey321
Old Oct 16, 2012, 06:30 PM
Kcal is offline
Joined Jul 2008
"And dance by the light of the moon."
Question What do you use for wing tape on 3 piece wing hog2soar Sailplane Talk 14 Aug 31, 2012 01:28 PM
Discussion Do you evaluate air before launching and how you do it ? FRIDAY_2008 Thermal 38 Aug 12, 2012 01:35 AM
Discussion Traders; Before you sell, do you search the Wanted first ??? jcstalls Trader Talk 7 Jul 12, 2012 09:22 AM
Discussion Using Virtualdub to record FPV - What settings do you use? NorCalMatCat FPV Talk 12 Feb 25, 2012 08:33 PM
what brushless motor do you use with your zagi? jeff262 Foamies (Kits) 7 Nov 28, 2003 10:31 AM
