Old Dec 14, 2012, 09:02 AM
jdlilfan is online now
Find More Posts by jdlilfan
jdlilfan's Avatar
United States, IN, Indianapolis
Joined Mar 2010
Agreed! The spoilers and reversers don't help a lot on the actual aircraft. Performance at our airline is predicated without it. In most of our daily ops we aren't allowed to use them. Brakes are cheaper to burn up compared to fuel and engine maintenance.
jdlilfan is online now Find More Posts by jdlilfan
Old Dec 14, 2012, 02:46 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Originally Posted by nopistn View Post
The speed brakes dont even work that well on the real thing at lower speeds. You can really feel the difference at 320kts, but below 250 the gear/flaps do a better job of actually slowing the airplane down.
Yup! gears & flaps will always bleed 25% of your forward speed.
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Dec 14, 2012, 02:48 PM
Up-Out-&-Gone
Joined Mar 2007
JD I guess you guys land on Nice Long runways not to have to use reversers Huh? But I would bet landing on a smaller 5000 or less runway you've gotta deploy those reversers & air-brakes.
Old Dec 14, 2012, 02:52 PM
Hollywood2979 is offline
Find More Posts by Hollywood2979
Hollywood2979's Avatar
United States, TX, Cibolo
Joined Nov 2011
DD, Just curious, how much does your glass parts way, i'm thinking about possibly doing one in the near future but will probably use a preperg fiberglas to keep weight down, nose, tailcone and nacelles.
Hollywood2979 is offline Find More Posts by Hollywood2979
Old Dec 14, 2012, 03:02 PM
jdlilfan's Avatar
Joined Mar 2010
Spoilers automatically deploy with thrust levers idle and wheelspeed above 25kts. Yeah, we cant really use reverse unless shorter than 7,000ft. And then we can only use idle. Company policy. Landing flaps 45 at 43,000 lbs should only use about 3,500 ft of runway without reverse.
Old Dec 14, 2012, 04:10 PM
Up-Out-&-Gone
Joined Mar 2007
I hope these Photos show how light both the Fiberglass Nose and tail are together . . .VERY light Indeed.
I'm hoping for a flying weight from 1.8lbs to 2.1 lbs Tops!
Old Dec 14, 2012, 04:13 PM
Up-Out-&-Gone
Joined Mar 2007
I see. . . .3,500 feet man thats a short runway, I remember flight training in a Piper Cherokee 180 how fast a 3,500 foot runway ran out . . .. .Pretty darn quick Lol
Old Dec 14, 2012, 11:08 PM
nopistn is offline
Find More Posts by nopistn
Joined Apr 2008
Haha, I'm guessing you're at eagle... yalls company policies are a little differant. We pop the buckets on every landing... and burning "Jeff's Gas" is way cheaper than burning our brakes.
And the brakes on the EP models suck so if you actually use them on landing, and have to do a quick turn, they will still be too hot to take off!
nopistn is offline Find More Posts by nopistn
Old Dec 14, 2012, 11:15 PM
Up-Out-&-Gone
Joined Mar 2007
Nopistn whats your biggest gripe about the ERJ-145 series? and whats the best thing about them . . . . . .from a pilots point of view.
Old Dec 15, 2012, 09:13 AM
nopistn is offline
Joined Apr 2008
I'd say the avionics that ours are equipped with are pretty poor.
Examples:
If you're going fast and or have a tail wind, the flight driector will often overshoot a course, then over correct several times resulting in many unnecessary turns and sometimes causing concern from ATC while overshooting a localizer (final approach course for a runway) with other traffic on a parallel runway.
The speed hold feature is also very poor, causeing the airplane to pitch erratically while attempting to chase a speed, especially in anything less then perfectly smooth air.
I also despise the bicycle handlebars for a yoke.
But really those negatives will have nothing to do with your model at all.
As far as actually flying the airplane, I like it a lot.
I like the direct (unassisted) cable link to the elevator which is well balanced and feels nice.
I like the trailing link landing gear (better design than the CRJ) that helps smooth out controlled crashes.
I like being able to open the side windows on the ground.
It's also pretty technically advanced (idiot proof) and it will basically ding or yell at you most of the time if you're messing or is something goes wrong.
Old Dec 15, 2012, 09:52 AM
Joined Nov 2011
That is pretty light, how many layers do you use and is it the 3/4 oz hobby cloth, do you vaccuum bag it or just lay it up on the plugs? Im thinking when I do mine I may do one layer of prepreg and vaccuum bag it to the plug and then do a light ply ring to stifen it.
Old Dec 15, 2012, 10:46 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
you'd be surprised at that statement. the actual speed difference between landing flap settings and zero flaps isn't that much. on a 767, the differential between the two is only about 10 knots in a 767. what changes dramatically is the approach angle to the runway. of course, if you don't fly finals with power, flaps will bleed off airspeed till stall occurs, which is why finals are always flown power-on. it's actually a mistake I see too many RC pilots make, because they simply don't understand aerodynamics. they don't set up a good glide path with the elevator and use careful power inputs to increase and decrease altitude.
I'm sure every airplane is slightly different, but the general statement is that flaps don't change the approach speed too much, only the approach angle.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 15, 2012, 12:57 PM
Up-Out-&-Gone
Joined Mar 2007
Examples:
Wow! so I guess you do allot of manual overide of the auto-pilot Huh and you hear allot of "where the FUKKKK are you going????? from ATC lol
Bike handlebars? hey its like flying the Old Hawker Siddely Trident! lol
Coolest thing is how she looks from the outside too! the 145 is a good looking bird!
Old Dec 15, 2012, 01:01 PM
Up-Out-&-Gone
Joined Mar 2007
One layer of Fiberglass, and don't worry its very strong and Light!
Old Dec 15, 2012, 01:08 PM
Up-Out-&-Gone
Joined Mar 2007
Very true Rich thats why when I maidened my 767 I had fixed gears and had the flaps at about 20degs, so I knew to keep her at a relativly high throttle level, but now I have retracts & made other improvements the 2nd flight will be VERY interesting . . . . . .I hope
Build Log Embraer ERJ-145 build jdlilfan RC Airliners (Commercial, Cargo, Troop Carrier) 220 Jun 14, 2014 04:28 AM
Build Log Erj-145 rmackelvey Foamies (Scratchbuilt) 67 Apr 07, 2012 07:35 PM
Discussion Project - ERJ-145 XR FANMAN Electric Ducted Fan Jet Talk 61 Jul 26, 2008 07:42 PM
For Sale Airplane model ERJ-145 modelplane Non R/C Items (FS/W) 3 Oct 16, 2005 10:31 AM
Need Info on Bombardier CRJ200 and Embraer ERJ-145 Regecide Life, The Universe, and Politics 0 Oct 15, 2003 09:17 PM
