That seems pretty normal for that type of heli. The trick is to not let the flybar catch up by using a lot of movement changes. There is a flybar change that is supposed to help.
Latest blog entry: Some stuff
TBE is induced by a harmonic distortion in the flybar, it has nothing to do with drag, as drag is constant. It could be bent (unlikely), too tight, too loose, the mounting or linkage could be worn, it could be binding in one spot; lots of things that are hard find. But, TBE is never caused by something that is consistent through the full 360° rotation. The pendulum effect is swaying back and forth when attempting to stop. It's more common in some micros in others. It's something like a car with bad shocks when you try to stop, it doesn't have enough damping effect. Restricting the flybar movement or capabilities reduces damping effect. Delaying or reducing damping allows forward flight longer, before the flybar catches up. If you want a micro FP that isn't slowed by the flybar, find a used Blade MSR, of get a micro without a flybar.
United States, KS, Wichita
Joined May 2010
My experience with these micro helis is that if the flybar is tight, it's usually a symptom of a problem, rather than the cause.
| Thread Tools | |
| Discussion slow forward flight v911 | hilewannabe | Micro Helis | 9 | Sep 11, 2012 06:36 PM |
| Gallery FPV Y-6 Fast Forward Flight, Chasing Planes and 4x4s... with a collision | Adidas4275 | Video Piloting (FPV/RPV) | 1 | Apr 05, 2012 01:37 AM |
| Fast Forward Flight on Hummingbird? | Manchild | Micro Helis | 10 | Jun 02, 2003 02:06 AM |
