Old Oct 12, 2012, 01:46 PM
Kassimdandago is offline
Find More Posts by Kassimdandago
Joined Feb 2012
Lithium iron and lithium iron phosphate batt.
A lifeo4 and life batteries bought 1yr ago, failed to supply power. On investigation it was found out that in any one of them a line of paralell has completely, short circuited and another line has completely, open circuted after attempting to charge them @ 2 amps. Before then they were intended to keep them, charged as they were not to be used for more than a year. The problem occured after bringing them out, from the lengthy storage to be used again. I wondered what went wrong. The manufacturers claimed that they could be stable atleast up to 5yrs.
Kassimdandago is offline Find More Posts by Kassimdandago
Old Oct 13, 2012, 07:02 AM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
Charging at 2 amps may have been the problem, Life should not be charged like a Lipo battery, too many amps depending on size of pack.
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old Oct 13, 2012, 07:09 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Not all LiFePO4 are created equal.
Years ago I used only LiFePO4 cells made by A123 Systems to power my electric aircraft and these were mostl 2300 mAk cells which I charged at 20Amps. routinely. I had one 3S pack that I flew 6 min. flights in a very powerful e Flite Mini Ultra Stick and recharged it in 6 minutes. I flew it over 500 flights and it still was delivering over 2000 mAh capacity per flight.
Charles
Old Oct 13, 2012, 07:27 AM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Many years ago Everydayflyer convinced me to use them...A123 in my powertools.
I fully charged them on a Cell Pro 4 charger. Some retained 90 % after 2 or 3 years of storage.
I NEVER trickle charged any battery except Lead acid. Then ony at 13.6 volts from a I C constant voltage regulators I made. I have 4 small mower batteries on constant 13.6 vdc trickle charge for years. Still checking out on a hygrometer at + 75 %.
Hi Charles.
Great to see you still helping others in battery land.
cyclops2 is offline Find More Posts by cyclops2
Old Oct 13, 2012, 07:34 AM
cyclops2 is offline
Joined Mar 2003
Forgot
I have a stick type vacuum cleaner I converted to small A123 cells.
Abuse ?? Extreme !! I runn that pack down to 10 to 15 % every time. That allows a whole house vacuuming. Been doing it for years. still at 90 % +-. It even balances. I did make the pack from cells vwith equal voltages.
They are a Timex in batteries.
Old Oct 13, 2012, 07:07 PM
jlloyd1995 is offline
Find More Posts by jlloyd1995
jlloyd1995's Avatar
United States, OR, Molalla
Joined Oct 2010
Trying to get some info on A123's. I have some brand new 2300 mah A123 battery packs that have been sitting for about 2 years at 6.6 volts. Is this healthy? What is a good storage voltage and does it matter? How low can I safely discharge them for cycling?
Thanks in advance!
jlloyd1995 is offline Find More Posts by jlloyd1995
Old Oct 13, 2012, 07:16 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Read up!!!
http://www.rcgroups.com/forums/showp...01&postcount=2
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Oct 13, 2012, 07:57 PM
jlloyd1995's Avatar
Joined Oct 2010
Thanks!
Old Oct 14, 2012, 08:02 AM
cyclops2 is offline
Joined Mar 2003
1995
I always fully charge & do a equalizing charge after each run down. The floor vaccuum cleaner wasrun down to 5 % this morning. Did a full ...Cell Pro 4... recharge & balancing. 100 %.
Cells read +- .01 volts after balancing & auto shutoff..........No other batteries can ever come close to that after 5 years of that deep of overdischarging EVERYTIME.
I store at maximum recharge voltage.
Discussion life (Lithium Iron Phosphate) hotlinercort High Performance 15 Oct 23, 2011 05:55 PM
Discussion Lithium Iron Phosphate - LiFe batteries jmpdgs Batteries and Chargers 8 Feb 22, 2010 03:11 PM
Sold Fromeco " IRON CORPS" 1200 MaH Lithuim Phosphate pack always flying Aircraft - Electric - Batteries & Chargers (FS/W) 1 Apr 29, 2009 04:43 PM
Sold Fromeco 1200mah Iron Corps lithium phosphate batteries Hammbone Aircraft - General - Miscellaneous (FS/W) 0 Apr 06, 2009 02:53 PM
