Old Oct 13, 2012, 02:04 AM
KM.Racing is offline
Find More Posts by KM.Racing
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
Genesis Offshore Or Apparition-II ??!
hello guys please Vote For the Powerful Boat (speed , stability , performance)
Genesis Offshore Spec :
Length: 1045mm
Width: 245mm
Height: 115mm
Weight : 2.5kg
Motor: 36-74Size 2075kv Watercooled Brushless Inrunner
ESC: 100A watercooled (Required)
Drive system: 4mm
price: 192.5 USD
Apparition-II Offshore Spec :
Length: 800mm
Width: 240mm
Height: 120mm
Weight : 4kg
Motor: 2 x 380 2881kv Watercooled Brushless Inrunner
ESC: 70A watercooled (required)
price: 215.8 USD
KM.Racing is offline Find More Posts by KM.Racing
Old Oct 13, 2012, 06:16 AM
Norman2 is offline
Find More Posts by Norman2
Norman2
Norman2's Avatar
Connestee Falls, Brevard, North Carolina
Joined Mar 2006
Hi, I would personally go with the Genesis. It is a larger boat and single motor. The Apparition is
ok but with twin motors you will have to buy 2 ESC and it will be double trouble. I have an EKOS cat which I converted to single as I was having many problems with the twin set up.
Regards
Norman
PS: Plus the Genesis is a much better looking boat.
Norman2 is offline Find More Posts by Norman2
Old Oct 13, 2012, 06:21 AM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
Regards
Norman
nice thinking buddy you're 100% right
it's better looking and have 1 motor will reduce the mechanical problem
Old Oct 13, 2012, 03:37 PM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
The Genesis for sure.
But... The 100A ESC suggested is not big enough. It will burn out. Get a Turnigy 180A & run an X440/3 blade prop on that motor.
You will need the bigger ESC when you decide to upgrade the motor anyhow. And trust me, you will upgrade the motor one day.
We set one up at our club yesterday with one of my old Red Brick 200A ESC' s Everything was in the sweet spot. Temps, Revs & speed.
All the best.
Paul.
785boats is offline Find More Posts by 785boats
Old Oct 13, 2012, 04:09 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
All the best.
Paul.
heyy thanks man !
but I'm impressed !!! 180 A ESC !!!!!!!!! why you boaters prefer to increase ESC Amperes ? :P
Old Oct 13, 2012, 04:18 PM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
The main reason is that the motors will draw a lot of amps depending on the prop size. A higher rated ESC will handle those amp draws. A lower rated ESC will pop.
Although that motor is rated at about 80A I've measured 140A draw on mine.
The bigger the ESC the more margin you have for Amp spikes.
Cheers.
Paul.
Old Oct 14, 2012, 02:08 AM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
okayyy thank you bro for this caution
I'll work with it
Old Oct 14, 2012, 09:19 AM
Basstronics is offline
Find More Posts by Basstronics
United States, OH, Toledo
Joined Jun 2008
I cant say I was to impressed with the Genesis. Ran real nice STRAIGHT but couldnt corner at all.
I vote for something a bit wider.
Basstronics is offline Find More Posts by Basstronics
Old Oct 14, 2012, 01:26 PM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
That's strange.
It was the Apparition that I couldn't get to corner at speed without spinning out. The two Genesis at our club both corner well at full speed.
Bit it would be better if it was a couple of inches wider. as it can be a bit unstable in rough & windy conditions.
Old Oct 14, 2012, 01:35 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
That's strange.
thanks for your opinion buddy !
I've entered your blog and I'm impressed with your boats good work it really took hard to make these achievements ! wonderful
Old Oct 14, 2012, 06:41 PM
Joined Jun 2008
My running buddy had one with a castle 1515 2200kv 5s and it was fast going straight. Didnt corner the best (not at full speed at all) and with some wind it wasnt very stable.
Old Oct 16, 2012, 02:16 AM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Thanks Jad. I'm glad you like the boats. Time to sell a few off as I'm running out of room to keep them all.
Basstronics.
I must admit that the 2200kv motor on 5s would be a lot faster than the boats at our club which are running around 2000kv on 4s. So the cornering speeds are a bit slower here.
We must remember though, that even the full size cats of this type slow down for the corners,
Old Oct 17, 2012, 05:19 AM
Rnkeng is offline
Find More Posts by Rnkeng
Have setup my buddies new Genesis with stock motor, HobbyWing 120 ESC & stock prop running 2 4S 40C's in parallel. Measured 97 Amps RealTree V4 logger, speed 35 mph (GPS). Problems with unknown water leakage. Motor/ESC HOT. Have melted solder on 4mm motor bullet connectors. Full thread posting on RC Universe. http://www.rcuniverse.com/forum/m_99...m.htm#11257446
Rnkeng is offline Find More Posts by Rnkeng
Old Oct 19, 2012, 07:30 AM
viper1 is offline
Find More Posts by viper1
viper1's Avatar
Melbourne, Australia
Joined May 2006
For the unknown water leakage;
1) remove brackets and everything from the transom, and re-mount with some silicon in between.
2)Check the water cooling hull feed-through collar(s), some are not properly glued from factory.
3) put a piece of heat-shrink over the stuffing tube where it enters the strut. Like this guy did:
This is a well-known issue where the water gets pushed up in the tube.
This should help
For the overheating;
1)Pull the shaft and check if it runs free, re-lube.
2)Set the Genesis with the rear end flat on a table, set strut bottom even with bottom or a hair higher, I'll bet yours is too low.
This will increase your speed and run cooler.
viper1 is offline Find More Posts by viper1
Old Oct 20, 2012, 04:31 AM
Rnkeng is offline
Thanks much Viper. I knew about the shrink tube fix but didn't know or think about the strut height. Thanks again.
Discussion Apparition Twin Hull, Twin motor offshore boat Oblivion Racing Boats - Electric 107 Dec 30, 2014 09:53 AM
Discussion Mounting my lipos in a Apparition-II stalyoni Racing Boats - Electric 7 Jun 25, 2012 07:46 AM
Discussion Godspeed, Genesis, Apparition,HOR, which is the best cat hull wet banshee Racing Boats - Electric 3 Jun 03, 2012 09:43 AM
Discussion Genesis cat or Apparition now future project fighter cat Shannon87 Racing Boats - Electric 47 Feb 21, 2011 10:57 PM
Discussion 32" Offshore Cat "Apparition". 785boats Racing Boats - Electric 10 Oct 15, 2010 04:23 PM
