Old Oct 11, 2012, 07:15 PM
Lazman is offline
Find More Posts by Lazman
United States, VA, Mechanicsville
Joined Oct 2006
Y6 Coaxial 600mm design
II had a few ideas around building a Y6 coaxial design, I just finished and thought I would share.
Requirements:
Heavy lift Y6 - i wanted the frame to be able to handle 20lbs hanging from the center. Not that I plan on that yet.
Simple design with low part count. The main Y frame has 11 parts.
Easy to rebuild with low cost, aluminum extrusion and flat plate for main structure (for the frame, the motors and such cost a bit).
I was also frustrated with most kits made today, many have 200 screws and nuts.
My idea:
Build a frame using high strength 2 sided tape with coaxial motors in a 600mm frame.
I have tested the frame with 20lbs hanging from it, surprizingly strong. Total lift capacity should be between 25 to 30 lbs. Total weight with 11000 mah lipo is 7 lbs, ready to fly. There are only 12 screws in it, they are to attach the motors. It took about an hour to assemble the frame, of course wiring took longer.
Turned out far better than I had hoped and learned that my MakerBot is capable of creating structural pieces.
Flight videos coming asap.
Interested in feedback as always.
Laz
Lazman is offline Find More Posts by Lazman
Discussion Syma S033G Convert from coaxial to non coaxial Kenwhite23 Beginner Training Area (Heli-Electric) 13 Apr 17, 2014 04:01 PM
Build Log small hovering design using coaxial rotor with fixed props hg1 VTOLs 217 Sep 28, 2012 07:06 AM
Discussion Y6 Design & Build flylite Multirotor Talk 6 Jun 14, 2012 05:09 PM
Idea Airframe design suggestions for small coaxial rotor craft ? hg1 Coaxial Helicopters 1 Jun 29, 2007 02:01 PM
micro coaxial helicopter design ideas afabio Electric Heli Talk 3 Apr 25, 2002 08:48 AM
