Old Oct 14, 2012, 01:36 AM
webbsolution is offline
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
Originally Posted by joesoar View Post
Great suggestions.... I like the Coroplast idea!
@ JT: Fedex Ground for a Sportube between CA->HI = $240, HI->CA = $120
However, if I go the Coroplast way, how do I get around the "80" linear dimension" limitation (length+width+height)? Currently, there is no limitation if is a Sportube, as it classifies as "Sporting Equipment" (snowskis in winter, waterskis in summer
Joe
American airlines, United, Alaska, Lufthansa and British airways and air canada are all at 102-105 linear inches so a 76 inch long box by 16wx16h works out perfectly for most. You can fit 7 planes in a box that size and still be under 50 lbs if you use the 10mm coroplast.
I have been using the coroplast and bulkheads and it looks like my box was dropped by fedex from a significant height on the trip back from the WSM. One fuse fin got a tiny dimple. The extruded edges of the box were damaged, the auluminium bent but the planes survived.
Coroplast rocks -
webbsolution is offline Find More Posts by webbsolution
Old Oct 14, 2012, 01:43 AM
joesoar is offline
Find More Posts by joesoar
joesoar's Avatar
Honolulu, HI , United States
Joined May 2000
When you get a chance, can you post some photos of the Coroplast box?
Thanks!
Joe
joesoar is offline Find More Posts by joesoar
Old Oct 14, 2012, 11:10 AM
Joined Jul 2007
Thanks!
Joe
Sure here are two designes I did. One has a traditional hinge (piano hinge) which I am not a fan of but never failed me. That box has 90 degree plastic extruded molding on the top of the lid and 90 degree aluminium on all other corners. The extra extrusions add a lot of weight but this box with 5 planes is still under 50 lbs.
The second one was made differently and I like it a lot more. I dremmelled out the seam on the inside of the 10mm coroplast so I could get a 90 degree fold along the bottom of the entire box. The virtical 4 pieces of extruded plastic are riveted the corners through the coroplast and into small section of extra aluminium 90 degree corner material.
The top is an extruded aluminium 3/8 inch 90 with an extra channel which accepts the lid that slides on. CHeck otu the product details here on that piece because its an essential portion.
http://www.tchweb.com/tchstore/produ...ble-Angle.html
The value of this slide on lid is several. 1) The box is much stronger from a side load scenario than with a traditional lid. 2) It makes for a lighter case with far less hardware and there are no clasps or latches to stick out and tear off. 3) you can put a virtial flute down the middle and create a box that you can stand on and not crush a model. So stacking luggae is no threat at all.
I have attached a picture of the fuse shelf - fuses are retained with a thich section of carbaord tube which has holes for the tow hook and two on the sides for heavy zap straps. The fuses cant slide around at all. When they tip the box on its end nothing can move. The stab box has the stabs taped inside them and is sandwhiched by the fin shelf shelf that covers that stab box and retains the tips and fuses from moving.
Old Oct 14, 2012, 01:02 PM
joesoar is offline
joesoar's Avatar
Joined May 2000
Great box... Very nice. Thank you for all the details.
I think I will do something similar, but sized to fit inside a Dakine ski bag - best of both worlds!
Joe
Old Oct 14, 2012, 03:21 PM
Joined Jul 2007
Joe
I also have a coroplast insert for my sport tube that allows a single x2 3.4 or 4.0 but im not sure if the fin would survive so I have not used it yet.
Old Oct 14, 2012, 05:19 PM
John Walter is offline
Find More Posts by John Walter
John Walter's Avatar
USA, IL, Naperville
Joined Feb 2003
Here is my build thread from 2008.
http://www.rcgroups.com/forums/showthread.php?t=876781
This may be larger than you need, but it's easy to adjust the dimensions.
John Walter is offline Find More Posts by John Walter
Old Oct 22, 2012, 01:52 AM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Originally Posted by stefanoc2 View Post
Tuomo,
do you use 10mm coroplast or are you able to find 8mm?
Stefano
Sorry, I was away... Travelling - without models
We use 5mm material. It is actually not Coroplast, it is Vikuprop. Just different brand name. Material is 100% same.
There is no need for thicker than 5mm material. Our boxes have survived so many flights that I am not worried anymore. When packed and closed by tape they are strong enough to sit on, although I would not recommend sitting in the middle if you are a big an, ends are ok.
The idea of a Coroplast box is to make it from one piece material without any hinges etc. Just fold, glue and tape. This gives lightest and strongest result. However, 8mm or 10mm material is very difficult to fold. I think you cannot use thicker than 5mm without special tools, and even that takes some practice and helping hands.
I do not have any internals in the box. I lay down wing in the bottom as webbsolution. Then I have bubble plastic and clothes that I need. On top I lay the fuselages with a layer of something soft - packing material or clothes. To other end I pack my tools in soft pouch. Ballast rods are taped to bottom corner of the box.
Tuomo is offline Find More Posts by Tuomo
Old Oct 22, 2012, 02:12 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
This is what my latest box looked like when it was new. Now it is very worn out.
This box is barely wide enough for 3 planes (wings limit). I made it little higher since I anticipated the new higher rudders. In practise the extra height is not needed but if I need, I can transportsome wing parts flat beween main wing packing and fuselages.
I suggest you to make the box nice and tight. Allow some room for the xtra stuff and clother you might need. By doing this you can avoid having separate luggage - I fly often without any extra fee. If you ned a bigger box one, a new one costs just 30-40e.
Old Nov 11, 2012, 02:37 AM
AUSELECTRIC is offline
Find More Posts by AUSELECTRIC
Joined Nov 2004
I have started on this box today. It is made from an aluminum composite and hope to keep it at arround 9Kg 1600x600x400
AUSELECTRIC is offline Find More Posts by AUSELECTRIC
Old Nov 11, 2012, 10:41 PM
USA, IL, Naperville
Joined Feb 2003
1600mm long. I assume this is for F3K because F3J, F3B, and F3F planes won't fit.
Old Nov 11, 2012, 10:58 PM
Joined Nov 2004
It has been built specifically for a trip to NZ in December with a number of 1.2m and 1.6m gliders and wings, but it will fit my double carbon faser fuse (that will eventually have a 3 piece wing)
Old Nov 11, 2012, 11:47 PM
joesoar is offline
joesoar's Avatar
Joined May 2000
I was able to obtain a second Sportube top only as well. Will try to make a "Supertube" by using two top halves with a modified bottom half to hold it all together. Then, Coroplast box inside.... Well, thats the plan at least...
Thanks again for all the suggestions, photos and construction advice!
Joe
Old Nov 12, 2012, 06:54 PM
Joined Nov 2004
After trying to save weight on the box I ordered some really heavy wheels that are to big.
I had been searching for recessed castors, much like on suit cases. Found what looked ok online but on arrival the are over 600g each
Old Nov 12, 2012, 08:27 PM
joesoar is offline
joesoar's Avatar
Joined May 2000
Auselectric,
How about a set of wheels with an axle that you can order from Sportube for $25? They are just the right size and not heavy. Look under replacement parts / Sportube III.
Joe
Old Nov 12, 2012, 09:27 PM
Joined Jul 2007
wheels plus baggage ramps...= velocity
velocity+fixed objects = broken parts
detachable wheels - better solution.
You have to remember that we are building these boxes for the worst scenarios - baggage handlers who toss them onto a ramp which may be a full story high...
I was at an airport this morning and I watched a guy pickup his Pelican case which was actually broken! He said it was in perfect shape before he handed to air Canada.
Help! Heng long tank distance control problem Othor11 RC Tanks 16 Jan 20, 2013 05:05 PM
Discussion Methods of transporting Multicopters on a plane/long distance slidins15 Multirotor Talk 4 Aug 21, 2012 08:22 AM
Discussion Med/long distance objects fuzzy TheNiceGuy FPV Talk 12 Aug 08, 2012 08:04 AM
Question Is Hitec Freedom 9s a good receiver for long distance? easystarfpv4 Electric Plane Talk 16 Jul 02, 2012 12:23 PM
Discussion Newbie Long Distance Flying Question HoosierGuy Sailplane Talk 7 May 09, 2012 06:39 PM
