Last updated on 12/14/12:
I've been a big fan of the 262 for years and have built several GWS foamies with varying degrees of success over that period. When I saw that Dynam had released a 262 I immediately jumped on the first one I could find in stock. I quickly discovered that I wasn't the only one in line. Although it took me a while to get my hands on the plane this turned out to be a blessing instead of a curse. By the time it had arrived there were already a plethora of folks posting and boasting about what a wonderful flying model Dynam had created. In no time at all the knives, glue, spackel and paint emerged as folks began to modify and improve that which Dynam had created. The results have been spectacular as everything that could have been improved seems to have been by one enthusiast or another. Naturally I took full advantage of this and compiled a list of mods that I knew I wanted to implement. Below you'll see the list and the pictures of the progress I've made.
This post is ongoing and will be changing from time to time as I experiment with new mods and techniques on version II. Most of the updates will be in the form of pictures. Each photo will have details of what it depicts. Great models deserve a great journey and this ones been a blast so far. I hope you enjoy the ride. Feel free to PM me if you have questions about any of the mods.
* Version I & II - Sanded off all of the injector marks on the tail feathers and undersides of the wings
* Version I & II - Moved tail feather servos to the tail surfaces and removed the unsightly factory installed push-rod tubes.
* Version I & II - Installed bisected flaps.
* Version I & II - Moved the ESC to provide adequate cooling.
* Version I & II - Installed Gun tubes to provide better battery cooling.
* Version I & II - Installed a CC 10amp UBEC.
* Version I & II - Opened up the battery compartment to allow room for
two 2650-3300 mAh packs.
* Version I & II - Statically balanced the fan blades to minimize vibration.
* Version I - Installed .05watt 150ohm resistors into the LCD lines.
* Version I & II - Replaced the post struts with Oleo struts.
* Version II - Gear doors - (
Nose door, and
Mains)
* Version I - Apply vinyl appliqué to reinforce the bottoms of the nacelles.
* Version I & II - Fill, repaint and WBPE the entire plane.
* Version I & II - Install a high quality pilot figure.
* Version I - Fabricated a 50mm Canon for ME-262A 1/u4as conversion. (
version specific)
* Version I & II - Nacelle intake modification.
* Version II -
Leading Edge Slats & Flaps (
- click the link to see the video. While these are historically inaccurate, they are the only practical and reliable setup I've been able to find.)
Below are three links to short slat concept videos none of which I felt could be done reliably.
*weighted slats
*weighted slat - air pressure retraction
*drooped L.E.S.
The nacelle mod was originally done beautifully by
Stacker. My version although slightly different drew directly off of his so kudos to you Dave (
Stacker), on the gorgeous job you did there!
