Old Oct 12, 2012, 04:29 PM
cpstout is offline
Find More Posts by cpstout
Joined Mar 2012
Mcpx problem - please help
Just learning to fly a cp helicopter. Things have been going well for a few weeks. Then I broke the main shaft. So I replaced it. Everything looks good. Controls seem to work. But here's the problem: when you give it the throttle, it wants to spin around in a circle. The tail rotor seems to be working. I can hold it in my hand, give it the throttle, & both main rotor & tail rotor are spinning. I don't know what else to do. I'm about ready to give up on flying. Anyone have any ideas?
cpstout is offline Find More Posts by cpstout
Old Oct 12, 2012, 05:25 PM
crazyflyer92 is offline
Find More Posts by crazyflyer92
United States, FL, Sunrise
Joined Oct 2012
i had the same problem i replaced the tail motor and boom and it went away.
jeff
crazyflyer92 is offline Find More Posts by crazyflyer92
Old Oct 13, 2012, 01:25 PM
cpstout is offline
Joined Mar 2012
I replaced the tail boom & motor & still the same problem. Not sure what to do now. I was hoping the more experienced people here could offer some help. Looks like 44 people looked at the post but offered no help. Maybe no one has ever had this problem. Does anyone know of a forum that helps with technical heli questions?
Old Oct 13, 2012, 03:17 PM
cpstout is offline
Joined Mar 2012
I found the answer to my problem at helifreaks.com. I'll just pass it on:
"I mean you may have too much positive pitch when you push the collective stick all the way up.
If you have too much positive pitch it can cause the main motor to pull too many amps, this can cause the tail motor to not get enough power to keep a good tail hold."
When I replaced the main shaft the head must have sat lower because of where the main gear was on the shaft & when I gave it the throttle it put too much positive pitch.
Never though of that!!!
Old Oct 13, 2012, 08:31 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Most would not of wanted to embarrass you by asking if you had rechecked the setup before trying to fly it after doing a major repair like replacing the shaft....
livonia bob is offline Find More Posts by livonia bob
Old Oct 14, 2012, 11:48 PM
Joined Oct 2012
i had that problem but when i was upside down i had to take a lot out and it fixed that
Help! A sensitive plea for help.... David A Ramsey Life, The Universe, and Politics 147 Jun 27, 2012 08:01 AM
Plea for help Wiebelhaus Off-road Cars 0 Oct 03, 2004 11:54 AM
Pleas help recommend charger TheTick Batteries and Chargers 23 Apr 29, 2004 04:06 PM
A Plea for Help The_Giver Humor 3 Aug 30, 2002 07:10 PM
RealFlight g2 Multiplayer pleas help Pablito Parkflyers 0 Apr 27, 2002 08:44 PM
