Old Feb 07, 2013, 01:01 AM
Dave Campbell is offline
Find More Posts by Dave Campbell
United States, MI, Commerce Charter Township
Joined Dec 2000
Originally Posted by cale10 View Post
ive seen both but i have heard with an 049 the hmmer is a bit underpowered.
... Mine wasn't with a TD .049. It was pretty fast and I was very happy with it until the day I put a VA .049 on it and suddenly had unlimited vertical. The Hummer was designed for the TD, so you might be disappointed in it with a reed valve motor.
Dave Campbell is offline Find More Posts by Dave Campbell
Old Apr 14, 2013, 05:38 AM
jgumley is offline
Find More Posts by jgumley
Joined Aug 2012
Covered and ready for maiden
Finally (after moving house) I've covered the Idol. Aside from some indiscretions on the compound edges of the wingtips, I'm pretty happy with it. I've tested the engine in situ and although it runs well, it doesn't provide much power. At best, I think this will be a lazy (but stable) flyer... stay tuned...
jgumley is offline Find More Posts by jgumley
Old Apr 15, 2013, 12:52 AM
sundaramvelar is offline
Find More Posts by sundaramvelar
Fan of ultra Micro RC and FPV
sundaramvelar's Avatar
India, PB, Jalandhar
Joined Jan 2010
Fantastic build there. Really Nice Detailing. Mine flies real docile and stable which is without aileron. You may consider adding nose weight as mine was tail heavy with Battery behind. I had to move the 800 mah 3S lipo right to the nose behind engine to get correct CG at 20%.
After some tweaking with the CG, which is now at 20% a quick flight video. The Cox runs for more than 14 mins with the 1 ounce fuel tank did a quick video since the ground was very small.
FIRST LASER IDOL TEST FLIGHT (1 min 41 sec)
sundaramvelar is offline Find More Posts by sundaramvelar
Old Apr 22, 2013, 12:06 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Looking good guys!
jgumley - You will notice that power improves after you go through a few tanks of fuel and the piston beds in properly. You will find the starting gets easier, more power and the ability to lean it out a bit more for more rpm in the air.
Part of the reason I don't recommend throttles on Cox engines is that they rob you of power... try it without one and you might be surprised at how well she goes flat out.
I do like the muffler and cheek material removal though.,.. must run a lot cleaner like that - my little Cox powered La Stick I built from scratch always gets soaked in castor!
- boingk
boingk is offline Find More Posts by boingk
Old Apr 22, 2013, 08:23 AM
jgumley is offline
Joined Aug 2012
sundaramvelar and boingk - Thanks for the comments and tips. Stay tuned for the maiden!!
Old Apr 26, 2013, 09:34 AM
PROACE is offline
Find More Posts by PROACE
Rocky Mountain High and Higher
PROACE's Avatar
Joined Jan 2002
As much as I like the Cox engines.. I bet the Idol would be awesome (and quieter) with a PAW .03 diesel.
The PAW .049 would be too heavy.
PROACE is offline Find More Posts by PROACE
Old Apr 26, 2013, 09:44 PM
skaliwag is offline
Find More Posts by skaliwag
sundaramvelar...... Well flown Sir... On a lean run should fly well. I bet it will loop
skaliwag is offline Find More Posts by skaliwag
Old Apr 26, 2013, 11:38 PM
Joined Jan 2010
Thank you.
Loop
I doubt it. Here at 1500Mtrs from MSL it is not picking RPM more than 12000/- even when lean it reaches just 13500. I might have to do a rather steep dive for it.
Old Apr 27, 2013, 08:04 AM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Sunderamvelar, Are you using the Tee Dee head, or the Surestart one? That will make a difference in power for sure.
aspeed is offline Find More Posts by aspeed
Old Apr 27, 2013, 01:52 PM
Joined Jan 2010
I am using a Surestart head,
Old Apr 27, 2013, 02:40 PM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
The TD head will give a few more revs, that may help up in the clouds where you live. The combustion chamber is more like a trumpet than a bowl, giving more compression and power. There are some conversion plugs that will work with a Nelson type plug, and a Merlin plug that will equal the power of a TD plug. It is a bit cheaper too. The Nelson plug may be a bit hard to find where you are.
Old Apr 28, 2013, 12:49 PM
Joined Jan 2010
Thanks will definitely try that
Old Mar 28, 2016, 09:57 AM
Rczorro is offline
Find More Posts by Rczorro
Joined Dec 2012
is there any good 1/2a pylon racer kits.
if there is please give a few links.
thanks
Rczorro is offline Find More Posts by Rczorro
Old Mar 28, 2016, 03:10 PM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
Steve may have a wing kit for the Scalpel? http://www.selecthobbies.com/kitdata.htm
Old Mar 28, 2016, 05:23 PM
NEW222 is offline
Find More Posts by NEW222
Canada, MB, Oakbank
Joined Dec 2004
Is something like the Sig Hummer something you would be looking for?http://www.sigmfg.com/IndexText/SIGRC50.html
NEW222 is offline Find More Posts by NEW222
Question What are some good motors for the HT-FPV flohio117 Multirotor Talk 11 Feb 18, 2013 07:01 AM
Discussion What are some good quality hex wrenches to buy? armanm The Builders Workshop 17 Oct 14, 2012 09:37 AM
Discussion Good Control Line for 1/2A Plastic RTF's? Ah Clem Control Line 12 Jul 02, 2012 08:02 PM
Sold Ace 1/2A Pacer Kit (complete,) Lanier 1/2A Shrike Kit (Partial) SargeAF Aircraft - Fuel - Airplanes (FS/W) 8 May 01, 2010 08:59 AM
Discussion What are some good 40" balsa kits? grampi 3D Flying 13 Jan 20, 2007 01:02 PM
