Closed Thread
This thread is privately moderated by TheFernMan, who may elect to delete unwanted replies.
Old Oct 12, 2012, 08:03 AM
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Trader Rating: 6
PreOrder for FLASHED HobbkyKing F-30A ESCs with latest SimonK with bootloader enabled
20x HobbyKing F-30A @ $17 each
14x HobbyKing F-30A @ $17 each
10x HobbyKing F-30A @ $17 each
7x HobbyKing F-30A @ $17 each
I will be receiving some F-30A 30 amps from HobbyKing during the third week of October. If you like to receive a set, PM me for Pre-Order. I will be shipping them out fast as soon as they're ready. Usually the same day! Place your orders now to make sure you get your flashed ESCs! These ESCs are well known for its great multirotor performance and quality!
"Standard ESCs are actually not designed for multirotor applications. They are programmed to increase and decrease the throttle command towards the motor in a gentle way. The reason for this is quite obvious. Imagine a motor accelerating and decelerating so abruptly in a helicopter or car... it would damage the gears and reductions in no time. In a multirotor application, we really want just the opposite. The goal is to change the motor speed, and thus the thrust, as fast as possible to achieve a perfectly stable platform.
While the current ESCs used in most multrotor applications work considerably well, there is a lot of room for improvement. Using the same ESC, but loading it with dedicated optimized software, will increase the handling and stability of your multirotor greatly.
We call this RapidESC: converting your regular lazy ESC into a high speed capable speed controller at no extra cost, ready for multirotor applications."
These are one of the best types of ESCs for the SimonK firmware. Read first post here
All N-Fet:
"The ESCs which use only N-channel FETs have the advantage of lower resistance, less losses and hence more efficiency."*
External Oscillator:
"An external oscillator may supply a more consistent timing signal and steadier motor speeds" "but the internal rc oscillator ones will drift quite a bit based on temperature."*
HobbyKing F-30A Tested and flashed with the latest SimonK with bootloader enabled so you can flash them in the future thought the servo cable with the USB linker from HobbyKing. I cut a little flap out and use clear tape to cover the opening. You can barely tell.
Selling them for $17 each ESC plus shipping US shipping only.
If you're interested send me a PM so I get proper shipping with your address. I'll be doing USPS shipping. It's $6.
Any question feel free to ask.
References:
What is RapidEsc (Simonk firmware)
All N-Fet Design
External Oscillators
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 12, 2012, 10:58 AM
(My english is Bad - Sorry)
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Trader Rating: 9
Why don't you ship to canada...?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Oct 12, 2012, 02:34 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Trader Rating: 9
Well... after asking he can do it..
Old Oct 13, 2012, 09:42 AM
Joined Mar 2012
Trader Rating: 0
you still got any laying around?..... i need 6 shipped to ny
edykosta is offline Find More Posts by edykosta
Old Oct 13, 2012, 09:52 AM
TheFernMan's Avatar
Joined Jul 2012
Trader Rating: 6
Still not available till the week of October 22. If you want to guarantee your set let me know.
Old Oct 14, 2012, 06:43 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Trader Rating: 9
TheFernMan,
Can you give me the square size of the ESC ..?
Old Oct 14, 2012, 08:29 AM
TheFernMan's Avatar
Joined Jul 2012
Trader Rating: 6
Originally Posted by Dialfonzo View Post
TheFernMan,
As per HobbyKing:
Size: 54 x 26 11mm
Old Oct 14, 2012, 08:34 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Trader Rating: 9
Originally Posted by TheFernMan View Post
As per HobbyKing:
Size: 54 x 26 11mm
And are they the REAL size.
Old Oct 14, 2012, 08:39 AM
TheFernMan's Avatar
Joined Jul 2012
Trader Rating: 6
I can measure one tomorrow
I left one at work. But yea it really close to those measurements.
Old Oct 14, 2012, 08:54 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Trader Rating: 9
It's not that important i will see once i have them.
I was trying to model them to know if they will fit in the frame.
Old Oct 16, 2012, 01:49 PM
TheFernMan's Avatar
Joined Jul 2012
Trader Rating: 6
all sold for now... Thanks again guys!
Closed Thread
Sold FLASHED HobbkyKing F-20A ESCs with lastest 2012-09-30 SimonK with bootloader enabled TheFernMan Aircraft - Electric - Multirotor (FS/W) 6 Oct 09, 2012 05:41 PM
Sold FLASHED HobbkyKing F-20A ESCs with lastest 2012-09-30 SimonK with bootloader enabled TheFernMan Aircraft - Electric - Multirotor (FS/W) 4 Oct 06, 2012 11:52 AM
Sold FLASHED HobbkyKing F-30A ESCs with SimonK with bootloader enabled TheFernMan Aircraft - Electric - Multirotor (FS/W) 0 Oct 03, 2012 08:50 AM
Sold HobbkyKing 30A ESCs with SimonK with bootloader enabled TheFernMan Aircraft - Electric - Multirotor (FS/W) 27 Sep 29, 2012 01:03 PM
Sold FLASHED HobbkyKing F-30A ESCs with SimonK with bootloader enabled TheFernMan Aircraft - Electric - Multirotor (FS/W) 7 Sep 28, 2012 08:48 PM
