Old Feb 05, 2013, 09:00 AM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Originally Posted by rcflyer4333 View Post
Aw man But im sure you'll make a real nice fuselage and this plane, like all your others will turn out great!!
The ONLY way you can succeed at this hobby is you must be able to change course in mid stride in order to make a plane fly better and what I have learned from my EMB-120 is its simply toooooo heavy!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Foam Safe Spray paint!
Old Mar 07, 2013, 12:26 PM
nopistn is offline
Find More Posts by nopistn
Joined Apr 2008
Originally Posted by demondriver View Post
I've hit a Brick wall made of Cardboard Lol The cardboad tube is simply TOOO heavy, I'm going to fashion a foam fuselage instead.
And the solution isn't just to "put a bigger motor on it"?
nopistn is offline Find More Posts by nopistn
Old Mar 07, 2013, 03:08 PM
Up-Out-&-Gone
Joined Mar 2007
Lol funny! . . .no sadly in this case that woln't work, I have to substatue a foam fuselage instead of a cardboard one for this these 145 and my 120, I'm having my friend SilverFox CNC 4" diameter foam fuse cross sections for me so I can use those instead.
The trick in using a cardboard tube for your Airliners fuse is you need to find one that's light enough, and there are plenty, but sadly not for this bird.
Old Mar 08, 2013, 03:39 PM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
Good call with the foam cross sections DD, you'll never look back! Just make sure whatever glue you use is sandable, otherwise the seams will show through the covering. I used Foam-Tac when I built my 717, but would probably use 3M77 if I were to do it again.
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Mar 08, 2013, 04:17 PM
Up-Out-&-Gone
Joined Mar 2007
That's precisely what I'm gonna do Rocket!, Only difference is the tail & nose section will still be fiberglass.
Looking good Sir!
Old Apr 12, 2013, 10:47 PM
Up-Out-&-Gone
Joined Mar 2007
My ERJ-145 have been Saved!
I Had The CNC master SilverFox router-out a Bunch of new Foam fuselage cross sections to replace the heavy Cardboard tubes, These will be stacked & epoxied and have one 3mm carbon fiber Rod link all the pieces. this new foam fuselage will be 1/4th the weight of the carboard tube.
The twin 145 build Is BACK!
Old Apr 12, 2013, 11:00 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
I Want One Sooooooo Bad! .. but i have planes to finish
*sulks and Walks Away *
Keenan smith is offline Find More Posts by Keenan smith
Old Apr 12, 2013, 11:19 PM
Up-Out-&-Gone
Joined Mar 2007
" Sulks and Walks Away-then trips & falls down the staircase of his London Flat & lands on his feet" all the while he was eating a bag a crisps Lol
Old Apr 13, 2013, 12:43 AM
Joined Dec 2010
Lol...
Old Apr 23, 2013, 01:08 PM
nopistn is offline
Joined Apr 2008
sweet, now it just takes one less foam block to build a 135!
I bet the foam will be stronger and easier to repair in case of crash as well.
Old Apr 23, 2013, 01:23 PM
Up-Out-&-Gone
Joined Mar 2007
Yes indeed Sir!, The problem with the Old 4" cardboard fuselage was the wall of the cardboard .I.E. the thickness was to thick & heavy, so I had to resort to using foam instead.
I will also use this foam fuse on the EMB-120
Old Apr 27, 2013, 03:43 AM
Up-Out-&-Gone
Joined Mar 2007
Here is the BA & Luxair 145's together with their new foam fuselages, after Nall I will attack these babies with Gusto!
Old May 25, 2013, 11:35 AM
nopistn is offline
Joined Apr 2008
In case you need some erj inspiration. ..
Old May 25, 2013, 11:48 AM
Up-Out-&-Gone
Joined Mar 2007
Great Photo Sir, Nice 777!
Yeah I just wished I had a few extra minuets these days to give to my 2 145's I'm working on some Customers Orders this month.
Old May 25, 2013, 06:15 PM
nopistn is offline
Joined Apr 2008
Nice 777? Doesn't the xr winglet look more bad ass?
Anyway, I hope to get one of these awesome flying models from you someday.
Build Log Embraer ERJ-145 build jdlilfan RC Airliners (Commercial, Cargo, Troop Carrier) 220 Jun 14, 2014 04:28 AM
Build Log Erj-145 rmackelvey Foamies (Scratchbuilt) 67 Apr 07, 2012 07:35 PM
Discussion Project - ERJ-145 XR FANMAN Electric Ducted Fan Jet Talk 61 Jul 26, 2008 07:42 PM
For Sale Airplane model ERJ-145 modelplane Non R/C Items (FS/W) 3 Oct 16, 2005 10:31 AM
Need Info on Bombardier CRJ200 and Embraer ERJ-145 Regecide Life, The Universe, and Politics 0 Oct 15, 2003 09:17 PM
