Old Oct 12, 2012, 08:51 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Will this work as an insulator?
After a recent experience of the motor getting so hot it the frame actually melted
I was constantly worried about my new frame meeting the same fate, it's already starting to warp. So i thought about getting larger washers to atleast spread the weight, but i couldn't find one small enough. Then i thought about paper washers, but figured they wouldn't be rigid enough to keep the plastic from buckling. Then i thought that the screws are going to get hot no matter what, why don't i just keep the heat away from the plastic.
So i got a box cutter made some small squares, then got my lighter and poked a hot needle through them to make the holes.
This should keep the screws from concentrating both heat and pressure in such a small area. The question is, do you guy think this will work?
I don't mind getting another frame, but i was expecting to change them after a few dozen hard landings.
PS: Excuse me, i accidentally touched the motor just now and i think i'm getting a blister.
PPS: Yeah, the skin's raising, this thing's really hot!
Hajile is online now Find More Posts by Hajile
Old Oct 12, 2012, 09:35 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
For similar circumstances, I made a mounting plate from a piece of flat CF. It fit over the end of the motor with holes for the pinion and mounting screws. It spreads the load better. It may require some shaping to fit the area it will be used in, so Dremel tools are needed.
Balr14 is offline Find More Posts by Balr14
Old Oct 12, 2012, 09:40 AM
Pigs dont fly is offline
Find More Posts by Pigs dont fly
How high does it go?..duh
Pigs dont fly's Avatar
Currently in...UK
Joined Jun 2004
I'd say 'no' as its plastic, and low melting point plastic that is supposed to melt so it can form the packets its made from. Perhaps get some PCB board material (glass fiber) and make a plate up, think about getting a heat sink for the motor, and perhaps checking the motor temp before flying one battery directly after another.
Pigs dont fly is offline Find More Posts by Pigs dont fly
Old Oct 12, 2012, 10:02 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
That amount of heat seems excessive. I would be interested in learning why.
Old Oct 12, 2012, 10:10 AM
Joined Jul 2012
I can probably file one out of old circuitboards, but it's too thick.
And no, i don't even fly for more than a couple of minutes at a time now, much less two batteries. Just fly three or four circuits around the room, land, unplug, wait several minutes before flying again.
I'd also like to know. As you can tell, the teeth aren't pressed right up against the main gear so there shouldn't be any strain on the motor.
Maybe next time i'll check if it can actually light a match after a quick flight. I don't have carbon fiber sheets, nor do i know where to get one. But i think i may be able to use a metal snipper and cut some sheets off old milk can lids.
I'm actually considering cutting my losses, selling this, and getting a MasterCP instead. Atleast that one has a vented motor.
Old Oct 12, 2012, 11:04 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
You may just need a new motor, or have faulty connections; causing arcing. It looks like a Walkera mini CP or Genius, which really needs a brushless motor.
Old Oct 12, 2012, 11:35 AM
Joined Jul 2012
I do have a brushless motor for it actually (A C05m). But i've burned out my second ESC. The walkera ESC apparently can't even pull enough power from the battery to start the motor so you need to give it a push. Which means you have the ESC beeping for a couple of seconds while you manually start the rotor spinning. I've given up on it (If there's anybody in the Philippines near Alabang or Laguna, you're welcome to buy the motor, just get an ESC that pulls more than 10a). I could have bought six brushed motors for the price of the brushless kit.
Question as a 3rd plane, will this work? or am i asking for failure? bm2thirsty Electric Plane Talk 29 Jul 31, 2012 02:36 PM
Help! Will this motor work with this plane? YellowSnow Beginner Training Area (Fuel) 9 Jun 30, 2012 11:48 PM
Discussion Will this work as a motor mount? Nightstone Foamies (Scratchbuilt) 12 Jun 11, 2012 08:19 PM
Discussion Can THIS motor work with THIS plane? If not-can you show me an ARF that will work? zdsweet Electric Plane Talk 2 Jul 24, 2009 09:44 PM
Discussion Will an eflite 2.4GHz transmitter work as a buddy box? Unterhausen Radios 2 May 09, 2007 03:20 PM
