United States, FL, Sebastian
Joined Nov 2011
No worries here, canardjeff. I ask about the wingtips because of the stills on their website showing a wingtip drag in great detail. I haven't tried it with my parkzone icon yet
, but it looks amazing.Your Y tail might be just the ticket for reducing the dreaded dutch roll? I read many complaints regarding this! When mine tries to wag, I add a touch of throttle.
Joined Nov 2011
Renfield Designing something " new" is fun but it involves a lot of " Fence Walking" so to speak choosing where to make concessions , looks over performance and vice versa. Also it is a battle trying to make something different. My good friend Dave Platt ( yes, Mr. Scale ) said once to my father and I , " how can you do something new? Everything has already been done". In many ways this is true. Even Rutans work has been preceeded by and based upon many similar earlier concepts. Look at a lot of the late WW 2 design activity. Hell, Leonardo DaVinci drew rubber powered canards in the 1400s ( and Helicopters). We call Rutans "amazing epiphany" feathering system on Space Ship One a dethermalizer in the free flight world and even rigged one to a servo on a R/C assist Texaco plane long before Space Ship One was thought of. Not dissing Burt, just making a point supporting Dave's statement. Icon did a terrific job ( it is taking way too long though ) and really stirred up a lot of emotion (1000 depositors). But it is time for another player in the game. Does your model Icon really wag it's tail bad? I've read others making the same complaint and people claiming it has inadequate tail volume. The real one doesn't seem to exhibit this in any of the videos I've watched. A friend of mine , Len Fox, is a pro test pilot and conducted the spin testing on the real Icon. He says it flies very nicely, naturally he will be doing the test work for mine and will provide great comparative assessment. Thanks for the tip on the Icon water ops photos. What I find pleasing is it is as I related in an earlier reply , glassy smooth water. Wing tip would probably trip in rougher water, as would mine which contacts with a similar angle of attack to the water. Only time will tell on the Y-Tail, the model is only a couple days away from flyable. Will find out soon, hoping for the best!!!!! There is always something to be learned when you try to be different, sometimes good surprises, sometimes bad, thats what makes designing your own stuff so much fun. If nothing new is ever attempted, how can we advance as a whole? Regards Jeff |
My suspicion is that Icon would've gone with a V or Y except for the need to accommodate folded wings? The warning on the Icon water testing photo said it all, I suppose. Looks cool but don't try this! Yet I know that on some glassy smooth day at the lake, I will. ![]() Good luck with the maiden! |
DUNDAS CANADA
Joined Feb 2006
Jeff.
You designing good looking plane. I have one question. Are you concerned that without any deflection plates or the sponsons, on takeoff the water will be sucked into the prop. Original Shearwater had this unique shaped fuselage that shielded the prop, but at the cost. The drag from that area on other vice clean design made the plane un-economical. The Shearwater company abandoned that version and is in process of working on new, much cleaner design. I wish them and you all the best with the planes. Despite of that, I love flying my R/C version of original Shearwater. Here is the vidio with my model flying.
DUNDAS CANADA
Joined Feb 2006
Lockey.
The Flying Model Magazine is selling the plans now. Here is the website. http://carstensbookstore.com/shearwater.html |
Joined Nov 2011
Thanks for your concern. The design does have fuselage mounted sponsons which will handle lateral water stability and they make a great shield for water spray to prop . They were not yet ready to mount to fuselage when the pictures were taken. They require a rather stout structure going thru fuselage as on the real one I hope to mount the retractable gear in the sponsons retracting rearward into sponsons behind step with a gear door only covering area forward of step( still scheming and designing this aspect of real craft). additionally I have to add and contour epoxy/micro balloons on hull chine to create a downturned spray rail forward of sponson.More updated pictures coming soon as well as test flight this week sometime. Sprayed primer last night to help waterproof , will fly in primer then fully finish and detail cockpit ( have to pull a clear canopy off foam and glass one presently used for test flying) as per intended on real one later. Thanks for your compliments and suggestions. Jeff |
I noticed a few posts concerning the Bonanza V-tail... I just finished reading the results of the official FAA investigation into whether the Bonanza's tail was weak or structurally insufficent. In a nutshell, the earliest Bonanzas had the highest incidence of strucural failure, later attributed to probable overspeed/overstress of the then new & slippery airframe. Over the years Beechcraft enlarged & beefed up the tail, adding thicker skin in some areas, sub-spars and thicker root ribs among the other more well known mods such as leading edge root cuffs that prevent stabilizer deflection at high g loads. They also added 14% to the chord of the stabs starting with the C35, if I recall correctly. The findings indicated that as long as the airplane was operated within published limits on ALL versions of the Bonanza, the airframe (tail included) was safe.
The V-tailed version of the Bonanza was about 3 MPH faster than a standard tail, due to less interference drag with 1 less surface intersecting the fuselage. Skin drag wasn't a real player. Sorry, just wanted to share a bit of info for those that care ![]() So I would say faster, prettier, but prone to dutch roll... and surely mired in controversy. |
Joined Nov 2011
Test flight
Test flight went great, airplane flies beautifully as if on rails . will be doing video next flight and hopefully water tests later in the week as well if wind lays down. will post video when completed. Only have one set of batteries so basically one flight per outing and two hours on charger.
Jeff |
| Thread Tools | |
| Discussion New full scale HP-24 homebuilt | jhiggins | Scale Sailplanes | 7 | Mar 19, 2008 04:59 PM |
| Discussion R/C Flying Inside a Full-Scale Airplane? | natoquick | Electric Plane Talk | 30 | Mar 31, 2007 02:35 AM |
| Discussion A full-scale R/C style "stir and stab" contest... | quietman | Sailplane Talk | 20 | Dec 24, 2006 11:25 AM |
| Question for pilots (full scale non R/C) | Curtis Shinmori | Electric Plane Talk | 44 | Dec 29, 2004 10:59 AM |
| Full Scale Pilots and R/C Pilots | AirVenture | Electric Plane Talk | 13 | Jul 04, 2001 04:02 PM |
