Old Oct 11, 2012, 09:41 PM
spstimie is offline
Find More Posts by spstimie
Joined Oct 2012
Question
First Heli...Dumb Questions(DH9116)
I just ordered a DH 9116 ($50shipped couldn't resist). Battery is charging as we speak. Am I supposed to tighten the main blades? Didn't say in the manual, but it seems weird to me and I think it might be missing something.
spstimie is offline Find More Posts by spstimie
Old Oct 11, 2012, 10:00 PM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
see how it flies with the blades loose... kind of hard to advise without seeing how loose they are in person. I'll tell you this, there should be no up and down play at the base of the blade, where it screws into the blade grip. But they need to be loose enough (moving side to side) so that they straighten themselves out when you spool up.
Also, try to tighten each side about the same.
finguz is offline Find More Posts by finguz
Old Oct 11, 2012, 10:05 PM
spstimie is offline
Joined Oct 2012
Thanks.
Old Oct 12, 2012, 06:16 AM
Angrydad is offline
Find More Posts by Angrydad
Australia, WA, Mandurah
Joined Apr 2012
I don't think you can make the blades overly tight on the 9116, from memory? Don't quote me though, my memory these days isn't all that good! Just be a bit careful you don't over-tighten and bust the blade grips is all I'm saying...
I replaced a couple of sets on mine and don't remember ever getting them anywhere near tight
Angrydad is offline Find More Posts by Angrydad
Old Oct 12, 2012, 09:05 AM
Balr14 is online now
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
On any FP heli, the blades should be loose enough that you can push them sideways with gentle pressure. They have to be able to seek their own balance point, but not be so loose they flop around.
Balr14 is online now Find More Posts by Balr14
Old Oct 13, 2012, 11:21 PM
spstimie is offline
Joined Oct 2012
no up and down play, but they move side to side smooth. Went out and hopped around a bit friday night. crashed a few times. held up well. Reading through RADD's training write ups.
it didn't pitch forward very well, but side to side and back were good. Guess we will see if i like this enough to spend some real money on a heli. it is definitely more difficult than my fathers blade quad. I was hovering that after 10 minutes.
Old Oct 14, 2012, 01:53 AM
finguz is offline
finguz's Avatar
Joined Mar 2012
maybe there is some setting up you have to do to it to get better forward cyclic. Maybe your swashplate isn't level.
Old Oct 14, 2012, 07:58 PM
spstimie is offline
Joined Oct 2012
The swash plate is not level. I am reading as much as I can about learning to fly and tuning the helicopter.
Old Oct 14, 2012, 10:01 PM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Helicopters are more of a tinkerers hobby than about flying it seems. How many hours of maintenance does it take on average to achieve an hour (that would be about five flights) of flight time.
Hajile is online now Find More Posts by Hajile
Old Oct 14, 2012, 10:23 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
They can fly for 50-100 flights without much maintenance besides checking screws and a couple drops of oil if they are not landed hard (or crashed of course). That's for clones with inexpensive bearings and gears/belts Better quality helis could conceivably run double or triple that I guess. I don't have any better quality helis myself.
eagle777 is offline Find More Posts by eagle777
Old Oct 14, 2012, 11:17 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
My 5 year old Hirobo Quark has had about 2 hours of maintenance in total.
Old Oct 15, 2012, 12:13 AM
spstimie is offline
Joined Oct 2012
Ok, so trying to adjust pitch tonight. If I pitch straight back the right servo doesn't move. straight back is about 5 o'clock on the stick. If I pitch straight Right the left servo doesn't move. Right is about 2 o'clock on the stick. Any thoughts? I know BALR has mentioned the PCB is an issue with these. Is this adjustable?
Old Oct 15, 2012, 07:08 AM
Brutus1967 is offline
Find More Posts by Brutus1967
The Netherlands
Joined Nov 2009
Since I keep track of that:
Pure preventive maintenance: 15 to 30 minutes per 10 hours of flight, approximately, for fuel powered helicopters. It is a bit depending on whether there is a fuselage that takes extra time when doing maintenance.
Electric helicopters are usually a lot less time consuming, say 5 to 10 minutes per 10 hours of flight
That goes more or less for all types, unless you are doing hardcore 3D with it. Usually hardcore 3D does not require maintenance, it will typically need repair before it is due for maintenance....
Time needed for repairs is completely depending on your flying skills, your mechanical skill and the quality of the helicopter.
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Oct 22, 2012, 01:50 AM
spstimie is offline
Joined Oct 2012
I was only able to fly this a couple times when I first got it. First flight, I hit a cement stair case from 20" up and crashed it a few times in the grass.
Last time I flew it(2nd flight), prior to adjusting the swash, I was up in my loft trying to hover. It got going toward the stairs. I shut it down and it slid down the stairs. 16 stairs and no worse for wear. The DH9116 is pretty tough for the cost.
Did I mention I am not a great rc helicopter pilot?
Adjusting the swash maybe took five minutes.
Finally got in three flights this afternoon after I adjusted the swash(still not perfect but better). All in the house. By the third flight I was hovering okay and keeping it in the air for most of the battery. Once I get a little more control I can take it to work. We have an empty warehouse where I have taken my rc drift car.
Discussion Motor Question - Probably a dumb one! Rightfly Electric Plane Talk 3 Sep 06, 2012 11:36 AM
Whoops! Did Something Dumb… Plus I have a Question Piper J3 Sailplane Talk 26 Sep 05, 2012 08:43 AM
Help! Really dumb question oacilamaf Beginner Training Area (Heli-Electric) 4 Aug 26, 2012 04:48 AM
Discussion Dumb pusher prop question kc2pxp Electric Plane Talk 48 Aug 01, 2012 03:50 PM
Discussion First heli build. Main gear question faheja Electric Heli Talk 2 Apr 05, 2012 10:53 PM
