Old Oct 13, 2012, 01:20 AM
Super Matt is offline
Find More Posts by Super Matt
Joined Dec 2011
Originally Posted by sam51401 View Post
FYI, even though Tam at TamJets makes the smaller upgrade trunnion, he has declined to make the larger size due "to slow sales" as per the response to my request.
Not as much demand to turn his EDM loose on such gear.
Super Matt is offline Find More Posts by Super Matt
Reply With Quote  (Disabled)
Old Oct 17, 2012, 12:19 PM
sam51401 is offline
Find More Posts by sam51401
Fly more Foam
sam51401's Avatar
United States, IN, Sellersburg
Joined Jun 2004
here are some pics and rough measurements for a EFlite 60-120 nose gear trunnion that i wish to made from a harder material since the original seems very soft.
sam51401 is offline Find More Posts by sam51401
Old Oct 17, 2012, 12:31 PM
eatond is online now
Find More Posts by eatond
EDF Jet Jam 2015, May 28-31st
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi Sam,
looks like you're missing a measurement for how wide the trunion is.
Dan Eaton
eatond is online now Find More Posts by eatond
Old Oct 17, 2012, 01:31 PM
sam51401 is offline
Fly more Foam
sam51401's Avatar
Joined Jun 2004
opps!!!
.49" thick
Originally Posted by eatond View Post
Hi Sam,
Dan Eaton
Old Oct 17, 2012, 03:16 PM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
I'm a machinist by trade and making the part in a stronger metal will just bring more problems. Retracts are design by plane weight, if you change the design or parts then the actuator might suffer because of a heavier moving parts, etc.
If you want to make a light part and stronger than aluminum you have to use titanium and be aware is going to be pricey (just the bare metal) and to machine it they will charge you a NUT because of its difficulty to machine it. A 1"x1"x6" retails for around 60-75 dollars.
Gamalier is offline Find More Posts by Gamalier
Old Oct 17, 2012, 04:33 PM
sam51401 is offline
Fly more Foam
sam51401's Avatar
Joined Jun 2004
not looking for bullet proof but the material EF uses is indeed pretty soft. A higher grade of aluminum would work, like 6061 or 7075, similair to what Robart uses.
Old Oct 19, 2012, 01:09 AM
Gamalier is offline
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
From the 2 options you stated I will say use 7075 given the higher yield strength (56K psi vs 35K psi) the higher the temper number the stronger the aluminum.
Old Oct 19, 2012, 09:26 PM
sam51401 is offline
Fly more Foam
sam51401's Avatar
Joined Jun 2004
I have D/L a cad program today from Google called Sketchup 8. Really nice and have made a 3D drawing of the trunnion for anyone that may have this program. I cant do DXF since that is in the PRO version only and sales for 495$ i think.
Help! Machinist needed.! epoxyearl Engines 2 Aug 02, 2012 08:37 AM
Sold Craftsman Machinists Micrometer Caliper Tool / NOW FREE micron5 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Apr 22, 2012 05:23 PM
Craftsman Machinists Micrometer Caliper Tool micron5 Non R/C Items (FS/W) 0 Apr 22, 2012 04:44 PM
Sold Craftsman Machinists Micrometer Caliper Tool / NOW FREE micron5 Aircraft - General - Miscellaneous (FS/W) 0 Apr 19, 2012 02:37 PM
Discussion requesting any experiences in requesting repair parts for spektrum radios... bpong Radios 13 Apr 05, 2012 10:55 AM
