Old Oct 11, 2012, 07:11 PM
gianni sanchez is offline
Find More Posts by gianni sanchez
Belgium, Walloon Region, Mons
Joined Jan 2012
rafale phillip avonds EDF 120mm converted
here's my last project ,a phillip avonds rafale converted to edf 120mm
the set up is schuebeler 4 blades DS 94DIA HDT 120mm with NEU motor 1527/1.5Y
on 12cells
CC 80hv and 2 -6cells5100mah kypom 35c lipo's
very easy to convert ! it took me an afternoon to do it!
maiden is close !!!!
if you have any suggestions or info about how this jet flies ,behaviour , bad habits , CG re-location ,feel free to post answers!
check that out
gianni sanchez is offline Find More Posts by gianni sanchez
Old Oct 11, 2012, 10:33 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Currently building an aeronaut rafale, 120mm EDF 10cell with maybe an option for a lightweight 12cell.
Was wondering where is your battery placement as your pics don't show.
super kupfer is offline Find More Posts by super kupfer
Old Oct 12, 2012, 04:08 AM
Joined Jan 2012
just in the front of the splitted inlet duct stick in between
but this one is way bigger than the aeronaut
i also have a aeronaut rafale on twin 70mm 2w30 on 2- 8cells with vasafan
flies super nice and pretty fast with this set up!!
all my batteries are in front on this one ,
i use to have 2 90mm in it in the past but to heavy ! lipo's were also in the front
under cockpit
never used canard on this one...
here's also videos
rafale aeronaut bunjee take off 2/ 2w30 het motor 3900 watts (0 min 8 sec)
this one was is the 90mm fans
rafale aeronaut, slow speed pass (0 min 49 sec)
Old Oct 12, 2012, 09:19 AM
Joined Jan 2010
under cockpit
here's also videos
http://www.youtube.com/watch?v=wPtUnvy1qqA
http://www.youtube.com/watch?v=-KM3Z0Buxrs
Mine also has the batteries between the inlets and would love to use the same canard mechanism as your Avonds has but the torque rod is in the way of the batteries, may have to go to individual servo setup.
Old Oct 12, 2012, 03:41 PM
Joined Jan 2012
so.... nobody does this conversion before?????
just curious how it's flying
Old Oct 13, 2012, 02:14 AM
jacojet is offline
Find More Posts by jacojet
jacojet's Avatar
South Africa, Free State, Sasolburg
Joined May 2010
HI, I have done the conversion. Used a schubeler HST 94 fan on 12s 5300mah gens ace packs (3x 5300 4s packs) , hobbywing 120HV ESC and E-flight 60-120 electric retracts. All-up weight came to 8.7kg. first flights was with open ducting with lip on fan and it went very well, then I made some full ducting and it is faster and requires less throttle to cruise. No bad habits, slows very nice for landings and is a joy to fly! The HST fan really needs 14s to reach optimum performance, but I fly with only 12s and still recorded a speed of 220km/h. I fly with the CG just in front of the forward former in the fan compartment.
Avonds Rafale, schubeler 94HST on 12s (4 min 32 sec)
jacojet is offline Find More Posts by jacojet
Old Oct 13, 2012, 09:41 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Awesome performance!
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Oct 15, 2012, 01:33 PM
Joined Jan 2012
ahhh! thanks!! at least one guy did it already
thanks for the info !!
i tried yesterday to maiden it but it didn't took off the puffy grass we have at the moment at the field
just have to wait for the lawnmower session ......
i did the same thing for the fan lip with open ducting
did u feel a big difference with a close duct??? or it's just sensitive??
witch motor do u use ??
i have a NEU 1527 1.5y on 12cells
seems to be a bit slow to me ...
Old Oct 15, 2012, 02:00 PM
Mikael is offline
Find More Posts by Mikael
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
I have a Avonds Rafale too.
It's a bit heavy because of repairs after a crasch but it flies great.
It's got a XPS dynamax, Jeti spin200 and 14s 6600.
It weighs ca:9,5kg. The speed is arround 270 km/h.
One problem I had in the beginning was that it wants to jump in the air on takeoff.
But after I moved the maingear forward, made sure it sat in a positive stanse and pointed the exhaust up a bit it works great.
Mikael is offline Find More Posts by Mikael
Old Oct 16, 2012, 01:57 PM
jacojet is offline
jacojet's Avatar
Joined May 2010
More than one! I used a HST94-600 schubeler in mine. With the open ducting she needed a lot of throttle to fly (cruise) but with proper closed ducting she went a lot better and cruising was at a smaller throttle setting, so I would say the closed ducting worked better and more efficient. In your photos it looks like it would be very easy to make the ducting closed? I also made a single oval shaped exhaust.
Old Oct 16, 2012, 05:48 PM
Joined Jan 2012
thank jacojet and mikael!!
i don't have much time for the moment to make a decent inlet duct, so i ll gonna try to make a second test this week end , but i begin to believe the NEu motor was not a good choice!!
how much your motor draw and how much watts it produce on 12 cells jacojet?
Old Oct 16, 2012, 06:44 PM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
Gianni, not a good comparison here because you guys are using entirely different Schübeler fans.
Your DS-94 "HDT" is 120mm with 4blades, and your chosen motor Neu1527/1.5Y
Jacojet is using the DS-94 "HST" that is 128mm, 11 blades and is a complete unit with factory built in motor.
If his is the DS-94HST DIA6740-600 it would be approximately 98Amps and 4300watts using 12s. This would be about 74N thrust on a test stand with bell mouth.
NOTE:
Your 1st post referenced using a CC HV80 ESC? You will be way over the capability of this ESC with decent batteries, the Schubeler fan and 1527 motor will run near 110Amps on good 12s cells.
Not sure about the 35C LiPo's you are using, may be that you will be down on power due to voltage sag under load.
Mike Warren is offline Find More Posts by Mike Warren
Old Oct 17, 2012, 12:22 AM
jacojet is offline
jacojet's Avatar
Joined May 2010
The numbers Mike quoted is exactly right!
I do not think you chose the wrong motor, it should give good performance. The take-of run on my rafale is also a bit long, and with the first flight, I thought she will never get into the air! Good luck!
Old Oct 17, 2012, 04:35 AM
Joined Jan 2012
[QUOTE=Mike Warren;23020082]Gianni, not a good comparison here because you guys are using entirely different Schübeler fans.
NOTE:
Not sure about the 35C LiPo's you are using, may be that you will be down on power due to voltage sag under load.[/QUOTE
thanks for the info! u're right for the hv 80 too! the motor draw 118A exactly on WOT but never have problem with this hv who suppose to handle 30% more than the effective numbers and won't be at full throttle all the flight time
,anyway this is for the maiden ,i have another 120hv i order to arrive ...
i bought this unit with the motor already installed and was supposed to be the best motor for this schueb ,hmmmmm
i start to believe it's not!
i think i'm gonna change into a HET motor 700-98 on 12 cells if it doesn't take off next time
another question : do u use canards?? how did u set them ? rates ?
thanks!!
Old Oct 17, 2012, 10:00 AM
jacojet is offline
jacojet's Avatar
Joined May 2010
Yes, I use the canards. Maximum travel, it helps with take-off. Set-up to move the same as ailerons and the trailing edge down with up elevator. For aileron function on canards I use about 30mm but max travel for elevator function.
Build Log Aeronaut Rafale 120mm EDF super kupfer Large EDF Jets 345 Nov 26, 2015 01:44 PM
Discussion Avonds Rafale jacojet Electric Ducted Fan Jet Talk 41 May 12, 2012 07:27 AM
