I generally use low temp hot melt glue for servos, as it allows me to remove them with a hot air gun. I've just finished my first all-Foam Tac build (a Mako) and had absolutely no problem with melting foam (or anything else). The Mako instructions warn about not using too much Foam Tac. Very impressed with Foam Tac and will be using it much more in my Depron and MPF builds. Just about to start my fifth Polaris (not counting the XL, Mini and AquaCats). |
Latest blog entry: Polaris Aileron Pushrods
Howell N.J
Joined Apr 2001
Foam Tac
Sorry you had a problem with the Foam-Tac. This is only the second time I have been told about this happening. I can tell you that the other person that had a problem glued in a spar then covered it with tape while still wet, in this case the glue did not get enough ventilation and the guy filled the slot with alot of glue. This should not happen with either blue label or the newer version of Foam-Tac. One thing to remember with Foam-Tac is a little goes a long way, when I glue in servos I put a bead of glue on the servo, push it in place and then pull apart, I leave apart for about 20 to 30 seconds then push it back, this gives the solvent time to evaporate. As for fillets I don't have any experience using Foam-Tac for this purpose, I will give it a try and get back to you. We are working on a Foam-Tac filler for this purpose it will be out soon. Eric The Deacon of Beacon |
Zr and eg:
I just goofed with FT in the way eg described. Too much, used to span a gap, used wax paper between the join and the weight I used to immobilize it. I will be first in line for a FT filler. Gorilla/pu glue is just too chancey. I may have flubbed (fixable) with FT, but I screwed up 2 wings completely with pu glue and had to trash them. |
Grand Rapids, MI
Joined Jun 2005
Eric, is the neck of the new bottle thicker than the other one? The screw on tip isn't going on straight & tight. It looks like the inner lip of the tip isnt going inside the neck. Unless I just got an odd bottle...
Can post a pic if that doesn't make any sense
United States, MI, Oxford Charter Township
Joined Dec 2012
Mike |
| Thread Tools | |
| Contest Foam-Tac Contest | Eric Giorgiantonio | 2012 NEAT Fair | 88 | Jan 19, 2013 12:26 PM |
| Contest Foam-Tac Works on wood | Eric Giorgiantonio | 2012 NEAT Fair | 2 | Dec 28, 2012 12:04 PM |
| Discussion Is my Beacon Foam-Tac ruined/ too old to use | StewieRC | Foamies (Scratchbuilt) | 1 | May 22, 2012 12:43 PM |
| Discussion Beacon Foam-Tac EPP hinges | squishy654 | Foamies (Scratchbuilt) | 14 | Apr 06, 2011 06:11 AM |
