I wish that blond model would get out of the way so I could see the plane
Using kits to sell sex is just plane wrong ! |
Latest blog entry: The Ultimate Hobby shop "Orange...
The programming is actually quite easy. Flight condition one (non-vpp and to start up theesc): the power curve is linear, the pitch always at 100%. FC 2: (I have it selected by a switch): pitch curve linear (going with the throttle stick), power curve V shaped (throttle stick at 0%, power 100% - max reverse thrust, throttle stick 50%, power 50 to 60%, stick 100%, pwr at 100%). Hope it makes sense.. |
Vpp
First impressions (I am a vpp novice, so I can only comment on the performance of the system): the 9" blades are probably too much of a burden, performance with 8" blades is no worse and batt lasts longer... Blades much better balanced than they were in the same system I bought 3 yrs ago. 8" blades almost vibration free. Can't wait for more testing tomorrow.
I got a few flights on mine and wow is it impressive. I will weigh it tomorrow and see where it is, but in the air it feels just like a good depron airplane. I didn't think it was possible but I like it more than the standard Crack Yak.
It's not too floaty at all...in fact it flies very similar to the normal Crack Yak but with a much more pure response. The airplane it reminds me most of is Donatas' Sultimate. You can pull or push as hard and fast as you want and it will make perfectly square corners without losing energy or rolling out. It will float along like a butterfly if you pull the throttle back or whip around at silly speeds if you open it up. The light 2S system provides insane power. |
![]() We want to see someone we know on the sticks! |
Latest blog entry: Imac freestyle at pegasus 050313
| Thread Tools | |
| Discussion Twisted Hobbys Crack Pitts 12 Build and Info Thread! | cwojcik | 3D Foamies | 2863 | Today 05:19 PM |
| Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) | hercdriver7777 | 3D Foamies | 5807 | Today 04:57 PM |
| Wanted Twisted Hobbys - 32" Crack Yak Wanted | Moparbob | Aircraft - Electric - Airplanes (FS/W) | 32 | Jul 10, 2012 06:36 PM |
| Sold Twisted Hobbies Crack Yak | isenbed | Aircraft - Electric - Airplanes (FS/W) | 4 | Apr 16, 2012 10:43 PM |
