Old Nov 02, 2012, 05:33 PM
Don't cut the Yellow Wire
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
Originally Posted by Raften View Post
"misrepresent the false information", Geeze Pete I am not in the habit of giving the third degree to someone I know and trust. Are you?
.Thirty minutes ago I put dabs of FT on two pieces of $tree, spread it out to cover both surfaces and pressed them together. I know that is not how the directions say to use it as I didn't let it air dry. But you know what, the $tree is now mushy. Makes me wonder if it was really Welders that was used or that the kid didn't read the directions well enough. I'll contact him this evening.
If you don't use a product according to MFG instructions you have no argument.....
dr.E is offline Find More Posts by dr.E
Old Nov 02, 2012, 05:44 PM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
All I can say is that WMPF and Foam-Tac go great together!
aircontrol is offline Find More Posts by aircontrol
Old Nov 02, 2012, 05:49 PM
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
WOW that mini mako looks awesome!!!!!
rcrich is offline Find More Posts by rcrich
Old Nov 02, 2012, 05:56 PM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Glue and planes are thoroughly tested!
Mini Mako Wall Test (1 min 38 sec)
Old Nov 02, 2012, 06:20 PM
NorCal
Joined Dec 2009
Who made an argument. I give up on this, I have done just fine with other products.
Raften is offline Find More Posts by Raften
Old Nov 02, 2012, 07:32 PM
Howell N.J
Joined Apr 2001
Wow
https://vimeo.com/51316236
Wow!! So that's what they mean when they say "Sticking the Landing"
Holy Cow, BTW you didn't happen to glue the Mini Mako to the side of the building with Foam-Tac did you??? (I know shameless plug) couldn't help myself.
All kidding aside awesome planes and awesome flying, and you are entered in the monthly contest.
Regards
Eric
Beacon adhesives
Eric Giorgiantonio is online now Find More Posts by Eric Giorgiantonio
Old Nov 04, 2012, 04:16 AM
Howell N.J
Joined Apr 2001
Foam Tac contest Update
the Foam-Tac contest winners will be announced after Election Day, that's next week, so you still have time to get in on this month's contest, Winner will be announced the day after the Elections, so get to "Sticken and Clicken" and don't forget about Beacons' Foam-Tac web site we would like for you to post there also, Yes, it will increase your chances of winning...
Thanks and Good Luck
Eric
Beacon Adhesives
Old Nov 04, 2012, 04:57 AM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Eric
Beacon Adhesives
Where is the Foam-Tac wed site, can you give us a link?
Old Nov 04, 2012, 08:05 AM
meanbaby's Avatar
brooklyn,ny
Joined Jul 2007
www.foam-tac.com
-pete
meanbaby is offline Find More Posts by meanbaby
Old Nov 04, 2012, 09:37 AM
Standing Athwart History
roo_ster's Avatar
United States, TX, Dallas
Joined Mar 2011
Point of fact...the original poster, a beacon rep, advises using foam tac in a means othe than that described in the instructions.
roo_ster is offline Find More Posts by roo_ster
Old Nov 05, 2012, 06:22 AM
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
This comes from the FoamTac Site (I don't see any difference in what the reps said vs the instructions that are on the web)
http://www.foam-tac.com/home.aspx
Helpful Hints / Directions
HELPFUL HINTS
• Less is more! Apply a thin line of Foam-Tac to surfaces; add more only if needed.
• Foam-Tac's bond "welds" foam together for making invisible butt-joints & seams. Once cured, bond is stronger than the foam itself.
• Great for reattaching broken ailerons.
• Won't glue fingers together - not a cyanoacrylate.
• Never leaves any residue on surfaces.
DIRECTIONS
• All surfaces must be clean, dry, and free of dust and grease.
• Remove white cap & save for storage. Screw on applicator tip & snip.
• Apply a thin layer of glue to each side of materials to be joined.
• Wait a few seconds and then firmly press parts together and immediately separate for 4-5 seconds more. Rejoin parts, firmly pressing surfaces together for a permanent bond.
• Allow to dry for 20-30 minutes for a strong bond with a full cure within 24 hours or less.
• ALWAYS REPLACE THE FLAT WHITE CAP AFTER EACH USE TO KEEP GLUE FROM THICKENING
Foam-Tac Usage.mp4 (1 min 14 sec)
Old_Foam-Tac.mov (2 min 36 sec)
Old Nov 05, 2012, 06:58 AM
Aerogeezer
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I have three tubes of the original Foam Tac and a partial left. The instructions on the card say to "put Foam Tac on both pieces and allow to air dry for 10 -20 minutes then join together." I ended up with a misaligned fuselage because their was no adjustment time and the parts stuck immediately and would not pull apart. I posted this a page or two back and got a reply that you don't need to let it set 10 - 20. Then why is it in the instructions on the card? That question was not answered. I like Foam Tac and will follow the revised instructions. It just would have nice to have had better instructions from the start. I am guessing that the first batch sold to Radical RC that has the new formula but on the old purple card still has the 10 - 20 minute instructions also.
Rickochet is offline Find More Posts by Rickochet
roo_ster's Avatar
Joined Mar 2011
HELPFUL HINTS
DIRECTIONS
http://www.youtube.com/watch?v=rqctR...ayer_embedded#!
http://www.youtube.com/watch?v=XhW8k...layer_embedded
'Taint what is on the card of the Foam-Tac I bought. Looking at it right here in my hot little hand.
I am not saying it is not the best thing since sliced bread. I do;t know that, as I have yet to use it. Just no need to be obnoxious toward those who are using it off-card...since folks who claim to be from the manuf are also suggesting it be used in a means outside that which is prescribed on the material that comes with the product.
Old Nov 05, 2012, 07:02 AM
roo_ster's Avatar
Joined Mar 2011
Another question on usage:
How about joining/laminating sheets of FFF/blucor for, say, a KFm airfoil? Is it better than Gorilla glue for that, which foams up and fills voids?
Old Nov 05, 2012, 10:16 AM
Medicinal Foam User
Wilfor's Avatar
150 mile house B.C. Canada
Joined Jan 2010
Almost every glue i use has different ways to be used and most are not whats printed on the bottle . I use elmers Rubber cement like the foam tac instruction you posted . Sometimes i put GG in a container with water and let it foam before applying . It can be hard to write all the ways to use something on a little package . Experimenting with scraps is something we should all learn and remember to do .
Wilfor is offline Find More Posts by Wilfor
Contest Foam-Tac Contest Eric Giorgiantonio 2012 NEAT Fair 88 Jan 19, 2013 12:26 PM
Contest Foam-Tac Works on wood Eric Giorgiantonio 2012 NEAT Fair 2 Dec 28, 2012 12:04 PM
Discussion Is my Beacon Foam-Tac ruined/ too old to use StewieRC Foamies (Scratchbuilt) 1 May 22, 2012 12:43 PM
Discussion Beacon Foam-Tac EPP hinges squishy654 Foamies (Scratchbuilt) 14 Apr 06, 2011 06:11 AM
