This thread is privately moderated by RHTizzy, who may elect to delete unwanted replies.
Old Oct 11, 2012, 01:50 PM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
Build Log
Flashing ESC's with SimonK
I tried to flash my ESC's after getting pre flashed ones from RCTimer but ran into a problem
Originally Posted by RHTizzy View Post
Hi guys,
Just recently I bought a few pre-flashed 30A ESC's from RCTimer and the difference was so noticable I thought I'd flash my other ESC's too. I've flashed a bunch of other stuff using a CRIUS USBASP and thought I had the pinouts clear so I made a new cable for doing the ESC's. But I can't get it working.
As soon as I touch the pins to the ESC the USBASP quits and cannot be found by avrdude anymore. The status light on the asp blinks when I touch the pins to the ESC but it doesnt talk to the USB port anymore. Unplugging the ASP and then pluggin it back in will reset it again, but that's as far as I can get.
Have I got something backward? All input is welcome, thanks people.
Cheers,
Rick
In the first pic I test the USBASP without touching the ESC to see if the driver is recognised. After that I touch the pins to the ESC and the ASP cannot be found anymore. I made the extra connector after the problem arose so I could easily swap the connections but everything seems to match up to spec and it still freezes the ASP.
Simonk replied the following, which was right on the money!
You are probably trying to flash an unpowered ESC. Depending on how sensitive your USB port is, and the ESR/size of the capacitor(s) on the ESC, it might just draw too much current when you first touch it, and bounce the USB port. If you power the ESC from a current-limited supply first, you should no longer see this.
I hooked up an 1800mAh 20C lipo to the ESC and retried: Success!
Noticeable result: immediate throttle response as opposed to the spungy feeling. There are said to be other benefits but this was immediately noticable.
RHTizzy is offline Find More Posts by RHTizzy
Found Simonk Flashed ESc's mmalik4 Aircraft - Electric - Multirotor (FS/W) 10 May 21, 2012 10:41 AM
Sold 4 Towerpro style 25a ESC's flashed with Simonk FW kanchana Aircraft - Electric - Multirotor (FS/W) 5 Apr 11, 2012 06:51 PM
Sold 4 Turnigy style 25a ESC's flashed with Simonk FW kanchana Aircraft - Electric - Multirotor (FS/W) 0 Mar 25, 2012 09:25 PM
Sold 4 Towerpro style 25a ESC's flashed with Simonk FW kanchana Aircraft - Electric - Multirotor (FS/W) 0 Mar 24, 2012 04:19 AM
Sold 4 Turnigy 25a ESC's flashed with Simonk FW kanchana Aircraft - Electric - Multirotor (FS/W) 5 Mar 24, 2012 01:35 AM
