Old Oct 14, 2012, 04:50 PM
Axizor is offline
Find More Posts by Axizor
Joined Aug 2012
V911 Wobble Problems
Hey guys. I just got a new WLToys V911 heli yesterday. I have only got about 8-10 flights out of it. I've had my fair share of crashes so far, but nothing too serious and I always try to cut throttle when I know it's about to crash or right after it does crash. The heli always went right back into the air and flew fine.
Today after about 3 or 4 flights (with a couple of crashes) I noticed that the heli wasn't hovering stable like it used to and was drifting forwards and to the left. I tried to correct it with trim, but I soon realized that it was wobbling in the air. Sometimes the wobbling is really bad. It can still fly somewhat easily, but it sure does wobble.
Here is a video I found on YouTube of another V911 doing the same thing.
WL Toys V911 helicopter hovering problems (0 min 19 sec)
I would gladly appreciate some insight on what may be wrong. Thanks guys!
Axizor is offline Find More Posts by Axizor
Old Oct 14, 2012, 05:29 PM
Budasac is offline
Find More Posts by Budasac
Micro Menace
Joined Aug 2012
I would try changing the main shaft. If you take it out and roll it on a flat surface you'll be able to tell if it's bent.
Budasac is offline Find More Posts by Budasac
Old Oct 14, 2012, 05:38 PM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Hold onto it and run it up slowly and see if it shakes. Check tracking of flybar and blades. Easy to see if its not tracking right. I have a V911 original one that shakes in hover but flys fine and doesn't drift. In normal flight its fine and has done this last 50 flights so no concern. It does track true so check it out. Could be main shaft if blades do nor track right.
dankar04 is offline Find More Posts by dankar04
Old Oct 15, 2012, 05:01 AM
hawk01 is offline
Find More Posts by hawk01
Joined Aug 2006
i also have a V911 and have dozens upon dozens of flights on it. also had numerous inadvertent crashes and it is quite a resilient little machine.
since its maiden flight i have already noticed the heli does not like to roll left very much in hover. more so it does not like to move backwards in hovering.
it inherently wants to move forward and lean to the right slightly everytime. this characteristic trait of the single rotor micro FP helis is also prevalent and more pronounced with the nine eagles bravo SX (with hughes MD fuselage) which i also have.
fortunately, the V911 can actually hover with a level attitude. the bravo SX hovers with a very pronounced lean to the right. this is nothing out of the ordinary, it is inherent upon micro FP helis as you may read on the nine eagles thread FAQS...
so V911 owners don't fret, the wobble is just nature of the beast. i just constantly keep it flying forward doing right turn circuits and high speed funnels (which it does very nicely!).
you will notice even if FFF it does not like to do left turns very much even with good coordinated use of aileron and rudder.
HTH
hawk01 is offline Find More Posts by hawk01
Discussion v911 fading battery performance problem razholio Micro Helis 9 Jan 13, 2013 02:25 PM
Discussion V911 Circuit Board Problem janosaba Micro Helis 15 Oct 22, 2012 11:38 PM
Discussion V911 Cannot sustain fast forward flight problem. Help appreciated Raymondorock Micro Helis 20 Oct 21, 2012 10:39 AM
Question Problem with with rudder on V911. gtfreight Beginner Training Area (Heli-Electric) 9 Aug 02, 2012 10:44 PM
Discussion v911 Problem Grimp25 Micro Helis 6 Apr 18, 2012 08:58 PM
