| Thread Tools |
| This thread is privately moderated by mikefromgermany, who may elect to delete unwanted replies. |
Double Horse 9116 Troubleshooting
Double Horse 9116 Troubleshooting ![]() Compiled from contributions by owners of the DH9116 RC helicopter and members of RC Groups Discussion Forums via the “Double horse 9116 Heli Thread" and "The new Double Horse 9116 Heli Thread" Dedicated to Mick, aka „Stormforce“, who did a fantastic job with his “Double Horse 9116 Technical Manual”, downloadable at http://customers.skymesh.net.au/~mat...ech_manual.pdf Thanks a bunch, Mick, you did a remarkable job tutoring new RC-pilots like me and making them understand their 9116 MUCH better! Rest in Peace, mate! -mike- aka “mikefromgermany” Let’s get started: You didn't listen to others or asked nobody before, got blinded by advertisements and well spoken promises and finally had been badly misled by the hobby-grade-look of this bird? (like me..) So you got yourself a 9116, dialed it in, flew it and now encountered problems or did a crash and broke something. As a beginner you have no clue where to begin. Maybe here’s something to solve it. Important: For all problems and solutions listed below it is required the heli was or is dialed in according to the "Double Horse 9116 Technical Manual" (link above) If you can’t find anything regarding your problem, feel free to ask at "The new Double Horse 9116 Heli Thread" FOD Frequently Occuring Damages TX doesn't bind You switched the heli on, the TX also, the beeping stopped but the red LED still is flashing instead of going solid? TX still doesn't bindWhen binding, make sure the throttle trim is set to neutral or it's lowest point and the throttle stick is at it's lowest point. Switch the tx off, plug in the battery, but don't switch it on. Then hold the tx in your left hand (assuming it's in mode 2) and hold the throttle down with your thumb, switch on the tx, then before it starts beeping, switch on the heli and quickly place it on a level surface, it should be bound when you hear the servo's flutter into life and align themselves with the settings in the tx programming. Tried everything above. Still nothing. PCB light flashes fast then slow and stays slow with no bind. Occuring sometimes after a hard crash or even as a DOA.Motors shut down when lift off?1. Have a closer look on the soldered connection bridge between main PCB and the Antenna PCB. In the pic it's the black block on lower right. If you smoothly increase throttle from zero the motors shut down? Then the reason is a too sensitive "motor overload protection system" - short: MOPS. The Heli doesn't stop turning clockwise, even with all trim applied with buttons1. Try bumping your throttle up quickly to around 30-50% to lift off, this bird needs no slow increase of throttle like a big CP heli. Your tail is overpowering the main motor's forces.The Heli doesn't stop turning counter-clockwise, even with all trim applied with buttons You encounter a lack of tail authority when trying to do a FFF banked right turn (clockwise). The motor can barely manage pushing the tail around. Your tail isn't even able to hold at all?Servo Horn bends and slides up the pushrod So your servo horns bend and slide up the pushrod? It mostly occurs on aileron servo (right hand side, looking from the tail). Broken main shaft # 9116-06First reheat the bent servo horn and straighten it (it will last until you get some spares). Crashed and broke one or both pins of the main shaft? No spare part? Bad vibrationsShorten the hollow pipe to 73mm (cut from upper side!), then After a crash you get bad vibrations spooling up, no visible damages?Check following parts: HOW-TO's Replacing the tail Take off the canopy and unplug the wires for the tail motor and the tail light from PCB (tail motor cable is blue/white, tail light cable is red/black)Replacing the main motor Take off the canopy, unclip the servo linkages on the swashplate (A), undo the retaining screw in the main gear (B), remove the complete rotor head assembly together with the hollow pipe and the main gear (C). Undo the 3 screws on each side on the base of the body (D) and remove the 2 supporting bars (E). Unclip the floor and remove it by expanding the body frame slightly.Improvements Some improvements you can do to correct some flaws in construction. Blade balancing It is always a good idea to balance the main blades. Reduces vibrations and wear and tear on bearings.Canopy SpacerA cheap balancing scale is pictured below. You balance the lighter blade with small pieces of tape. To fix the left servo horn touching the canopy, when the servo is at full throw forward. Canopy StickerCut 2 pieces of plastic 2mm strong, drill 3 holes in it (you will notice where if you look at the canopy holder) and use these as a spacer. It makes sense to patch some adhesive tape on a new new canopy where the flybar would hit it. I use a clear, glass-fibre reinforced tape for it - near to invisible and bears some beating from the flybar. It also prevents the flybar crashing through the canopy and smashing the PCB (the gyro especially).Servo Move Mod To fix the left servo horn touching the canopy, when the servo is at full throw forward, to fix the slide of servo horn up the pushrod and also to fix the excessive outward flexing of the servo arm. Tail Boom BumperYou'll find the instruction to do it in the tech-manual. The tail boom denting is caused by the flybar striking it. You will suffer these strikes when you're flying the bird too hard (sudden full stick movements in opposite directions) or crash with throttle applied. Main Blade Grip WashersSome people have put rubber or clear plastic hose over it to protect it, even wine cork. Makes better, direct steering performance, blades don’t wobble around any more but are still movable in the grip. Low Voltage BuzzerLeft picture: The washers for the main blade grip are stamped from 0,15mm thick plastic sheet – outer diameter 9mm, inner diameter 4,5mm. To get a decent warning before your battery runs down while your bird is 50 feet in the air and starts plunging towards the soil. MOPS Bypass ModInstall a Low Voltage Buzzer (~2-5 USD) under the bottom plate with double faced adhesive tape, it weights only 6 grams and it indicates per LED and sound if the voltage per cell is dropping below 3.6V. Plus: the balancer plug is secured.... As stated often enough before: Highly recommended! As stated above it prevents the sudden shut down of motors when throttling up. These blackouts occure sometimes in the air when you suddenly apply full throttle, too. The problem is reduced and passes over time as the motor got run in. You may also first break your new motor in before thinking of a bypass. FAQStill want to do it? Terms: What the hell are you talking about? Movements and terms:The heli leans to the right when hovering The heli leans to the right while hovering more or less motionless in the air - that's caused by the head-construction and pure physics. Don't try to compensate with weight on the left skid etc, this reduces only flight time and maxes tear n' wear.My range is less than the advertised 100m 100m range is reached only at the very best conditions, without any other 2.4 GHz noise, no obstacles etc. In reality you'll get 50-70m. To enhance reception do not direct the antenna to the bird, a 90° angle to the bird and parallel to ground would be best.What batteries I should buy for upgrade? Any 7.4V 2S 800 - 900 mAH 20C Lipo Battery with JST connector and JST-XH balancing plug with following dimensions will fit without modifications: 58 x 30 x 15mm, max weight 50gr.My well balanced 9116 starts to spin slightly clockwise as the battery goes down. It's normal that you have to retrim the rudder while flying when the batterie goes down. That's what the trim buttons are for.I can't save my settings like subtrims or throttle curves on the TX. Press MENU for 2 seconds - until the battery voltage is back on screen. All changes you do with the trim buttons are lost when switching the RX off.The servos jitter when powered up The servos should make a sudden short flutter or jitter on power up, as they may have moved when you powered down or the arms may have dropped during storage, so when you power up, they settle back to the position the tx has them set to by the user programming. However, if a servo make's a constant noise or the arms constantly move like they are vibrating (jitter) it is from an over excited step motor within the servo, which usually means the servo motor is on it's way out.How to check functionability of gyro?
How to balance the heli? To balance the heli, tie some string or sewing thread to the top of the main shaft above the blades and suspend the heli by the string. If the heli is bias one way or another, you must adjust the heli weight so it hangs level. This may require you to shift the position of the battery, or even add weight to the top of the battery or inside the nose of the canopy. Once the heli is balanced, you can step on to the swash-levelling procedure in Stormforce's Tech-Manual.My main/tail motor doesn't last long These motors are cheap, brushed and driven far beyond their construction limits. So don't expect them to last more than 50 flights in general. Sometimes even bad motors are sold that last for only 25 flights. Long hovering sessions will stress your motors even more, ending in even less flights per motor. They also burn out quick if are stalled throttled up. It is always a good idea to stock up 2 main motors and 3 tail assemblies, just in case. You may get more flights out of them when breaking every new motor in.How to break a new motor in? And why? When brushes are new, they do not completely touch the commutator. They wear into it, eventually getting a mirror-like finish over the complete contact surface. If you run these already overstressed motors under full power and load before the brushes were fully seated, the brushes got way too hot, and burn out the lubrication embedded within them. The edges of the brush keep breaking off, are uneven and jagged. |
Don |
Joined Jan 2013
newbie
hello, so im new to all of this but im catching on pretty quick. so far only problem i have is tx , when i want to roll to the right the heli does nothing. can someone tell me what i need to do please. i've read most all the posts on 9116 but have not found a fix. thxs curlyrocks
Was it DOA? Or worked it until now/crash/etc? Further questions/please ask as written above here regards -mike- |
| Thread Tools | |
| Question double horse 9116 need help with | EMCycle | Beginner Training Area (Heli-Electric) | 14 | Jan 10, 2013 04:05 PM |
| Question Turnigy 9x and Double Horse 9116 rudder problem | Doc Monty | Beginner Training Area (Heli-Electric) | 3 | May 16, 2012 10:44 PM |
| Question Starting with a new Double Horse 9116 | Scotticism101 | Beginner Training Area (Heli-Electric) | 3 | May 15, 2012 01:36 PM |
| Help! Double Horse 9116 | lordpaine | Beginner Training Area (Heli-Electric) | 7 | May 12, 2012 03:31 PM |
| Discussion 9116 Double Horse | Daza1964 | Beginner Training Area (Heli-Electric) | 1 | Mar 26, 2012 09:22 AM |
