Old Oct 10, 2012, 09:32 PM
jk6672 is online now
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
e-retracts
I hope I posted this in the correct area, but here goes anyways.
I just picked up my first plane with retractable gear (1400 FMS T-28) but they seem to be finiky, the left side seems to be giving some problems with not closing as flush as the right. I really don't see any adjustments to fix the sag.
Also, any tips on replacing a flap servo without damaging the EPO?
jk6672 is online now Find More Posts by jk6672
Old Oct 11, 2012, 12:05 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I would run the retracts on a separate BEC. as for adjusting how far it closes, remove it, shave, modify, and glue...you might want to make your landing gear mounts stronger by carving out foam and using wood.
flap servo....knife and careful hands.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Oct 11, 2012, 12:35 AM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
http://www.rcgroups.com/forums/showt...ms+1400mm+t+28
I was sorely temped to buy one of these birds until I read this thread. Apparently the only success with those retracts is replacing them (to small and fragile) and eliminating the doors. Lots of conversation on that subject. There are also problems with the airframe distorting due to temp changes. The bottom of the plane is cold the sun heats the top and causes a host of problems.
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Old Oct 11, 2012, 08:56 PM
John
jk6672's Avatar
Joined Sep 2012
Here is a video my touchy retract and I've like to figure it out before it happens when I need to land.
retract stuck (0 min 49 sec)
It seems the left (port side) retract sits lower in the wheel bay and I'm not sure how to correct the issue:
Also I snaped a picture of the retract and out of all three retracts this is the only one that this piece of metal heats up. Any clues?
Old Oct 11, 2012, 09:33 PM
MrMention is offline
Find More Posts by MrMention
Joined Sep 2012
What I've noticed with these retracts is that if the batteries are low, sometimes they all wont come down. So if you are just testing, make sure to use a full pack
MrMention is offline Find More Posts by MrMention
Old Oct 11, 2012, 09:41 PM
John
jk6672's Avatar
Joined Sep 2012
I was using a fully charged 4S 5500mah 60C
Old Oct 11, 2012, 11:10 PM
erikc641 is offline
Find More Posts by erikc641
United States, NM, Las Cruces
Joined Jul 2012
You need to plug in to the rx and see what the current draw is when they are operating. Most of those have overcurrent protection and draw between .1-.3A. Anything over this and that one will not operate. Feel the one that isn't coming and see if it is hot. Oh, just read that one does get hot. It is what I said above. Something in that one is binding, causing it to have to go over the limit for operation, so it does not.
erikc641 is offline Find More Posts by erikc641
Old Oct 11, 2012, 11:12 PM
erikc641 is offline
Joined Jul 2012
Let me ask you this, does it work when you first plug in the battery?
erikc641 is offline
Joined Jul 2012
Are you running a seperate bec?
Old Oct 12, 2012, 12:12 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Regarding the retract that is not retracting all the way...after you've ruled out electrical issues with the retract, and it's still a problem, remove the retract and use washers to shim while re-installing.
Another thing to try is disconnect the servos for the good retract, and see if that changes behavior.
What ESC are you using?
I'd consider picking up an external BEC to power the retracts. You don't want it in parallel with the ESC's BEC, so know what you're doing before taking this advice.
Old Oct 12, 2012, 06:27 AM
John
jk6672's Avatar
Joined Sep 2012
Its all stock, but I have ordered a 75a CC ESC and also a separate CC BEC.
I honestly don't know how to measure electrical draw, but if you can explain to me how I'll run down to Sears and pick up a meter.
Old Oct 12, 2012, 11:12 AM
erikc641 is offline
Joined Jul 2012
[/QUOTE]
This is the one that is over drawing current, triggering the overcurrent protection and not working as a result. Does this one work when first plugged in or after you let it sit for a minute or two?
Old Oct 12, 2012, 11:34 AM
John
jk6672's Avatar
Joined Sep 2012
This is the one that is over drawing current, triggering the overcurrent protection and not working as a result. Does this one work when first plugged in or after you let it sit for a minute or two?[/QUOTE]
I'll check that out today.
Old Oct 12, 2012, 11:39 AM
John
jk6672's Avatar
Joined Sep 2012
Why would I need to do that, and do you have any pictures or diagrams of setting up external BEC?
Are you saying that the CC ESC with switching BEC won't work once installed and I should run seperate BEC?
Old Oct 12, 2012, 11:56 AM
Foambird is offline
Find More Posts by Foambird
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
Something is binding or the retract is faulty. Most likely it is binding somewhere in its travel. I don't think the added BEC is needed. The current draw is limited anyway by the retract circuitry preventing a stall from drawing too much current. I don't recognize the manufacturer of your retract.
I will say my retracts need to be re-aligned after maybe a dozen landings. The struts bend or twist slightly and begin to bind. I have to bend the struts forward and adjust the angle even with good, gentle landings. Upon landing, I always test the retracts to see if they bind upon retract before the next flight.
Foambird is offline Find More Posts by Foambird
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Discussion E-flite 90 and 105 nose retract C206 Flight Accessories 2 Jul 18, 2012 03:49 PM
Sold E-Flite Deuces Wild PWR32's E-Flite Retracts kuczy Aircraft - Electric - Airplanes (FS/W) 9 Jun 18, 2012 01:35 PM
Sold E-flite Retracts 25-46 size AL1EN Aircraft - Electric - Airplanes (FS/W) 2 Mar 30, 2012 03:52 PM
Sold E-flite Retracts 25-46 size AL1EN Aircraft - Electric - Power Systems (FS/W) 2 Mar 05, 2012 03:38 PM
