there's this
http://www.ebay.com/itm/Motor-Speed-...item1e6c4c52bf but you'd need a separate BEC because input voltage is only up to 17v. I just googled 50A brushed car esc and got lots of results. |
If the ESC can't handle the full 18v, it'll blow regardless of how you're powering the servo tester.
I was confused about the pot because it sounded like you were asking why to use a servo tester at all. I'm thinking something like a flexible pushrod from the pedal to the horn on the pot could work. That way if they jump on both pedals the cable will flex instead of braking anything off of mounts. You'll also need to "connect" it to the horn in such a way that turning the other way doesn't push the opposite pedal further out (kinda like the brakes/carb linkage on a nitro car) How do you plan to handle reverse? Having a kid hit the brakes, then hit them again and go in reverse could give them quite the shock if they were just hoping to stay stopped. |
WParsons, thanks for the response, flexible cable like used on the planes could be a great idea to drive the servo tester, that way I can also mount it wherever I want.
On the reverse, that is a good question. The basic set-up of these cars uses a switch to change polarity on the motors so they stop, and then switch into reverse. It might be easier to keep that set-up and just use an ESC set up to apply brakes when you let off the gas. Scott |
| Thread Tools | |
| Discussion Using old servo control boards as actuator driver/motor ESC for PROPORTIONAL control | EQMOD | Electric Power Cars | 12 | Dec 20, 2012 09:05 AM |
| Discussion Help me pick out motor, ESC, battery, and servos for my first scratchbuilt. | MightyRed | Foamies (Scratchbuilt) | 4 | Jun 19, 2012 09:42 PM |
| Discussion I need some help figuring out how to wire something up to my Rx | asd9000 | Radios | 4 | May 11, 2012 08:57 PM |
| Discussion recived an intresting pack today...help me figure it out | eran_k | Batteries and Chargers | 3 | Apr 04, 2006 04:31 AM |
| Can anyone help me figure this out... | av8ersteve | Batteries and Chargers | 3 | Aug 10, 2005 07:36 AM |
