Old Oct 14, 2012, 05:15 PM
Shane Sunday is offline
Find More Posts by Shane Sunday
United Kingdom, Northern Ireland, Belfast
Joined Jun 2011
Brown out! Loss of a new model.
Hey there kids. Well here we are again. I'm afraid it has happened again. Although this time it was not pilot error this time it was a bona fide brown out.
Today I put my lovely Kyosho ME109 in the air and she was flying beautifuly albeit a little underpowered. She was running 6 servos so I used a fully charged life battery to power the Spektrum AR6200 receiver. It was great until I took her high, rolled her onto her back and dove whilst levelling out. It was all going so well and she was almost level when I noticed no response from any of the controls. I thought she was level enough to maybe hopefuly skid across the runnway but alas she was in many peices. It certainly didn' t look like a plane any more.
As I walked the walk of shame I tried moving the sticks and low and behold life returned. Earlier the range check went well so I was not worried. My Spektrum DX8 is like new. I learned how to bind ages ago. I've been so cautious lately that I'm beside myself. How did it go wrong?????
I truely feel this is not my fault but that of the manufacturers. Has anyone ever won a dispute on a faulty product? Kind of bummed out.
On a brighter note though. I went on to have 3 more flights with my starmax f18 which were fun, exciting stress free flights. It uses an Orange receiver and I gotta tell you... I trust it more than I trust the name brand at the moment.
Thanks for listening guys.
Shane Sunday is offline Find More Posts by Shane Sunday
Old Oct 15, 2012, 05:13 AM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
I've read that more than 3 servos on 3s without a seperate BEC will cause the brownout, but I'm not speaking from first hand experience. Crashing aint no fun and that I do know first hand.
HELModels is offline Find More Posts by HELModels
Old Oct 15, 2012, 09:50 AM
dedStik is online now
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
OP mentioned using a seperate LIFE battery for the RX so I doubt the BEC or too many servos were the issue.
Would help to know if there was RX flashing going on when the plane was recovered.
dedStik is online now Find More Posts by dedStik
Old Oct 15, 2012, 11:57 AM
Joined Jun 2011
hey guys.
The receiver wasn't flashing that I had noticed. As I recall it was on. It certainly wasn't flashing when I started out. I've had that happen before.
Old Oct 15, 2012, 01:24 PM
AeroKen is online now
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
Have you tested that life battery under load (the same load that 6 servos plus receiver would draw) to see if it maintains it's voltage under load?
AeroKen is online now Find More Posts by AeroKen
Old Oct 15, 2012, 07:10 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
A 6.6fv LiFe shouldn't EVER sag below brownout voltage even on Spektrum recievers. Even if the LiFe flat dead, it should've sagged to maybe 4.5v... I think a less-than-perfect battery's at fault.
acetech09 is offline Find More Posts by acetech09
Old Oct 16, 2012, 09:29 AM
HELModels's Avatar
Joined Aug 2003
Right you are, I read it as "life" as in a fresh battery.
Just this morning I gained personal experience with a BEC that decides it needs to shutdown and stop supplying power to Rx and servos - Smash.
Old Oct 17, 2012, 11:40 AM
Joined Jun 2011
These are some things to think of for sure but. The battery is still full of charge and I haven't done anything new since the crash. It's a 1700 mah life battery too. So I dunno. I'm sending the receiver back to Horizon as we speak. At the moment I just don't know.
Thanks for the help guys.
Old Oct 18, 2012, 07:59 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Just a guess, but was the elevator horn on the underside ?
If so when/if she is repaired, try holding full up elevator and gently press down on the elevators trailing edge.
Sometimes manufacturers do not brace a push rod or snake enough to stop it flexing and allowing the elevator to move down under higher speeds.
A 'pull' is always better than a 'push' with a control, they just look prettier if stuck out the way on the underside, but they must not flex, or .........
eflightray is offline Find More Posts by eflightray
Old Dec 03, 2012, 11:12 AM
andrew26842 is offline
Find More Posts by andrew26842
Joined Oct 2012
Crash Post Mortem! BEC
I had a AcroMaster that suddenly insisted on pulling straight up when I hit the throttle! It also started hating right hand turns and stalled at a good rate of speed from a good height into the ground!
I replaced it with a FunCub It also Pulled Up with throttle and on the first flight spiraled into the ground in a Right Turn!!!!!
I was Unable to duplicate the issue on the ground, and it was Not a Range Issue.
The Castle Creations 50 Amp ESC was old tired and became faulty!
When I replaced it.... I now have complete control!
andrew26842 is offline Find More Posts by andrew26842
Old Dec 24, 2012, 05:13 PM
Daz393 is offline
Find More Posts by Daz393
Depron Daz
Daz393's Avatar
United Kingdom, England, Basingstoke
Joined Feb 2012
Is your AR6200 a true Spektrum Rx? I bought a couple and have had brown outs. Fortunately the one in my EF 58" Extra was intermittent and kept coming back quick enough to recover from a high wide turn. They are now in the bin. Don't believe that they were original kit and the internet and some shops I hear are full of fake 6200s. I now pay the full price from an authorised Spektrum dealer.
Daz393 is offline Find More Posts by Daz393
Old Dec 26, 2012, 01:11 AM
Detroit Dave is offline
Find More Posts by Detroit Dave
Detroit Dave's Avatar
United States, MI, Taylor
Joined Mar 2009
I moved my DX-7 to my park flying planes. I put 3 planes in that I couldn't explain why. All were glow planes with 6 volt, high MaH ratind receiver packs. They also had been recently cycled. Lost a Great Lakes Bipe, a Mud Duck Sport, and a Fokker DR-I triplane. The Fokker will get replaced, but it won't see 2.4 gigahertz.
The Mud Duck went free flight seconds after take off. I had just given it a touch of rudder or it would have flown straight away. It made a circle that must have been close to half a mile in diameter. The wind finally lifted one wing and it went in on a knife edge. It was in the air close to three minutes and I never got any control back at all. Couldn't even shut down the throttle.
I have flown 2.4 with orange receivers and Lazer Toyz, 6 channel receivers and haven't had any problems with them, but those are mostly small planes and park flyers.
Bought a bunch of 72 Megahertz receivers and I'll be flying them with the planes that I value. Hard to give something up when it works.
Dave
Detroit Dave is offline Find More Posts by Detroit Dave
Old Jan 01, 2013, 06:44 PM
Joined Oct 2012
Will the Castle Creations CapPack prevent Brown-Outs?????
Old Jan 01, 2013, 06:52 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
I don't think this was a brownout - with a LiFe pack of that size you should have had gobs of power. I worry about your "underpowered" comment and wonder if that was not helping. An inverted maneuver to boot.
Having a hard time with your brownout analysis. I think something else is amiss here.
Old Jan 02, 2013, 09:49 AM
acetech09's Avatar
Joined Apr 2012
No, the capPack reduces voltage spikes between the battery and the ESC.
What you want is this: http://www.hobbyking.com/hobbyking/s...Protector.html
Discussion Brown out, Hold, Loose wire or Something Else? wayfaringdreamer Electric Plane Talk 4 Aug 17, 2012 12:30 PM
Question Do Analog Servos brown out when used with a Digital Radio? Cathay Stray Radios 89 Aug 09, 2012 02:46 AM
Help! AR600 AND AR8000 browning out/rebooting, but not blinking? -= GYRO =- Radios 19 Jun 16, 2012 12:45 PM
Discussion Brand New HK OrangeRX brown out/signal fade geekrawker Radios 11 Apr 09, 2012 04:20 PM
Discussion Plane crash after Spektrum 2.4 signal loss! Was it brown out? Stuart Warne Crash Discussion 11 Oct 02, 2009 08:46 PM
