Old Dec 03, 2003, 03:31 PM
enigmabomb is offline
Find More Posts by enigmabomb
TeamZiering
enigmabomb's Avatar
Chandler, AZ
Joined Mar 2002
How to build a GWS Gear Box
Here is a picture tutorial of how to assemble your own GWS Gear Box. Total Cost: 12.20 plus shipping. I picked up everything from www.parkflyermotors.com
Moderators: Please move if this is the wrong forum.
Firstly, Assemble your parts together:
2 GWS Bearings
1 EPS Frame
1 Spur Gear
1 Prop Shaft
enigmabomb is offline Find More Posts by enigmabomb
Old Dec 03, 2003, 03:32 PM
TeamZiering
enigmabomb's Avatar
Chandler, AZ
Joined Mar 2002
Open everything being careful not to lose any small pieces (I almost lost a washer) and put the bearings inside the GWS EPS Frame. They should be snug.
Old Dec 03, 2003, 03:34 PM
TeamZiering
enigmabomb's Avatar
Chandler, AZ
Joined Mar 2002
Next, I like to put the Spur Gear on the shaft. This lets you get it on really good without putting any strain on the gear box frame. I push the end of the shaft against the edge of the table and push on the gear. The final result is a nice, tight fit.
Old Dec 03, 2003, 03:38 PM
TeamZiering
enigmabomb's Avatar
Chandler, AZ
Joined Mar 2002
Next, I put the shaft inside the frame. NOTE: Make sure to slide it in from the FRONT OF THE FRAME. So the spur gear should be moving towards the frame. It seems simple, but this alluded me for sometime. I was removing bearings and such.
Put the washer included with the prop shaft on the end of the shaft.
After that's done, it's time to install the dreaded "E-Clip" I have a good method. Get a pair of needle nose pliers and put it in the very end. Press it in just enough so it stays without you having to hold it.
Old Dec 03, 2003, 03:42 PM
TeamZiering
enigmabomb's Avatar
Chandler, AZ
Joined Mar 2002
Once the clip is on there so it doesn't want to fall off, Put the pliers sideways, and finish squeezing the clip on. See the attached picture. It should make a 'click'
Old Dec 03, 2003, 03:43 PM
TeamZiering
enigmabomb's Avatar
Chandler, AZ
Joined Mar 2002
Admire your hard and precise work. It should spin freely. You should feel good, this was not an easy process.
Old Dec 03, 2003, 03:49 PM
Philip Thulin is offline
Find More Posts by Philip Thulin
Hacker motoren rules :)
Philip Thulin's Avatar
Sweden, Östergötland County, Norrköping
Joined Sep 2001
why not buy the whole gearbox complete with motor and spinner redy to use for $17 instead?
/Philip
Philip Thulin is offline Find More Posts by Philip Thulin
Old Dec 03, 2003, 03:52 PM
TeamZiering
enigmabomb's Avatar
Chandler, AZ
Joined Mar 2002
That 5 dollars is like 4 prop shafts or 3 propellers. I could spend the money, but with a little ingenuity I can save 5 bucks. Every little bit counts when you're a student.
Old Dec 03, 2003, 03:58 PM
KSU Flyer is offline
Find More Posts by KSU Flyer
KSU Flyer's Avatar
Manhattan, Kansas, United States
Joined Nov 2001
FYI
You can buy an EPS100 motor with gearbox w/ ballbearings from Balsa Products for $12.00...
http://www.balsapr.com/catalog/motors/EPS100C.asp
-Mike
KSU Flyer is offline Find More Posts by KSU Flyer
Old Dec 03, 2003, 03:59 PM
temp_oct is offline
Find More Posts by temp_oct
I told them, I was drunk.
temp_oct's Avatar
Bangkok, Thailand
Joined Aug 2003
I think you can buy assembled EPS350 gearbox (with spinner) from aircraft-world.com for $11.80 + $2.50 S&H. It is cheaper than built the whole thing from all the parts (well, compared to my LHS anyway )
temp_oct is offline Find More Posts by temp_oct
Old Dec 03, 2003, 04:03 PM
j_z_123 is offline
Find More Posts by j_z_123
BOSS
j_z_123's Avatar
New Jersey (excl EWR), United States
Joined Apr 2002
Well, This is good to know, if you bend your prop shaft. Not that I do
Jon
j_z_123 is offline Find More Posts by j_z_123
Old Dec 03, 2003, 04:57 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
The EPS-100 gearbox is just a fraction of an inch smaller in diameter than the EPS-300/350 gearbox, and, as Mike says, can be bought with 280 motor for $12. I now have quite a collection of 280 motors since I've been buying these to convert to Johnson 250 use.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Dec 05, 2003, 12:44 PM
Joined Sep 2001
I´m a student...
how to build a vaccum forming box? rayc Scale Kit/Scratch Built 14 Feb 28, 2008 11:46 AM
GWS gear box ????? electro Foamies (Kits) 6 Aug 10, 2003 09:43 PM
Prop size for Cobra with GWS Gear box Never Enough Parkflyers 3 Aug 06, 2003 02:28 PM
flight report GWS gear box astro 010 dave morris Parkflyers 19 Dec 22, 2002 10:02 PM
