Old Oct 17, 2012, 09:53 PM
nkhamlue is offline
Find More Posts by nkhamlue
Build em lite......
Joined Apr 2012
Originally Posted by cwojcik View Post
I was really careful and used maybe 1/4 of a tube in my build.
Thank you very much......good information as it helps to quantify the expected amount weight attributed to glue.....appreciate your input. Would appreciate your further input as to your RTF weight and set up used. Thanks much......
nkhamlue is offline Find More Posts by nkhamlue
Old Oct 18, 2012, 04:08 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
That's probably close to my build also. I started with a tube that was already ~ 1/2 used and still a bunch left. It takes very little glue to make a joint stronger than foam. I run a small bead down the center of the foam and then spread it with a paint knife, it also removes any excess.
Azarr
Azarr is offline Find More Posts by Azarr
Old Oct 18, 2012, 04:13 AM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
Originally Posted by cardenflyer View Post
Only thing that really sticks out in my mind is the landing gear. Wish it wasn't extra with the original.
Originally Posted by hercdriver7777 View Post
I agree, which is one of the reasons we went with the new gear design on the Lite series.
There's no reason not to use the "X" type gear on the standard CY. I prefer mine without LG, but the guys over in indy have been adding the "X" gear using 1.5-2mm round CF rod.
The gear on the Lite CY is really holding up well, I gave it a major test yesterday doing a vertical figure 8, the bottom was just a little too close. The use of the vertical ply piece in the bottom of the fuselage is just a great idea and something I hadn't seen before. Not only does it give a tie off point, but it distributes the force from a hard "arrival" instead of concentrating it at the crossover point.
Azarr
Old Oct 18, 2012, 06:03 AM
David Kyjovsky is offline
Find More Posts by David Kyjovsky
David Kyjovsky's Avatar
Prague Ruzyne, Czechoslovakia (former)
Joined Jan 2003
Azarr
I believe that the 3x1 flat CF is ideal. Very strong for a normal landing, while able to flex back if the landing angle is very steep (aka crash). The optimal leg size for the CY is 18 to 19 cm.
David Kyjovsky is offline Find More Posts by David Kyjovsky
Old Oct 18, 2012, 06:06 AM
Joined Jan 2003
Is it possible for you to ask him about a 2mm prop adapter? That would allow using a motor like the Hacker A10-9L without having to machine a special shaft.
Azarr
Armin says sorry, no 2mm prop adapter...
Old Oct 18, 2012, 06:41 AM
nkhamlue is offline
Build em lite......
Joined Apr 2012
Azarr
Thanks for your input as well Azarr....much appreciated. The Twisted folks and the RC Factory people have come up with some great concepts in this Lite version. I would like to match their diligence and take pride in building Lite......
Old Oct 18, 2012, 06:44 AM
Nimbus Dave is offline
Find More Posts by Nimbus Dave
Joined Jan 2006
Well said....agree 100%. Good luck with the Lite build.....
Nimbus Dave is offline Find More Posts by Nimbus Dave
Old Oct 18, 2012, 07:07 AM
nkhamlue is offline
Build em lite......
Joined Apr 2012
Thanks David...good suggestion. Will give it a try.....
Old Oct 18, 2012, 07:55 AM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
I've had about three hard crashes on the gear, enough to break a prop, and no damage. The gear design is great.
cwojcik is offline Find More Posts by cwojcik
Old Oct 18, 2012, 08:16 AM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
As weight reduction is a significant feature of this new Lite version, was hoping for a more detailed/informative answer.....thank you for your reply.
With welders you wipe away all of the glue that does not actually go into the joint. So, I could have used three tubes or a quarter of a tube and ended up with the same amount of glue on the plane.
I was thinking that you were trying to figure out how many tubes to order.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Oct 18, 2012, 08:20 AM
Twisted Realm is offline
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
Good point Chris and nice tip, that's great way for removing unnecessary weight.
Twisted Realm is offline Find More Posts by Twisted Realm
Site Sponsor
Old Oct 18, 2012, 08:22 AM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
Video is here guys!
Crack Yak Lite (3 min 45 sec)
Old Oct 18, 2012, 08:28 AM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Nice flying Cody.
Awesome plane!
Pilot might have something to do with it too...
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Oct 18, 2012, 08:30 AM
nagayama13 is offline
Find More Posts by nagayama13
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
Awesome flight!
nagayama13 is offline Find More Posts by nagayama13
Old Oct 18, 2012, 08:41 AM
KamikazePilot is online now
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
Nice video Cody! Looks like you were having a lot of fun with this one.
KamikazePilot is online now Find More Posts by KamikazePilot
Discussion Twisted Hobbys Crack Pitts 12 Build and Info Thread! cwojcik 3D Foamies 3531 Today 06:49 PM
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6681 Jun 19, 2016 04:38 AM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
Sold Twisted Hobbies Crack Yak isenbed Aircraft - Electric - Airplanes (FS/W) 4 Apr 16, 2012 10:43 PM
