Old Oct 12, 2012, 07:14 AM
Jayray123 is offline
Find More Posts by Jayray123
OUCH!!!
Jayray123's Avatar
United States, PA, Erie
Joined Sep 2008
K&a a-10
I am about halfway thru the build on one of these that was given to me by a friend. Feels good to build a kit again. It comes with 45 mm fans running on brushed motors. According to the booklet, it flew on 45 watts. I am looking for a modern set of fans that will give in the area of 150 to 200 watts on 2s 1000's or 3s 800s. On 2 s that makes it roughtly 10-12 amps, or 3s and 8 amps. I could probably make 50mm fans fit, but it would look a little better with 40's. The kit has vac formed nacelles so I have to incorporate the fans into them.
BTW, the instructions have you glue the fan housings directly to a piece of 3/32 balsa on edge, with a little bit of tri stock in the corners. The other end gets glued to the fuse. Gives an idea how little power an old brushed small setup made.
Anyone have any ideas to fans/motors?
Jay
Jayray123 is offline Find More Posts by Jayray123
Old Oct 12, 2012, 01:27 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You might want to re-post this here--
http://www.rcgroups.com/micro-edf-je...r-systems-650/
I don't think you will find much help on micro or mini fans here.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 12, 2012, 03:00 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
I have a K&A A10 I started a few years back..never finished.but I have 2 KP44 fans in mine..more thrust than needed..I may try 2 Kyosho 45mm fans as i have thoses also..I will post some pics of it later
turbonut is online now Find More Posts by turbonut
For Sale 1/10 Scale 1980 Chevy K-10 Pickup Stamp Cars - Cars and Parts (FS/W) 0 Apr 22, 2009 11:27 PM
Anyone seen the Mini A-10 made by K&A? Acer Electric Ducted Fan Jet Talk 13 Mar 23, 2006 11:41 PM
Just Finshed my K&A Mini A-10 WortHog Lv2Fly Electric Ducted Fan Jet Talk 5 Dec 26, 2001 01:00 AM
K&A Mini A-10 kepople Electric Ducted Fan Jet Talk 5 Jul 17, 2001 12:34 AM
K&A A-10 Flies! Clydewinder Electric Ducted Fan Jet Talk 5 May 22, 2001 09:49 PM
