Old Oct 13, 2012, 10:17 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Question
LED best visibility
I've got strobe and landing lights on a couple of models, one a bought set, and the other home-made using a PICAXE programmable chip and the brightest LEDs I could find.
Neither of them are visible until dusk, and both are only visible when they're pointing almost directly at you. The limited viewing angle seems to be common to all high power LEDs.
So, is there a simple way to improve the viewing angle, please? Reflectors seem to be no use because the light's facing forward anyway, so I'm thinking some kind of lightweight lens must be the solution. Anyone willing to share a successful solution?
Also, regular LEDs seem to max out at 30mA (don't know what that equates to in light units), so is there any other practical device for this kind of application? My shop-bought set is limited to 5v supply, but I can configure my home-made one to run on higher voltages if that will help.
I've considered an array of 3mm LEDs all pointing in slightly different directions, but they don't seem to come in such high power versions as the 5mm, 6mm, or larger ones.
abenn is offline Find More Posts by abenn
Old Oct 13, 2012, 10:30 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
you can find leds with a wide viewing angles. but the wider the angle the dimmer it will look. A simle transistor driver will brighten them up. try digi-key, just pick your color.
http://www.digikey.ca/product-search...r/525057?k=led
Martin Y is online now Find More Posts by Martin Y
Old Oct 13, 2012, 11:06 PM
rmteo is offline
Find More Posts by rmteo
User
Colorado
High power LEDs can draw up to several amps (and emit blinding amounts of light) with wide viewing angles (such as this one with 115 degrees Cree XB-D).
For beacon style applications, lenses are available that will give a full 180 degrees viewing angle
17.2 mm Side Emitter Lens
rmteo is offline Find More Posts by rmteo
Old Oct 14, 2012, 01:20 AM
abenn is offline
Joined Jul 2004
Some good info there, thanks. I think I'll try out some of those lenses, perhaps in conjunction with a multi-LED array.
How can a transistor driver brighten up an LED, Martin Y? They're limited by their V and mA rating, aren't they?
Edit: Using search terms from the info you've given me has revealed a whole new world of high power LEDs with built-in lenses, from my regular UK suppliers, including the Cree models. I'm still curious about "drivers" though, for some of my search results indicate that a driver may be required for some devices -- don't you just apply appropriate + and - voltage?
Old Oct 14, 2012, 03:26 AM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Your PICAXE is limited to driving 25mA to a LED, you need a series resistor to limit the current to this safe value.
For more current output than that you need to use a buffer or driver transistor to drive the LED, and the limit then is really your power supply.
PICAXE manual 3 page 10 shows the general arrangement for using a transistor to drive more current.
srnet is offline Find More Posts by srnet
Old Oct 14, 2012, 03:53 AM
abenn is offline
Joined Jul 2004
Okay, I already use transistors between the PICAXE output and the LED. Even though I often don't need it from the current point of view, I do it as a matter of course so I can change the output device -- such as running multiple LEDs in parallel from the one output. Not being very up to speed on modern electronics, I thought maybe you and some of the advertisers were referring to something else
Old Oct 14, 2012, 05:39 AM
Stef is offline
Find More Posts by Stef
Flying Saucer Mechanic
Stef's Avatar
Middle River MD
Joined Dec 2000
you can overdrive the LED if you pulse it if you are careful it won't hurt it. Also when I was making and selling light kits I advised users to sand the LED to "frost" the plastic. It will display as a bright glowing ball.
Stef is offline Find More Posts by Stef
Old Oct 14, 2012, 10:51 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
A Cree XML LED will work with up to 3A. But you will need to have a pretty good heatsink. I use this type of LED in my better flashlights, and it is awesome.
Julez is offline Find More Posts by Julez
Old Oct 14, 2012, 05:04 PM
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
I use a NPN transistor for driving the leds. with a 22 ohm resistor to limit current. Here is a night approach system I made. When pulsed the leds can be strobed very brightly without problems of over driving.
104356 (1 min 11 sec)
Montreal 2012 night flight (5 min 22 sec)
Old Oct 14, 2012, 09:51 PM
abenn is offline
Joined Jul 2004
Thanks guys. Just one more question pending further research into the manufacturers' spec sheets:
When you talk about safely overdriving LEDs with pulses, what length of pulse are you typically talking about, what duration between pulses, and what percentage over the rated current?
Old Oct 14, 2012, 10:02 PM
rmteo is offline
User
Colorado
The proper (and the most efficient) way to do it is to use a LED driver IC. Take a look at Zetex Design Notes
Old Oct 16, 2012, 06:38 PM
nickelflipper is offline
Find More Posts by nickelflipper
Oregon, USA
Joined May 2010
Another way to go is the linear regulator route given the 5V supply. Here is a cheap high power led already mounted Here They also have the bare AMC7135 linear regulator chips for CC 350ma. The AMC7135 Vdd pin can be PWM'd with the Picaxe. Lots of other similar flashlight minded sites with all manner of led parts and pieces. You need plenty of heatsinking though if run at full power for any amount of time.
nickelflipper is offline Find More Posts by nickelflipper
Old Oct 17, 2012, 03:29 PM
larryb is offline
Find More Posts by larryb
Looking for a place to crash
United States, WI, DeForest
Joined Jul 2001
I got my LED's at the following:
www.spudgun.com/led.htm
He offers 5, 8 and 10mm LED's. The 5mm are 1/2W and the 8 and 10mm are 1W LED's. The 8 and 10mm can be seen in broad daylight and are great for adding Nav or landing lights.
These are the brightest LED's I have seen. They operate on 4.8Vdc and can be connected to the RX power supply or an external power supply.
You can't beat the prices anywhere
Larry
larryb is offline Find More Posts by larryb
Old Oct 28, 2012, 06:51 AM
abenn is offline
Joined Jul 2004
Follow-up questions ...
Okay, so I've got some white, red, and green Cree LEDs, and I have to agree they're bright. But I've never worked with surface-mounted components before, or components this small producing so many watts, so I need some practical help.
First off, I managed to knock off the attached half-dome lens from one of the LEDs while soldering wires to it. It still works, though I'm not sure what its visibility angle is now. Do I need to provide further protection (a coating of clear polyurethane or epoxy, for example) to hold things together better?
Secondly, I've soldered short 24g wire leads onto the LEDs so I can use them like my "normal" 3mm and 6mm devices. What is the best technique for putting them onto PCB board with a hand-held soldering iron? I'm guessing (haven't tried it yet) I make sure the copper strips on the board are bigger than the LED, pre-tin them, and then sit the LED on them while applying the iron to the bit of strip that's protruding around the LED
Thirdly, I've seen mention of heat-sinks. For the moment I'm just using my LEDs as strobes, so I don't think they'll overheat. But what about when I want to have landing lights running near their rated current limit of 1000mA? How do I go about dissipating the heat if I need to?
Lastly, for my temporary rig I've simply put resistors in line to achieve about 500mA current from nominal 5v input. For the moment the only ones I could find locally are huge 3W wire-wound ones, though I've now sourced some smaller 1W ones which will be sufficient watts for the green and white, but not for the red, which needs at least 2W. My strobe circuit will still work if I reduce the voltage to 4v (though it then won't be able to work directly off the receiver or a normal BEC) to reduce the resistor wattage, but is there a more elegant electronic solution to individually drop the voltage in each individual LED so that they can all operate off the same voltage, rather than a rather large resister in each line?
Old Oct 28, 2012, 08:37 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Wire them in series. Each LED will, like any diode, have a drop voltage that you can find in the datasheet. It's the same one you used to compute the drop off 5V when selecting the resistor.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Discussion NAZA/Wookong LED Visibility BobRCnut Multirotor Electronics 2 Sep 30, 2012 03:11 PM
Discussion Daytime visible LEDs? spencer6891 Night Flying 15 Jun 17, 2012 12:29 AM
Discussion Best Paint Scheme for High Visibility? wannabe FPV Talk 17 Mar 06, 2012 02:39 PM
Discussion How visible would LED strips inside a Depron airframe be? NanoDave Foamies (Scratchbuilt) 15 Mar 14, 2011 04:23 AM
Discussion LED's for high altitude visibility? Martin Hunter Aerial Photography 35 Mar 29, 2007 10:04 AM
