This thread is privately moderated by wingloada, who may elect to delete unwanted replies.
Old Oct 12, 2012, 04:13 PM
wingloada is offline
Find More Posts by wingloada
wingloada's Avatar
United States, MD, Lutherville-Timonium
Joined Apr 2012
Wooden fuselages
I have posted several design ideas for wooden fuselages to fit Jack Womack's Houston Hawk, Yardbird, and Bantam wings and tails. These fuselages are not official parts for the Houston Hawk, Yardbird, or Bantam and planes built with them need to be understood to be modifications and not true planes bearing Jack Womack's design names. They are just drawn up as options that can work as wooden versions for those wings and tail sets.
Here they all are. The revision date is listed on each plan. I have not built and tested some of these yet (I hope to soon) and I am not an engineer, just a modeler, so these are use at own risk drawings. There are photos at the bottom of the ones I have built.
Before printing be careful that the printer results with 100% scale at the bottom right of each drawing to confirm that you get 1:1 (1 inch on drawing equals one inch on printed page).
** My suggestion is that before printing, have the person doing the printing double check that the scale will be correct for their file+printer. Sometimes printers shrink or expand the drawing when printing. I have received a report of the Yardbird fuselage pdf printing at a result that was 68% of full scale. This may have been because I had too much on one page for the drawings so I have split the large drawings into two sheets, one that is the plan and the other that shows the profile and dimensions.
If reduction persists with these new files, I believe that you might be able to avoid that by setting the print percentage to the inverse of the resulting reduction (132% to compensate for a 68% reduction) or print directly from the dwg files with no reduction applied when printing, but that will require use of a CAD program at the printer. **
Fuselage for Yardbird wing (see photos at the bottom):
Updated: 10-20-12 -- Added a more accurate rendition of the airfoil which makes the top of the wing saddle area very slightly curved to match the bottom of the wing.
Updated: 12-22-12 -- Changes and modifications resulting from build of prototype fuselage.
pdf:
http://wkleinsasser.net/download/Yar...ge_WK_tail.pdf
pdf:
http://wkleinsasser.net/download/Yar...e_fuselage.pdf
(with tail similar to Jack Womack's original Yardbird)
drawing file with laser cut sheet:
http://wkleinsasser.net/download/Yar...e_fuselage.zip
Build log (begins around post 271):
http://www.rcgroups.com/forums/showt...691892&page=19
Electric fuselage for Yardbird wing:
pdf:
http://wkleinsasser.net/download/Yar...e_electric.pdf
Boom pod for Yardbird wing:
Updated: 11-25-12 -- Added layered drawing for a possible convertible glider-electric pod with detachable nose section. This is in the dwg folder at the link below. -- now includes cut sheet for the convertible pod.
Updated: 1-1-13 -- Changes and modifications resulting from build of prototype convertible pod.
pdf:
http://wkleinsasser.net/download/Yar...selage_pod.pdf
drawing file:
http://wkleinsasser.net/download/Yar...selage_Pod.zip
Convertible pod for Yardbird Wing (see photos at the bottom):
Updated: 1-19-13 -- Reflects modifications and changes after prototype build.
pdf:
http://wkleinsasser.net/download/Yar...pod-glider.pdf
http://wkleinsasser.net/download/Yar...d-electric.pdf
http://wkleinsasser.net/download/Yar...e_pod-main.pdf
http://wkleinsasser.net/download/Yar...d overlaid.pdf
Build log (work on pod begins around post 477):
Electric boom pod for Yardbird wing:
pdf:
http://wkleinsasser.net/download/Yar...d_electric.pdf
Adapter to fit Houston Hawk wings to Yardbird or similar top-mount fuselage (see photos at the bottom):
Updated: 10-21-12 -- Added a plot of the airfoil and a more accurate rendition of the airfoil which will fit with to the Yardbird's wing saddle area which is very slightly curved to match the bottom of the wing. Matched the HH root rib for the joiner rod and incidence pin.
Updated: 11-24-12 -- Redesigned reinforcement around joiner cavity.
pdf:
http://wkleinsasser.net/download/Yar...ng_adapter.pdf
Drawing file:
http://wkleinsasser.net/download/Yar...ng_adapter.zip
Fuselage for Houston Hawk wing:
pdf:
http://wkleinsasser.net/download/Str...ge_HH_tail.pdf
http://wkleinsasser.net/download/Str...th_HH_tail.zip
This contains some parts needed to build the Yardbird wing pod as well.
Boom pod for Houston Hawk wing:
pdf:
http://wkleinsasser.net/download/Str...selage_Pod.pdf
drawing file:
http://wkleinsasser.net/download/Str...selage_Pod.zip
Fuselage for Bantam 100" (smaller version of Yardbird) wing:
Updated 12-8-12 - Now matches all updates from the Yardbird fuselage.
pdf:
http://wkleinsasser.net/download/Ban...e_fuselage.pdf
wingloada is offline Find More Posts by wingloada
Wanted Dogan F3B fuselage or ThermiK-C Fuselage TB0384 Aircraft - Sailplanes (FS/W) 0 Oct 05, 2012 07:36 PM
Discussion Wooden Fuselage design prototype for 3 meter glider wingloada Sailplane Talk 5 Sep 30, 2012 01:37 AM
Discussion laminated fuselage decking/hatches - Fuselage built!! MCarlton The Builders Workshop 8 Sep 29, 2012 07:50 AM
Discussion Great old wooden yachts/WWI patrol craft Predreadnut Dock Talk 12 Mar 01, 2012 06:40 PM
Discussion Wooden fuselage vs Pod/Carbon Boom soholingo Hand Launch 39 Nov 10, 2008 01:03 AM
