Old Oct 13, 2012, 11:23 AM
avt is offline
avt
Find More Posts by avt
avt
Hell Flyer
Israel
Joined Nov 2006
Help!
HK KK v2.1 - can't exceed 30% gain
I'm trying to tune my first quad (Hobbyking's Q450), and am facing serious oscillations when the gyro gains are increased above 25-30%. At %25 gain (roll and pitch) it hovers more or less smoothly. But obviously there's not enough gain for it to balance itself.
From what I've read, this should be a problem of unbalanced motors and/or props.
I balanced my motors and props (at least I think I did it right), but the oscillations are still there.
When I hold the frame in my hand and throttle up the motors with no props on, I can feel some vibes through the frame. It's not monotonic, more of a sinusoidal pattern.
Could these vibes affect the controller so badly? Are these vibes the source of my problems with the quad (and perhaps in other parts of my life? )?
UPDATE: Problem is pretty much solved after I flashed the ESCs!
After trying every possible solution, balancing every part again, I went to flash the ESCs (BlueSeries 30A) with SimonK FW.
Amazing improvement! I couldn't believe it would make such a change. It's like a completely different quad now. VERY responsive, VERY stable.
Thanks again for your help.
avt is offline Find More Posts by avt
Old Oct 13, 2012, 12:15 PM
guyg is offline
Find More Posts by guyg
Israel, Ness Ziona
Joined Sep 2004
Hi
can you write your settings here
as for P .gain/ limit
I Gain/limit for 3 chanels
Tx
Guy
guyg is offline Find More Posts by guyg
Old Oct 13, 2012, 12:29 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
And how the controller is mounted.
WiseDuck is offline Find More Posts by WiseDuck
Old Oct 13, 2012, 01:12 PM
avt is offline
avt
avt
Hell Flyer
Israel
Joined Nov 2006
It's glued to the foam which is glued with a double-sided tape to the body.
Then there's a zip tie which holds it in place. I tried my best to make it less prone to vibrations as possible.
About the PI settings, I got this controller, flashed with KK v4.7. I'm not sure how to tell the exact P and I.
All I can say is that the roll and pitch pots are at about %25-30 from minimim position.
The yaw pot is at %50.
Old Oct 13, 2012, 01:45 PM
oyibox is offline
Find More Posts by oyibox
Joined Jun 2011
yes, yes and yes. sorry but you'd better try another frame or at least make sure you've tighten evrything
oyibox is offline Find More Posts by oyibox
Old Oct 13, 2012, 02:08 PM
2400RDR is online now
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
As I understand it, in the 4.7 firmware, the roll pot controls P for pitch and roll, the Pitch pot controls I for pitch and roll, and the yaw pot still controls the yaw.
Suggested initial setup is roll pot = 50%, Pitch pot = 0% and yaw pot = 50%.
Here is a post from the Kaptain himself describing it:
http://www.rcgroups.com/forums/showp...5&postcount=73
Give this setup a try and see what happens. By the way, zero on the pots is fully counterclockwise. Also, you should realize that this board doesn't self level- you trim it to be as level as possible, but you still have to fly it. It looks to me that the zip tie you used may be defeating the vibration isolation effects of the foam. Try getting rid of that too.
Rick
2400RDR is online now Find More Posts by 2400RDR
Old Oct 13, 2012, 02:30 PM
antiguogrumete is offline
Find More Posts by antiguogrumete
Valencia
Joined Feb 2010
Same for me
HK Flight Controller KK2 Auto Level (1 min 37 sec)
antiguogrumete is offline Find More Posts by antiguogrumete
Old Oct 13, 2012, 03:19 PM
avt is offline
avt
avt
Hell Flyer
Israel
Joined Nov 2006
Rick
Thanks Rick, I just tried these settings. Got about the same results as before.
I also read that zero on the pots is fully counterclockwise, but for some reason this is not my experience. When the pots were at 50% and I wanted to lower the gain, I had to turn the pots CW, and not CCW.
I'm sure my gains aren't reversed. I guess if they were reversed I wouldn't stay in the air more than 2 seconds. I double checked them.
Also, when I tried to set the I pot at 0% (which should be fully CCW), the quad pitched down like crazy. I set it fully CW and the P pot to about 30% from fully CW, and it's back to normal.
I don't know what I'm missing here.
Old Oct 13, 2012, 03:39 PM
Joined Feb 2009
(EDIT)
Just curious- did you do the ESC calibration?
Rick
Old Oct 13, 2012, 04:36 PM
avt is offline
avt
avt
Hell Flyer
Israel
Joined Nov 2006
Rick
Yes I did.
Old Oct 13, 2012, 07:04 PM
kaz1104 is online now
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Some time ago I bought a "vigilante" frame from www.468.com, and after rebuilding this unflyable quad several times, the only variable left that I had not changed out was the frame itself !!. Seems the problem was, that even though I had balanced the propellers and motors vibration was badly messing with the flight controller. The solution was to cut some aluminium strips to act as doublers/laminate on the original arms. They bolt to the center frame with the arm mount and extend out to bolt to the motor with the original arm. It is now one of my best flying frames ... amazing change. This mod should also work for the Q450 frame in reducing, or at least changing, the resonant frequency of the arms of the frame. Flashed speed controllers will also generally allow you to use higher gain settings.
Mark
kaz1104 is online now Find More Posts by kaz1104
Old Oct 14, 2012, 02:07 AM
avt is offline
avt
avt
Hell Flyer
Israel
Joined Nov 2006
Mark
Would you be so kind to post pictures of the frame, so I can see where the aluminium goes?
I'd appreciate it.
Old Oct 14, 2012, 02:39 AM
Dreamer
Joined Aug 2004
I'd appreciate it.
This is a different type of frame but the principle is the same. On the DJI or clone arms, the top of the arms are flat and the aluminium could go there ??
Old Oct 14, 2012, 02:54 AM
avt is offline
avt
avt
Hell Flyer
Israel
Joined Nov 2006
Thanks Mark. I will go look for some aluminium plates and see if that helps.
Old Oct 14, 2012, 03:13 AM
jseyfert3 is offline
Find More Posts by jseyfert3
Posted as eflightdude 06-07
United States, IL, Peoria
Joined Aug 2012
That was what I thought too, the foam isolates the vibrations but they'll just come right through the zip-tie.
jseyfert3 is offline Find More Posts by jseyfert3
Help! Yaw problem with HK KK Board V2.1, KK firmware 4.7 count74 Multirotor Talk 2 Jul 18, 2014 03:37 PM
Help! Major problems with HK KK Board V2.1. Thomasvijf Multirotor Talk 20 Sep 03, 2012 05:07 AM
Discussion HK KK V2.1 board not arming Woodchuck12 Multirotor Electronics 6 Aug 24, 2012 01:43 PM
Discussion HK KK V2.1 will NOT flash gibatron Multirotor Talk 43 Apr 27, 2012 08:36 AM
Discussion Hk kk v2.1 help jwalker590 Multirotor Talk 7 Mar 09, 2012 06:09 AM
