Old Oct 15, 2012, 02:14 PM
SrTelemaster is offline
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
Originally Posted by Brutus1967 View Post
OK? a glow plug cannot break?
Anyway, that is not how reliability assessments are made.
That would be: parts present combined with their respective mean faillure rate.
Personally, I think glowplugs in general show a significantly higher faillure rate than the combined chain of battery, sensor, electronics and sparkplug.
Brgds, Bert
Not to mention glow drivers & their high Ma capacity batteries.
SrTelemaster is offline Find More Posts by SrTelemaster
Old Oct 15, 2012, 02:19 PM
I HATE GLOW PLUGS!
Joined Feb 2012
Hi Adrian
Originally Posted by mac2286 View Post
I can't believe you found this thread. that just shows you are one dedicated man. Adrian, thanks again.
Adrian has his "sources".
Old Oct 15, 2012, 03:37 PM
kenh3497 is online now
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
How often does the ignition on your favorite auto fail? For all intents and purposes it is CDI. Yes there are some minor differences.......
Ken
kenh3497 is online now Find More Posts by kenh3497
Latest blog entry: A letter from my Senator.....
Old Oct 16, 2012, 12:44 PM
Gary Cee is offline
Find More Posts by Gary Cee
The best stuff is higher up
Gary Cee's Avatar
Joined Apr 2010
Brgds, Bert
I understand . Actually I was just breaking it down a bit . Still , there is very little that breaks down with a basic glow system . (Abuse aside) Even if you add on board glow (An extreme practice, far from mandatory) In the unlikely event of an onboard glow failure , the engine usually just purrs along without notice . In 50 years of flying , I have used on board glow with one plane . That plane is a loaner / trainer Kadet Senior . The on board glow is a convenience/ saftey addition to eliminate the need for a glow plug driver for starting . The engine idles and runs perfectly without the glow addition .
In the air , the main link is a simple glow plug . Many ,if not most glow plug failures are discovered and fixed on the ground .
The typical CDI has a myriad of components that can fail , any one of them can stop the engine at that point . Spark plugs foul , just as glow plugs fail . Hall effect sensors can come loose/fail , heavy on board batteries can fail , shielded plug wires can fail , CDI boxes etc . Shielding inadequacies can cause radio interference as well .
Parts that are not there cannot break still holds true .
Glow may have some drawbacks but the reliability and simplicity factor is pretty high with glow systems . I have seen very ...VERY few problems with glow systems . That won't keep me using CDI ..just sayin !
I whole heartedly doubt the potential glow failures in the air exceed the rate for spark ignition systems .
Diesel anyone ?
Gary Cee is offline Find More Posts by Gary Cee
Old Oct 16, 2012, 02:36 PM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
Spark ignition engines don't stop the fan turning nearly as much as glow ignition engines do.
just saying.....
TimBle is offline Find More Posts by TimBle
Old Oct 16, 2012, 02:47 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Originally Posted by Gary Cee View Post
Diesel anyone ?
Yes. I like diesels.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Oct 16, 2012, 03:04 PM
Brutus1967 is online now
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
Diesel anyone ?
Greg
I don't....
Too limited in their applications: Never seen a dieselized helicopter, boat or car, where as glow and petrol as well as "glow converted to spark" can be used in all of the above and then some.
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Oct 16, 2012, 03:09 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I fly diesel four strokes on a regular basis.
Greg
Old Oct 16, 2012, 03:37 PM
I HATE GLOW PLUGS!
Joined Feb 2012
Greg
I've heard that the old 15+:1 compression Saito FA150s & FA80s would readily run on diesel.
I guess that the glow plug was replaced W/a compression screw?
Old Oct 16, 2012, 03:39 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
My FA-80 wouldn't run on diesel, but I didn't put much effort into it. I convert OS four strokes engine to diesel.
Greg
Old Oct 16, 2012, 04:07 PM
Glue Gun is offline
Find More Posts by Glue Gun
registered user
Annapolis, MD
Joined Sep 2009
Here is a video I found of a Davis Diesel converted helicopter. The description says that the engine is an OS .32.
Diesel Raptor30flight (3 min 5 sec)
Glue Gun is offline Find More Posts by Glue Gun
Old Oct 16, 2012, 05:23 PM
The Netherlands
Joined Nov 2009
I stand corrected!
(The moment I wrote it I thought: somewhere, probably somebody has tried it)
But... not really impressed by how that engine runs....
Nevertheless, it's a Diesel Helicopter.
Brgds, Bert
Old Oct 17, 2012, 04:10 AM
Gary Cee is offline
Gary Cee's Avatar
Joined Apr 2010
just saying.....
I guess everyone gets different results .
Flameouts have never been a problem here
Given a properly set engine , there is little to go wrong from a component failure level with a glow system .
Lighter planes generally fly better .
Diesels !
Old Oct 17, 2012, 04:22 AM
bogbeagle is online now
Find More Posts by bogbeagle
Joined Mar 2007
I love my Enya .40 4C diesel.
Never quits, whilst ever it has fuel in the tank.
I wish they'd extend their range to include something about .70-sized.
bogbeagle is online now Find More Posts by bogbeagle
Off Site Siedel 7 cylinder Gasoline Spark Ignition 250CC Radial RC Airplane Engine icharus Aircraft - Fuel - Engines and Accessories (FS/W) 9 Apr 22, 2012 01:24 PM
Sold C&H Synchro-Spark ignition system needacheaphobby Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 01, 2012 10:03 AM
Video Running a vintage spark ignition engine rapmoz Fuel Plane Talk 1 Feb 21, 2011 10:11 PM
Discussion How to use Brushless Sensor to measure RPM on Spark Ignition Gas motor? ebourlet Eagle Tree Systems 2 Nov 17, 2009 10:22 PM
Discussion Benefits with a Spark Ignition on a Glow engine. Kikerumbo Engines 4 Aug 12, 2008 06:55 AM
