Old Oct 10, 2012, 09:39 PM
thndr1mj is offline
Find More Posts by thndr1mj
Yeah, I can CRA$H that!
thndr1mj's Avatar
United States, GA, Dallas
Joined Dec 2010
Help!
70mm EDF motor mount
I have a spare Dynam 70mm EDF motor that I would like to use on some kind of scratch build in the future. I'm looking for suggestions on how I would mount this unit to the plane. I also would like to know if there is a nacelle out there that I can use? If not, any ideas on building a nacelle/ housing out of the pink or blue foam? All ideas are welcome.
thndr1mj is offline Find More Posts by thndr1mj
Old Oct 10, 2012, 11:13 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
You can fabricate some mounting tabs from plywood or carbon fiber, and epoxy them your housing if there are no tabs.
Incorporate some mounting rails into the airframe for the tabs to screw into.
It the airframe is foam and the area where the EDF sits is round and matches the dia of the EDF. You can simply glue it with RTV Silicone adhesive. use just 3 small dabs to glue it. one under the fan and two at the sides. If you need to remove the fan at a later time, you can easily slice the RTV with a hobby knive on the sides, and just pull the fan out. The bottom "Dab" may pull a biy of foam with it.
This gluing method will be plenty strong enough for any 70mm EDF.
The Dynam EDF has mounting tabs...Just make some wood rails for your jet
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Nov 02, 2012, 12:06 AM
garryk is offline
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
Here's a Lacelle that fits over the unit after it's mounted. I wanted ones from like a A-10 Warthog or something like that, but this is the best I could find that was in stock.
http://www.effluxrc.com/Nacelle-WMNAC.htm
Garry K.
garryk is offline Find More Posts by garryk
Sold price derop on edf one motor will fit our larger 5inch and 4.75inch EDF msonny35 Aircraft - Electric - Jets (FS/W) 5 Oct 14, 2012 07:07 PM
Sold 64mm edf w/motor 2-70mm edf's, 70mm edf motor Dave Barrow Aircraft - Electric - Jets (FS/W) 0 Aug 10, 2012 07:58 PM
Sold Misc Lot of 70mm edfs, fans, motors, and 1 64mm edf combo SkylineFlyer Aircraft - Electric - Jets (FS/W) 3 May 07, 2012 07:30 PM
Sold Detrum 70mm EDF/motor combo (Dynamically balanced and mounted)$30 RC_Bob Aircraft - Electric - Jets (FS/W) 4 Oct 22, 2011 08:30 PM
Sold Detrum 70mm EDF/motor combo (Dynamically balanced and mounted) $40 shipped RC_Bob Aircraft - Electric - Jets (FS/W) 1 Oct 05, 2011 03:04 PM
