Old Oct 17, 2012, 02:18 PM
Mikael is offline
Find More Posts by Mikael
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
I use the rates as Avonds suggest. But I only fly with low rates, it's very responsive on ailerons. The high rates is for extreme manuevers.
The canard is mixed in with up elevator only.
Mikael
Mikael is offline Find More Posts by Mikael
Old Oct 17, 2012, 03:28 PM
gianni sanchez is offline
Find More Posts by gianni sanchez
Belgium, Walloon Region, Mons
Joined Jan 2012
ok ,i was affraid to use them with high rates ,because i also have a big jim fox saab viggen with canards and this is very touchy with them
so i put only 5 mm rates on canards with use of elevators
so if you confirm that i could go more , i ll put higher dual rates
gianni sanchez is offline Find More Posts by gianni sanchez
Old Oct 17, 2012, 04:02 PM
Mikael is offline
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
Avonds instructions:
Measured at trailing edge on elevons.
Elevator high rate 27mm up/down, low rate 16mm up/down
Aileron high rate 15mm up/down, low rate 9mm up/down
Canard measurment done at leading edge
Canard high rate 20mm, low rate 12mm. up only
Old Oct 17, 2012, 04:42 PM
Joined Jan 2012
perfect!! thanks dude!!!
Old Oct 23, 2012, 04:08 PM
Rage is offline
Find More Posts by Rage
Tours Air Base, France
Joined Dec 2007
hi guys
i am really happy to discover that thread i have a rafale avonds converted with rclander 12s edf almost ready for the maiden
i will fly with 2x6s 5000mah in the next 10 days
Rage is offline Find More Posts by Rage
Old Oct 24, 2012, 02:34 PM
Joined Jan 2012
cool!! keep us in touch with yours!
mine is still waiting for getting a "shaved" grass to get it airborne
i m also planning to get a closed duct as jacojet does
keep watching
Old Oct 24, 2012, 04:46 PM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Gianni,
Do you remember or know the bare fuse weight?
Gamalier is offline Find More Posts by Gamalier
Old Oct 24, 2012, 10:13 PM
Super Matt is offline
Find More Posts by Super Matt
Joined Dec 2011
Cant wait to see video of this bird in the air.
About time a thread that does not pertain to chinese edf crap, thou i have not had any luck with the HET motors.
Super Matt is offline Find More Posts by Super Matt
Reply With Quote  (Disabled)
Old Oct 25, 2012, 12:33 AM
jacojet is offline
Find More Posts by jacojet
jacojet's Avatar
South Africa, Free State, Sasolburg
Joined May 2010
Originally Posted by Gamalier View Post
Gianni,
When I got mine, I stripped out everything including formers and it weighed 3.3kg with paint.
jacojet is offline Find More Posts by jacojet
Old Oct 25, 2012, 01:02 AM
Rage is offline
Joined Dec 2007
For those who already fly this jet where do you have the correct CG ?
Old Oct 25, 2012, 05:41 AM
jacojet is offline
jacojet's Avatar
Joined May 2010
oops! double post, sorry!
Old Oct 25, 2012, 05:42 AM
jacojet is offline
jacojet's Avatar
Joined May 2010
7mm in front of the forward former in the fan compartment.
Old Oct 25, 2012, 10:28 AM
Rage is offline
Joined Dec 2007
cool thanks
do you think that 2x6s 5000mah 25c turnigy pack is enough for the 120mm rclander edf ?
Old Oct 25, 2012, 11:28 AM
Mikael is offline
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
Or you can measure the CG from the inlet, 358mm.
On mine the former was set to far back and resulted in CG to far back.
Old Oct 25, 2012, 12:47 PM
jacojet is offline
jacojet's Avatar
Joined May 2010
cool thanks
Depends on the amps, under 90 amps 5000mah will be enough for 4-5 minute flight. My set-up at the moment has about 93 amps, and I use 5300mah batt. for 4 min flight, leaving about 20% in the packs.
Build Log Aeronaut Rafale 120mm EDF super kupfer Large EDF Jets 345 Nov 26, 2015 01:44 PM
Discussion Avonds Rafale jacojet Electric Ducted Fan Jet Talk 41 May 12, 2012 07:27 AM
