Old Feb 15, 2013, 07:47 PM
Brner is online now
Find More Posts by Brner
Just Me
United States, OR, Salem
Joined Apr 2006
Lockey,
Probably not the best place to post this but I've found that epoxy mixed with a liberal amount of micro balloons is pretty easy to sand when laminating foam parts as you show above. Each to his own....lol
Brner is online now Find More Posts by Brner
Old Feb 15, 2013, 07:56 PM
Lockey is offline
Find More Posts by Lockey
Tony Audsley Retired Locksmith
Lockey's Avatar
Australia, WA, Perth
Joined Sep 2011
Originally Posted by Brner View Post
Lockey,
Whoops .... sorry if I have derailed this thread, I will shut up now until I receive my Foam-Tac glue and I will try it and let you know what I think to it
Lockey
Lockey is offline Find More Posts by Lockey
Old Feb 15, 2013, 09:26 PM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
If you're using just the tiny bit that it takes to do the trick, like with laminating, then the layer is so thin sanding isn't really a terribly difficult thing. I did some tests on fan fold foam for that purpose. If you use a big pile of glue then it can get rubbery and difficult to sand flush without rolling up in balls like rubber cement.
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Feb 16, 2013, 10:00 AM
dr.E is offline
Find More Posts by dr.E
Don't cut the Yellow Wire
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
Lockey,
Why not mix the microballoons with foamtac........ Some guys mix water soulble polyurethane WPU with light splackling compoundsands well and its flexible.....
Foamtac will have its new filling compound out for demo at the Wram Show... Sofaman will demonstate it at the booth...
dr.E is offline Find More Posts by dr.E
Old Feb 16, 2013, 12:47 PM
Brner is online now
Just Me
Joined Apr 2006
Originally Posted by dr.E View Post
Why not mix the microballoons with foamtac.........
Haven't tried that yet, but will give it a go.
Some guys mix water soulble polyurethane WPU with light splackling compoundsands well and its flexible......
I do that for a filling compound and it works great. I also add microballoons or light spackle with carpenters glue for filling balsa with very good results.
And a mix of WBPU (Minwax) with acrylic paints seems to help adhesion to foam some.
Now, back to the contest.........
Old Feb 16, 2013, 12:49 PM
meanbaby is offline
Find More Posts by meanbaby
meanbaby's Avatar
United States, PA, Mt Pocono
Joined Jul 2007
Originally Posted by Lockey View Post
Thank you Eric, I did find your product in the US at http://www.rcfoam.com/product_info.p...ca266c7620af1e
I have dealt with these people before and they are very efficient, so I have ordered 4 bottles and they are already on their way to me by UPS
By the way … do you have any tips for storing this? … also, can it be used for gluing CF rod/tube into a wing? Or should I stay with using epoxy glue for this?
Lockey
PS. How does it sand?
making a channel with solder pen for carbon fiber rod using foam tac and mpf (4 min 59 sec)
Hope this helps
Pete
meanbaby is offline Find More Posts by meanbaby
Old Feb 16, 2013, 04:44 PM
roo_ster is offline
Find More Posts by roo_ster
Standing Athwart History
roo_ster's Avatar
United States, TX, Dallas
Joined Mar 2011
New Filler Questions:
Will it be more like lightweight spackle or Gorilla glue?
Will it have adhesive strength like FT or just filler properties?
I would like a filling adhesive that adhered like crazy, filled what you wanted and then...stopped. No crazy foaming action need apply. Oh, light weight would be nice, too.
roo_ster is offline Find More Posts by roo_ster
Old Feb 16, 2013, 05:45 PM
dr.E is offline
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
It is Foamtac Based and thick as waffle batter....Its everything you have asked for and more.....
I'll be demonstrating it at the WRAM Show
Old Feb 16, 2013, 06:51 PM
Lockey is offline
Lockey's Avatar
Joined Sep 2011
Thank for the video Pete, I will be trying that when I get my Foam-Tac
By the way Eric, how will I know if I have got the NEW or the OLD version? and what is the difference?
Lockey
Old Feb 16, 2013, 06:58 PM
roo_ster is offline
roo_ster's Avatar
Joined Mar 2011
Hot dog!
Old Feb 16, 2013, 09:17 PM
rcrich is online now
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
new build
I just finished this bird with Foam tac and a small amount of hot glue!
rcrich is online now Find More Posts by rcrich
Old Feb 17, 2013, 04:23 AM
Eric Giorgiantonio is offline
Find More Posts by Eric Giorgiantonio
Howell N.J
Joined Apr 2001
Foam Tac
Lockey
Hi Buddy,
The "old" version has a purple label while the new has light blue label, and no matter because the old version works well just takes a little longer to dry. I wouldn't worry about it.
Eric
Eric Giorgiantonio is offline Find More Posts by Eric Giorgiantonio
Old Feb 17, 2013, 09:22 AM
Pavelow is offline
Find More Posts by Pavelow
Pavelow's Avatar
United States, FL, Mary Esther
Joined Jun 2008
Great minds think alike, rcrich. I just started cutting a modified Sumo to look like an angry bird. Any chance to get a photo of your wing shape?
Pavelow is offline Find More Posts by Pavelow
Old Feb 17, 2013, 02:07 PM
RPM314 is online now
Find More Posts by RPM314
Tailless fly-hard
RPM314's Avatar
United States, NY, Brooklyn
Joined Apr 2012
Here's my entry. Polaris constructed with depron. 3M77 for lamination, hot glue in critical areas, and foam-tac for everything else.
RPM314 is online now Find More Posts by RPM314
Old Feb 17, 2013, 04:35 PM
Howell N.J
Joined Apr 2001
Foam Tac
Very nice Polaris, let us know how the maiden flight goes. You are entered and good luck.
Regards
Eric
The deacon of Beacon
Contest Foam-Tac Contest Eric Giorgiantonio 2012 NEAT Fair 88 Jan 19, 2013 12:26 PM
Contest Foam-Tac Works on wood Eric Giorgiantonio 2012 NEAT Fair 2 Dec 28, 2012 12:04 PM
Discussion Is my Beacon Foam-Tac ruined/ too old to use StewieRC Foamies (Scratchbuilt) 1 May 22, 2012 12:43 PM
Discussion Beacon Foam-Tac EPP hinges squishy654 Foamies (Scratchbuilt) 14 Apr 06, 2011 06:11 AM
