Old Oct 21, 2012, 09:03 AM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Not yet I'm afraid. It's 2-3 weeks standard isn't it?
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Oct 21, 2012, 09:46 AM
nakelp86 is online now
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
here is the guick test to show difference in lenses on #16 cam
#16 key chain lens test (0 min 13 sec)
nakelp86 is online now Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
Joined Sep 2004
CJ
Hmm it could be so maybe this week.
Old Oct 21, 2012, 11:34 AM
rsands2801 is offline
Find More Posts by rsands2801
Joined Dec 2007
i think your mounts for the dragonlink need to have a swinging mechanism. Not everyone holds a transmitter at the same angle which means the bracket will not offer best position for the antenna for everyone. BUT any chance of one that works with DX7?
rsands2801 is offline Find More Posts by rsands2801
Old Oct 21, 2012, 11:53 AM
Joined Jun 2007
This has come into question a few times, but as stated, I don't think a slightly misaligned antenna will mess with the range too much. I doubt there are many that hit the outer limits of their dragonlink range. It also makes a cable length issue, it makes the mounts less universal due to differing radio design etc... Im still dead set that a swinging mechanism would create more problems than it solves. If you would like a custom design though im more than happy to cater for it.
The DX7, what sort of module does it have? similar to the hitec? (when viewed from the back, 5 pins horizontal on the lower left portion of the module hole), JR/Turnigy (when viewed from the back, 5 vertically aligned pins in the lower right section of the module hole) or Futaba (when viewed form the back, 5 Pins aligned horizontally across the middle top section of the module hole).
A picture would help .
CJ
Old Oct 21, 2012, 01:53 PM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
I guess so. The trouble with doing a pivot on the module is that the module would need to have a hinge quite far away from itself so the DL could swing freely. Ill see what I can do
(The next day)
CJ
What happened? You changed your attitude towards it over night.
I don't see the cable length issue, why isn't there an issue with the stock holder then? I have lots of length left over, so much that I worry about snagging it on something even when the DL is fully rotated.
iskess is offline Find More Posts by iskess
Old Oct 21, 2012, 02:47 PM
Joined Jun 2007
I have always held the position that a swing arm isn't necessary due to the sheer signal strength of the dragon link system. But as I stated earlier, I'm happy to accommodate others designs. The other issue of course is the unit compatibility changes. Currently, all of my futaba adapters will fit all futaba radios, the same goes for JR. if I were to implement a swinging system the antenna risks impacting the radio at either the back, or the bar. unless I separate the unit and hang the DL case from the bar, which as stated earlier, is a mounting system supplied with the DL V2. Im not entirely sure the geometry of having the hinge attached to the module would work universally with all radios, perhaps further research on this is required. Additionally, The cost of a 2 part unit would increase as they would need to be printed separately, so material used and print time increases (probably to the sum of 5).
CJ
Old Oct 21, 2012, 03:40 PM
Joined Jun 2007
Name: Screen Shot 2012-10-21 at 21.34.46.png
Description:
Name: Screen Shot 2012-10-21 at 21.35.08.png
Description:
Oops, clumsy me, I really should be careful where I leave these things :P.
CJ
Old Oct 21, 2012, 04:44 PM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Attachment 5248033
Attachment 5248034
CJ
mmm interesting design....will it fly ? possibly, will it fly well ? errrm maybe not otherwise there would be plenty mode full size equivalent ? I think it will need rudders
Mind you Burt Rutan has kinda sniffed around that...
rcmonster99 is offline Find More Posts by rcmonster99
Old Oct 21, 2012, 04:57 PM
Joined Jun 2007
Tandem wing, into which I have done a heavy amount of research. Main drawback is production time (you need two wings instead of one), not so much a problem for me. front wing is in effect a canard with an airfoil profile (Clark-y in this case). Advantages include wide COG range & shorter wingspan. Disadvantages, the rear wing flies slightly in the front wings washout (hence why it is higher, I may yet raise it some more). Wing chord, 100mm, each wing spans 300mm, leading to a total of 1200mm. Maximum all up weight, 1000g (a wing loading if 25oz/sq ft). Predicted airframe weight thus far, 620g. Gear on top (camera, 6 3.6g servos (one for cam tilt, five for surfaces, I have since added a reasonable rudder), motor, prop, spinner, ESC, 1800mah 3s lipo, DL Rx & OSD, misc cables and connectors & 5.8Ghz VTx gear) 330g.
Total predicted weight, 950g. Not out of the realm of possibility!
CJ
Old Oct 21, 2012, 05:05 PM
Joined Dec 2007
dx7 doesnt have any module...it has a 3.5mm hack where trainer leads would be put? see here for image:
http://api.ning.com/files/sX98WD5kzh...rearvelcro.JPG
Old Oct 21, 2012, 08:17 PM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Alright, I thought saying you would look into it meant you would consider designing it.
I'll just wait for the 9XR to be released, then we can work on a solution for that specific radio since the stock DL solution won't work on it, and it will be a hugely popular radio.
Old Oct 21, 2012, 11:56 PM
Joined Jun 2007
Probably for the best iskess. I'm more than considering to design it. But if you want it for a specific radio like the new Turnigy one, then it'd be best to Taylor it round that, rather than trying to make something universal.
Rsands2901, I think you may have missed the point of the module adapter, it's main function is to hold the DL on the back of a radio while making the plug in connection super simple using the existing module slot on the radio. If you have a radio without a module, there is no way to fix my current design to your radio, and if you can only then plug in via the trainer port, the two main functions of this mount don't exist for your setup. In which case, I'm not entirely sure what your asking for. A picture would help .
Old Oct 22, 2012, 12:29 PM
Houba ! Houba !!
Joined Sep 2003
CJ
mmm hit the PRINT button and let's see this baby in action
Old Oct 22, 2012, 01:58 PM
Joined Jun 2007
Got a few hours to go on it yet. Planning for a Keda out runner mounted internally. 30a ESC under the rear wing fuse brace. Gotta do ailerons and elevators, servos going to slot into the wing with their output shaft lined up with the control surface. Direct drive as it were. All internal linkages. Tilt mechanism for the camera needs to go in (I plan to use the same as you have for the reaper, link me?). It'll have a similar rudder mechanism. Again, direct drive internal linkage. 8X4 folding prop with cone spinner. The cloverleaf is quite clever, to save weight but maintain strength, it's actually positioned facing down imbedded in the front wing brace, the VTx will go above, in a cooling vent. Built in landing skids. Nothing will be a bolt on extra protruding into the air flow. It will all be "designed in" .
CJ
Discussion 3D printed FPV but DLG type elliptical wings.. Laurence Carroll Hand Launch 3 Aug 17, 2012 02:15 PM
New Product All kinds of props for multicopter, APC-type,EPP-type,Graupner-type,Three Blade chz109 Multirotor Talk 0 Aug 16, 2012 01:40 AM
Cool North Seattle/ Shoreline Fliers of all types come one come all! j3d1b3n333 USA - District XI 0 Aug 05, 2012 11:46 PM
Sold FPV Goggles for sale, 3D and 3D with audio. 80" screen. Selling Cheap jasper7821 FPV Equipment (FS/W) 2 Mar 24, 2012 12:44 PM
Discussion 3d Printing New Canopy for Blade MSR Need 3d Image BWChronos Micro Helis 2 Aug 11, 2011 01:42 PM
