This thread is privately moderated by Tartago, who may elect to delete unwanted replies.
Old Oct 11, 2012, 06:42 AM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
TopRC FW-190 Landing Gear Mod and others
I bought this plane a bit skeptical with the plan of using its wing for my Hyperion Dora. But after the first flight it was love at first landing.
I made like 20+ flights with her and now I decided it's time to giver her a pair of Marlene Dietrich legs.
Tartago is offline Find More Posts by Tartago
Old Oct 11, 2012, 06:48 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
From unboxing to maiden.
For the record:
This is a fine scale plane for her size.
The only 2 cons I've found are the legs and the paint. The latter was fixed using a generous layer of WBPU.
The legs were a challenge. I made some mistakes, but since I started all the process with one, the second was way much better.
Old Oct 11, 2012, 07:35 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
The plastic retract support is so weak that I decided to use 2 pieces of 5x12x80mm hardwood rails to make a better one.
I carved grooves on the foam to accept the new supports.
Pre drill and attach the retracts, then hot glue it to the foam grooves.
Old Oct 11, 2012, 07:37 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
A comparison with the original leg.
Old Oct 11, 2012, 07:47 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
The new legs give this plane a new look.
They are not perfect, but I learned a lot from one wing to the another.
The first took me 4 nights to think and complete and the 2nd only one.
The LG doors are made of 2mm PVC sheet, carefully heated to get them to shape and cover the wells. Attached to the legs with hot glue.
I hope this weekend I can test them.
Was it worth it? This plane is too pretty to leave her with those short legs.
Old Oct 17, 2012, 06:44 PM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Video of re maiden
The flight with the new legs went absolutely fantastic!
I was afraid of the CG being off, but everything was ok.
The take off was mach easier since I didn't worry about stones hitting the tail wheel and generating a nose over.
During the landing I noticed the most difference in behavior, the plane tracks more solidly and I could reduce the speed a lot. After touching down, the tail slowly sits as the speed is flared.
I really liked it!
I will get a new material for the wheel doors to make them more accurate to scale.
TopRC Focke Wulf FW-190A with landing gear mod (3 min 29 sec)
Old Nov 26, 2012, 11:36 PM
Flyer57 is offline
Find More Posts by Flyer57
Joined Nov 2012
Fw190
Hi Tartago,
Could not agree more, this a beautiful plane to fly, but the undercarraige is just all wrong!
Even after a close to perfect landing, and then still a nose over is never a good thing.
Really enjoyed your modification, but I decided not to move the retracts after some of your warnings and decided on a slightly different approach.
I moved the wheels forward and towards the centre of the wings as far as I could, then made new, longer struts, replacing the original 2.5mm spring steel with 3mm spring steel.
Also then strengthened the wheel wells with some balsa beams.
The wings are now even stiffer than than in the as-bought kit.
Put a forward bend in the steel struts just after they exit the rectract gear.
Took her up this morning and the landing was perfect, even on the slightly longer grass. No more nosing over, so very pleased.
As you know, it's never an easy thing, getting out the knife and starting to hack chunks of foam off new model, but very pleased it worked out here.
After a few more flights, I will make new doors and fit them.
Some pictures in case anyone with this beautiful plane is interested:
Flyer57 is offline Find More Posts by Flyer57
Old Nov 27, 2012, 05:14 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Well done Flyer!
It's a good mod to avoid massive foam surgery and the objective of avoiding nose overs is met.
I really like this plane an I was bleeding on the short legs.
Idea Another X525 (and other X### frames) mod - relocating the landing gear iamsuperbleeder Multirotor Talk 1 Jan 06, 2015 09:56 AM
Discussion Flyzone FW-190 Landing Gear Speed propflipper Electric Warbirds 4 Jun 19, 2012 05:50 PM
Discussion We intend to produce ESM FW-190 rear landing gear fimon Scale Fuel Planes 0 Jan 12, 2011 01:16 AM
For Sale New Uni-tract 1/5 scale FW-190 landing gear invertmast Aircraft - General - Miscellaneous (FS/W) 0 Sep 23, 2010 07:15 PM
Discussion Parkzone FW-190 Landing gear or skids itspat Parkflyers 0 May 24, 2006 02:54 PM
