Old Oct 13, 2012, 08:30 PM
kimchiyuk is offline
Find More Posts by kimchiyuk
kimchiyuk's Avatar
United States, NY, Barryville
Joined Jun 2012
wetting balsa to shape
I'm building my first kit. A Tower Hobbies fun 51. One of the balsa sheeting strips for the leading edge is very firm. I have lightly wet other blasa with windex with great results. This sheet though doesn't want to budge with a light spray. How much can I saturate it without ruining the wood or its future integrity or any other ideas? I don't have a place to get balsa within a reasonable distance or I'd just get a new piece.
kimchiyuk is offline Find More Posts by kimchiyuk
Old Oct 13, 2012, 08:40 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Put that stubborn piece in the bath tub under water overnight.weight it down,and let it think about it's bad behaviour...The harder it is,the longer it takes to soak it up..It won't hurt the balsa to lie there for a long time.
When you do try to bend it, do it gradually, slowly,as the wood fibers stretch into the new shape. Weight it down and let it dry.
If you presoak with windex,be sure it contains ammonia-some of the new blends don't,and Ammonia is what you need.
epoxyearl is offline Find More Posts by epoxyearl
Old Oct 13, 2012, 09:00 PM
no1isnormal is offline
Find More Posts by no1isnormal
United States, FL, Edgewater
Joined Nov 2010
+1 on the Ammonia. I mix it 80:20 with some water in a spray bottle for bending Balsa.
no1isnormal is offline Find More Posts by no1isnormal
Old Oct 13, 2012, 09:22 PM
kimchiyuk's Avatar
Joined Jun 2012
Thanks for the info...and yes the windex I'm using contains ammonia. Just out of curiosity, what is it about the ammonia that makes it the go to for balsa shaping?
Old Oct 13, 2012, 09:31 PM
epoxyearl's Avatar
Joined Oct 2011
Can't say-apparently it breaks up the wood's "surface tension", allowing water to penetrate into the fibers.
Old Oct 13, 2012, 09:52 PM
Joined Nov 2010
The ammonia breaks down the hydrogen bonds within cell walls and within the lignin matrix. This allows molecular movement when subjected to tensile or compressive forces. Once the ammonia evaporates from the wood, new bonds are made creating a permanent set.
The process is reversible by further ammonia treatment. Chemical set is not recoverable by treating with hot water or steam; unlike with steam and hot water bending treatments, no stresses or strains are bent into the wood. Thus, the new shape is like other kiln or air dried wood. It is ready to be machined, glued and finished.
Old Oct 13, 2012, 09:56 PM
kimchiyuk's Avatar
Joined Jun 2012
So after soaking it in the tub overnight, I still spray it with ammomia when setting to the desired shape?
Old Oct 13, 2012, 09:59 PM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
Put some ammonia in the tub with the water.
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Oct 13, 2012, 10:08 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Soak it down and keep it that way until it's like overdone pasta...
When it dries the lignum that forms the cell walls of the wood will harden up just fine once the water and ammonia evaporates.
Instead of Windex, which isn't a "real" ammonia, use straight cleaning ammonia. To avoid the fumes I'd put the wood into a plastic garbage bag and then, while holding your breath, reach in and pour about two cups of the stuff over the wood then immediately fold the bag closed with as little air in it as practical and let it sit for about 5 to 10 minutes. If what I've read is right it'll come out like that overdone pasta I was talking about and lay in place just fine. And once it dries completely you'll be good.
BMatthews is offline Find More Posts by BMatthews
Old Oct 14, 2012, 12:24 AM
Petem is offline
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Australia, VIC, Werribee
Joined Jul 2008
Floorboards?
All the above is sound advice, but if a piece of balsa in a kit needs that much attention to make it behave, it is probably heavy as well.
My tendency is to replace the offending piece from decent stock in my pile, and save the kit balsa for floorboards.
Cheers,
PeteM
Petem is offline Find More Posts by Petem
Old Oct 14, 2012, 04:01 AM
epoxyearl's Avatar
Joined Oct 2011
Cheers,
PeteM
Most of us would,also,but the OP suggested an inconvenience to obtain new wood...learning to bend the piece he has would be beneficial.
Old Oct 14, 2012, 04:08 AM
epoxyearl's Avatar
Joined Oct 2011
-Funny this would come up,at the moment I'm researching "Balsa Wood" for a new forum soon to be added.
'Balsa and lite ply,scratch and kit builds' should be running soon.
Our intent is to further the traditional balsa building techniques which have brought us so much satisfaction.
I had thought an in-depth discussion would be helpful to neophytes and elders as well.
Once it's running,maybe you gents would join and share your knowledge and experience. If we're going to build with balsa,we should at least know what it is, and how it can benefit us the most.
Old Oct 14, 2012, 07:18 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
To preserve domestic harmony, Don't use the tub, make a Balsa bath from a piece of plastic waste pipe. Solvent seal one end and use a plug in cap for the other. Check your plumbers supplies for waste pipe systems.
You can keep it filled ready for use and despite what others may say, Ammonia is preferable, it makes the balsa feel like rubber.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Oct 14, 2012, 07:51 AM
heli_bee is online now
Find More Posts by heli_bee
Joined Mar 2005
Here is a link to an old post showing what can be done with ammonia and water!
http://www.rcgroups.com/forums/showp...51&postcount=3
Martin.
heli_bee is online now Find More Posts by heli_bee
Old Oct 14, 2012, 09:30 AM
Al Offt is offline
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
Another suggestion for a soaking container is the trough used to soak pre-pasted wall paper. Most are 4 ft long with access to bend the balsa after it gets initially wet so you don't have to fill the trough too much in order to totally submerge the balsa piece.
Alan
Al Offt is offline Find More Posts by Al Offt
Question How wet is too wet for a non waterproof truck? Coenraad Off-road Cars 13 Dec 29, 2015 11:26 AM
Discussion Wet balsa forming 43851E The Builders Workshop 25 Nov 26, 2010 06:54 PM
Discussion Gluing wet balsa justy g The Builders Workshop 7 Oct 12, 2007 08:34 PM
shaping balsa sheeting erik1938 The Builders Workshop 6 Jun 01, 2004 04:55 PM
Question fiberglassed balsa winglet (shape first or later) papasmurf Slope 5 Oct 18, 2003 05:13 PM
