Old Oct 12, 2012, 03:28 AM
joesoar is online now
Find More Posts by joesoar
joesoar's Avatar
Honolulu, HI , United States
Joined May 2000
Long Distance Sailplane Transportation
Looking for sources of boxes into which I can fit two Open Class sailplanes.
I have been using a Sportube for the past 10 years, but abandoning this after repeated & recent damage to my planes.
Anyone know of and/or using airline approved boxes? (I think the limit is 80" in length).
Would be interested in manufacturers/models/pricing/etc.
Thanks in advance,
Joe
joesoar is online now Find More Posts by joesoar
Old Oct 12, 2012, 05:42 AM
luvF3b is offline
Find More Posts by luvF3b
launch high, go fast
luvF3b's Avatar
Australia, TAS, Devonport
Joined May 2008
Ask us Aussies :-) we travel the world with models.
My Mate Steve has seen his box thrown from a 737 cargo door onto the tarmac. Ouch, it damaged the wing tips. Another mate, with a black sportube had his model left on the tarmac in 50 deg heat in Dubai.... The wings puffed like popcorn :-(
Apart from sportube, I have taken models overseas in 2 ways without problems:
1. Custom made cardboard box within a box with foam between the layers. Model supported by bulkheads within the inner box, or
2. Custom made box with aluminum extrusion edges and hard plastic sides made from a coroplast type material. Again, the model parts are supported by bulkheads ( these were the boxes that Cobra sailplanes were exported from the UK to Australia in back in the '90's)
Another solution I have seen is a simple coroplast box with models packed in plenty of bubble wrap ( Joe W can maybe provide more detail)
The secrets are:
A. Strong enough that luggage packed on top will not crush the box
B. "crumple zones" so that a dropped box from 6m from a cargo door on an airliner either deforms the box (eg the cardboard box in option 1) or has some sort of energy absorbing capability within the box ( eg a hard case with foam and bulk heads inside) the insides must have energy absorbing material at each end eg foam, or bulkhead where the parts are flexibly fixed to them.
Weight is also a consideration - the coroplast solution works well, cheap, disposable and energy absorbing. To my mind, the sportube does not allow enough support inside. Drop it and the parts inside move and smash into the ends.
Cheers,
John
luvF3b is offline Find More Posts by luvF3b
Last edited by luvF3b; Oct 12, 2012 at 05:45 AM. Reason: Typos by trying to do this on a bloomin iPhone:-)
Old Oct 12, 2012, 06:09 AM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
I fly all the time with coroplast box. It is strong enough and very nice to handle. And best of all, you can easily make a custom boxes that fit your needs.
Just remember to use enough padding inside to prevent fuses moving. I use mostly spare clothing. Weight of the box with 3 F3J planes, most inportant tools, clothing etc is about 15kg.
Tuomo is offline Find More Posts by Tuomo
Old Oct 12, 2012, 07:04 AM
jtlsf5 is online now
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Stick with the Sportube and ship FedEx. My experience is that TSA is more responsible than the airlines for damage when unpacking/repacking, as they have no concern for what is inside the box they rifle through and will just cram stuff back in. I've had to make claims on TSA the last 3 times I took planes on a flight with me, now just ship in advance and build the delivery time into the trip.
JT
jtlsf5 is online now Find More Posts by jtlsf5
Old Oct 12, 2012, 08:50 AM
stefanoc2 is offline
Find More Posts by stefanoc2
stefanoc2's Avatar
United States, TX, Houston
Joined Aug 2006
Tuomo,
do you use 10mm coroplast or are you able to find 8mm?
Stefano
stefanoc2 is offline Find More Posts by stefanoc2
Old Oct 12, 2012, 01:06 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Check this out. I am moving from Sportube to this with a coroplast box built inside.
http://www.dakine.com/p/bags/ski-bag...ncourse-double
FLY F3B is offline Find More Posts by FLY F3B
Old Oct 12, 2012, 02:06 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
I took a couple of aeroplanes to Austria this summer and used one of these - http://images.peliproducts.co.uk/3dcases/1770/1770.html
I also use these at work they offer real peace of mind when tranporting valuable and / or expensive kit.
Shedofdread is offline Find More Posts by Shedofdread
Old Oct 12, 2012, 02:45 PM
janne savolainen is offline
Find More Posts by janne savolainen
Finland, Klaukkala
Joined Sep 2011
Peli cases are way too heavy....
janne savolainen is offline Find More Posts by janne savolainen
Old Oct 12, 2012, 04:31 PM
Frank S is offline
Find More Posts by Frank S
sewing machine thumb
United States, CA, Palo Alto
Joined Jul 2001
That's an interesting thought. I already have one of those.
Frank S is offline Find More Posts by Frank S
Old Oct 12, 2012, 04:38 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
Tom Kiesling and Oleg have these. Really cool way to go. They are considered Ski bags, so tell the counter agent that there are skiis in there and you are in like Flynn.
M
Old Oct 12, 2012, 06:51 PM
joesoar's Avatar
Joined May 2000
Great suggestions.... I like the Coroplast idea!
@ JT: Fedex Ground for a Sportube between CA->HI = $240, HI->CA = $120
However, if I go the Coroplast way, how do I get around the "80" linear dimension" limitation (length+width+height)? Currently, there is no limitation if is a Sportube, as it classifies as "Sporting Equipment" (snowskis in winter, waterskis in summer
Joe
Old Oct 13, 2012, 02:04 AM
Tommy Wee is offline
Find More Posts by Tommy Wee
Tampere, Finland
Joined Oct 2009
Janne Savolainen makes nice boxes, I have one and have been very satisfied with it. Sturdy and empty weight is reasonable.
Mine is black but next one will be some other colour, it becomes a bit too hot in the field. In Finland ok, but there seems to be warmer climates
Just bought me a 4m Xplorer2, I need to have another box (longer...).
Here is the link to Janne's firm, he is a professional box maker:
http://www.js-case.fi/Lennokit_en.htm
Tommy
Tommy Wee is offline Find More Posts by Tommy Wee
Old Oct 13, 2012, 03:56 AM
joesoar's Avatar
Joined May 2000
Great - thank you!
Joe
Old Oct 13, 2012, 07:29 AM
Daryl Perkins is offline
Find More Posts by Daryl Perkins
Daryl Perkins's Avatar
United States, VA, Falls Church
Joined Mar 2007
Joe, the DaKine bag is classified the same as a Sporttube by the airlines. It's a ski bag. Bob M and TK brought their models to SA in them.
Bob built himself a gorgeous and lighweight wood box that fit perfectly inside it. He flew Icon 2's and an Explorer. The I2 has a 72" center panel. I think he brought 3 of them.
Tom had a rather ghetto coroplast and tape job that was just as functional...
D
Daryl Perkins is offline Find More Posts by Daryl Perkins
Old Oct 13, 2012, 02:48 PM
joesoar's Avatar
Joined May 2000
Hmmm... Sounds interesting...
I was also thinking of taking two Sportube top halves, shorten one a bit and make a "Supertube" out of it, as the bottom half always has gotten damaged (thinner plastic).
Will check out the dimensions of the Dakine bag... Ideally trying to fit a Maxa 4 and an AVA (dang bent wings). Maybe have to modify the wings to flatten out during transportation.
Thanks again!
Joe
Help! Heng long tank distance control problem Othor11 RC Tanks 16 Jan 20, 2013 06:05 PM
Discussion Methods of transporting Multicopters on a plane/long distance slidins15 Multirotor Talk 4 Aug 21, 2012 09:22 AM
Discussion Med/long distance objects fuzzy TheNiceGuy FPV Talk 12 Aug 08, 2012 09:04 AM
Question Is Hitec Freedom 9s a good receiver for long distance? easystarfpv4 Electric Plane Talk 16 Jul 02, 2012 01:23 PM
Discussion Newbie Long Distance Flying Question HoosierGuy Sailplane Talk 7 May 09, 2012 07:39 PM
