Old Nov 14, 2012, 02:34 PM
John Walter is offline
Find More Posts by John Walter
John Walter's Avatar
USA, IL, Naperville
Joined Feb 2003
If you want built-in casters. Try these:
http://www.reliablehardware.com/tiltcasters.aspx
John Walter is offline Find More Posts by John Walter
Old Dec 16, 2012, 11:24 PM
joesoar is offline
Find More Posts by joesoar
joesoar's Avatar
Honolulu, HI , United States
Joined May 2000
Progress...
I contacted Sportube and they were kind enough to send me just a top for the cost of the shipping.
So, I created a "Supertube" consisting of two top halves, with a 24" section of the old, damaged "bottom" half riveted into a shortened top section. Since the top section of the Sportube is considerably stronger than the bottom half, this should be a much better setup than before (sans wheels).
Then, I made a Coroplast box (6mm) which fits like a sleeve inside and both tops close all the way, protecting the box.
Now, I just have to figure out how to place my wings and fuselages in the box with some foam.
Thanks for the inspiration...
Photos below...
joesoar is offline Find More Posts by joesoar
Old Mar 10, 2016, 02:38 PM
David Olson is offline
Find More Posts by David Olson
MCS / NCSS / SVSS / LSC / SAM
David Olson's Avatar
United States, CA, Santa Rosa
Joined Jun 2010
Originally Posted by FLY F3B View Post
Check this out. I am moving from Sportube to this with a coroplast box built inside.
http://www.dakine.com/p/bags/ski-bag...ncourse-double
Mike,
They offer your bag, the Dakine Concourse Double Ski Bag in 2 sizes: 185 cm (72.8") and 200cm (78.7").
Did you get the 185cm size?
Dave
David Olson is offline Find More Posts by David Olson
Old Mar 10, 2016, 03:13 PM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
I use the 185 cm size. It is plenty big.
Tom
Kiesling is online now Find More Posts by Kiesling
Old Mar 10, 2016, 03:20 PM
Joined Jun 2010
Thanks Tom. I will order one now.
Old Mar 10, 2016, 03:32 PM
webbsolution is offline
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
I dont see the value in the Sport tube approach - you risk it all to save a couple hundred bucks.
Here is my take on this - you can try and claim your item is ski - Smowboards and then they will throw them like they are skis and snowboards... i see this every trip... you save some money for sure but risk broken models that are 5 x the cost of the savings. I saw this in Martin with the US guys at the J WC - lots of serious damage. I saw it in South Africa... and I saw it in Turkey...
Then TSA scans your bag and sees that its not been inspected, does NOT contain what is posted and you have Mr Fat fingers inspecting your gear in your absence AND closing what is often a precarious packing job that requires a higher IQ than 60 to complete. Again we have an awesome opportunity for crunches and carbon shards..
I know transport costs for oversize and weight are high but not compared to busted gear...
webbsolution is offline Find More Posts by webbsolution
Old Mar 10, 2016, 03:50 PM
San Diego
Joined Aug 2004
Dave,
The TSA doesn't care what is in the ski bag. They treat it just like any other bag. They will inspect your non ski bag oversize box the same way they'll inspect my ski bag. Put a good coroplast box inside the ski bag or sport tube, pack well, and you save yourself over $300 per trip in oversize charges if traveling in the states. The only time I've seen issues with damage is when people use a sport tube without an interior box.
The other option is to ship in advance. You run the same risk of rough handling and lost bags and generally pay more.
I see no reason not to take advantage of the airline's policies for ski bags.
FWIW
Tom
Old Mar 16, 2016, 04:39 AM
Pisaneli is offline
Find More Posts by Pisaneli
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Hi guys
What about Lithium-based Batteries shipment restrictions?
Do you declare them at check-in? What is your experience?
Gorazd
Pisaneli is offline Find More Posts by Pisaneli
Old Mar 16, 2016, 05:00 AM
Joined Jun 2010
Originally Posted by Pisaneli View Post
Hi guys
Gorazd
AMA has produced a very good video regarding this subject.....
http://www.modelaviation.com/lipo2
FAQ of FAA - PDF.
Old Mar 16, 2016, 05:40 AM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Thanks David
Very informative.
Old Mar 16, 2016, 10:51 AM
Joined Jul 2007
For what its worth -
On my last three trips - American airlines, United and Air Canada asked me about specific battery types - "are you checking in Lithium Polymer" batteries - I am flying with Life and Lithium Ion which is a different chemistry type. So I tell them I a not checking Lithium Polymer batteries.
I walk my planes to TSA and watch (facilitate) the inspection. If they ask me what kind of battery is in the plane I tell them Lithium Iron phosphate. or Tell them if its really a liPo that its taped off and isolated. I have never been asked to remove or discard a battery yet but the airline industry is prone to hysteria...so it could still happen.
Old Mar 18, 2016, 08:04 AM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Batteries are becoming a real problem. Theoretically I cannot see much difference between a plane or a camera or a laptop having Li-xx battery. But in reality we transport our planes as large sports equipment and they draw special attention in check-in.
I have been travelling with coroplast box that is closed with fiberglass tape. Not a big issue for me but it is another thing if the staff starts to inspect my box on their own... Fortunately it has never happened although the questions about batteries are bocoming almost routine.
Transporting batteries in cabin should be ok.
Tuomo is offline Find More Posts by Tuomo
Old Mar 18, 2016, 02:14 PM
Bmwjoon is online now
Find More Posts by Bmwjoon
United States, NJ, Nutley
Joined Mar 2015
These might seem expensive but do folks use ATA cases like these?
http://www.casesbysource.com/product...se-al7007-0403
They vary in price from like 500-1500 !
Bmwjoon is online now Find More Posts by Bmwjoon
Old Mar 18, 2016, 09:03 PM
Joined Jul 2007
no - you can build a much more functional case that is lighter and holds more models for half that price including some power tools.
Help! Heng long tank distance control problem Othor11 RC Tanks 16 Jan 20, 2013 05:05 PM
Discussion Methods of transporting Multicopters on a plane/long distance slidins15 Multirotor Talk 4 Aug 21, 2012 08:22 AM
Discussion Med/long distance objects fuzzy TheNiceGuy FPV Talk 12 Aug 08, 2012 08:04 AM
Question Is Hitec Freedom 9s a good receiver for long distance? easystarfpv4 Electric Plane Talk 16 Jul 02, 2012 12:23 PM
Discussion Newbie Long Distance Flying Question HoosierGuy Sailplane Talk 7 May 09, 2012 06:39 PM
