Old Jan 12, 2013, 03:46 PM
danstrider is offline
Find More Posts by danstrider
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
Got it! Had an errant wire connection; five days for that...
All packaged up, this is a pretty tidy installation. And best yet, it'll fit into my DLG without issue. I still have to install the plastic cover with a pressure port and then add a TEK nozzle. Exciting! Imagine that, a total energy compensated vario for hand-launch. Shh ;-)
A big thanks to Rolf for starting this thread and being so generous with code & schematics!
Dan
danstrider is offline Find More Posts by danstrider
Old Jan 12, 2013, 04:31 PM
Reflex1 is offline
Find More Posts by Reflex1
X-Ikarus
Reflex1's Avatar
United Kingdom, North York
Joined Feb 2003
Fantastic job !
Reflex1 is offline Find More Posts by Reflex1
Old Jan 13, 2013, 01:02 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Dan,
I Like it !
So will this be an Offering ?
birdofplay is online now Find More Posts by birdofplay
Old Jan 14, 2013, 01:12 AM
HughesBrothers is offline
Find More Posts by HughesBrothers
New Zealand, Auckland, Waitakere
Joined Jan 2012
Count me and about 3 others in too!
HughesBrothers is offline Find More Posts by HughesBrothers
Old Jan 19, 2013, 12:46 PM
cmanley_nl is offline
Find More Posts by cmanley_nl
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
I really hope you'll be selling these. It's the only thing I miss in my FrSky gear that's keeping me from stepping over from Multiplex with it's simple audio variometer.
cmanley_nl is offline Find More Posts by cmanley_nl
Old Jan 20, 2013, 09:46 AM
kabelbrand is offline
Find More Posts by kabelbrand
Germany, RP, Niederhausen
Joined Mar 2009
Hi,
Dan
Where can i have a look on your code? Read whole thread, but no link
Regards
Markus
kabelbrand is offline Find More Posts by kabelbrand
Old Jan 20, 2013, 01:34 PM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
Originally Posted by kabelbrand View Post
Hi,
Regards
Markus
It's on the first post, in the "code" box. Cut and paste to download. A.
Banjo5 is offline Find More Posts by Banjo5
Old Jan 21, 2013, 12:19 AM
Joined Mar 2009
I meant the modified code from Dan. I can't find this anywhere
Markus
Old Jan 24, 2013, 10:56 AM
Locutus is offline
Find More Posts by Locutus
Joined Aug 2006
thanks for this great thread!
In case you are using a open9x based transmitter with frsky, i created a version that uses frsky to transmit the data back to earth, where the decoding / display / tone gerneration will take place inside open9x. the data will be transmitted using the frsky sensor hub protocol.
http://9xforums.com/forum/viewtopic.php?f=49&t=2629
rainer.
Locutus is offline Find More Posts by Locutus
Old Jan 26, 2013, 11:49 AM
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
Post #60
I added a total energy probe to my vario to compensate for exchanges in airspeed and altitude. A small 3d printed part forms a cover over the pressure sensor and provides a port for attaching pressure tubing. Since I can make hatches, I'm just gluing in the probe into the hatch for now, which should also allow for easy exchanges of new probes to get the right shape. I'm very excited about this addition!
The project is still in progress and I'm not yet content. After it all works, I'll consider what my next options are. Tell the snow to go away so I can get out flying again, heh.
Dan
Old Jan 27, 2013, 08:17 AM
infractor is offline
Find More Posts by infractor
Joined Nov 2012
Hi Dan good solution, and followed your post, shows how connected the sensor to the tube, and please update the code that you carry, many follow the evolution that leads this post
Greetings from Venezuela
infractor is offline Find More Posts by infractor
Old Jan 29, 2013, 08:32 PM
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
In Rolf's spirit of this open-source thread, at the end of this post is the code I meant to fly tonight. In return, you have to post code updates and changes, feed the internet!!
Speaking of flying, I tried out the total energy probe this evening at the local soccer field. While it's still much under-compensated (I can hear when I push over or pull up), it sounds much much better than before. I experimented with bending the probe forward more or less. Bending less (a straighter tube) was better. Some remaining tests include moving the hole closer to the tip, using a smaller hole, using a larger diameter tube, and otherwise just continuing to play with it. Aluminum tube is cheap and this is definitely progress.
Also posted below is another terrible video with reasonable audio. You can watch the push/pull and hear the vario signal this motion. But compared to last time, not near as bad.
I haven't made any decisions about what to do with these boards because I'm still not happy enough with it. There is still some work to do, especially on ground hardware... I don't have a custom ground board with a shiny volume knob!
Dan
Video (wow yeah, compare to last flight)
Compensated DIY Arduino Vario (1 min 4 sec)
Airborne software:
Code:
// DIY Arduino Variometer, FrSky style
// All code by Rolf R Bakke, Oct 2012
//   http://www.rcgroups.com/forums/showthread.php?t=1749208
// Modifications by Dan Edwards, Nov/Dec 2012
//   Added #defines for the command names for clarity.
//   Tone is no longer generated airborne, instead data is
//     transmitted to the ground via an FrSky telemetry module.
//     A ground station parses the data and makes the tone.
//   Added the 2nd order temperature calibration routine.
//   Added a CRC check appropriate for short messages.
//   Referenced loop timer to current time, quashing a bug.
//_____ INCLUDES
#include <Wire.h>           // for altimeter sensor
#include <SoftwareSerial.h> // for inverted serial
//_____ MACROS
#define LED_PIN 13 // pin for LED
#define ADDR            0x77 // address of MS-5611
#define CMD_RESET       0x1E // ADC reset command
#define CMD_ADC_READ    0x00 // ADC read command
#define CMD_PROM_RD     0xA0 // Prom read command
#define CMD_D1_ADC_256  0x40 // D1 ADC OSR=256
#define CMD_D1_ADC_512  0x42 // D1 ADC OSR=512
#define CMD_D1_ADC_1024 0x44 // D1 ADC OSR=1024
#define CMD_D1_ADC_2048 0x46 // D1 ADC OSR=2056
#define CMD_D1_ADC_4096 0x48 // D1 ADC OSR=4096
#define CMD_D2_ADC_256  0x50 // D2 ADC OSR=256
#define CMD_D2_ADC_512  0x52 // D2 ADC OSR=512
#define CMD_D2_ADC_1024 0x54 // D2 ADC OSR=1024
#define CMD_D2_ADC_2048 0x56 // D2 ADC OSR=2056
#define CMD_D2_ADC_4096 0x58 // D2 ADC OSR=4096
//_____ DEFINITIONS
unsigned int calibData[7];
// 8-bit CRC 0x97. Table computed for from python script found at:
// http://hacromatic.com/blog/2012/08/make-your-serial-protocol-robust-with-8-bit-crc-codes/
static PROGMEM prog_uint8_t crc_table[256] = {
  0x00, 0x2f, 0x5e, 0x71, 0xbc, 0x93, 0xe2, 0xcd, 0x57, 0x78, 0x09, 0x26, 0xeb, 0xc4, 0xb5, 0x9a,
  0xae, 0x81, 0xf0, 0xdf, 0x12, 0x3d, 0x4c, 0x63, 0xf9, 0xd6, 0xa7, 0x88, 0x45, 0x6a, 0x1b, 0x34,
  0x73, 0x5c, 0x2d, 0x02, 0xcf, 0xe0, 0x91, 0xbe, 0x24, 0x0b, 0x7a, 0x55, 0x98, 0xb7, 0xc6, 0xe9,
  0xdd, 0xf2, 0x83, 0xac, 0x61, 0x4e, 0x3f, 0x10, 0x8a, 0xa5, 0xd4, 0xfb, 0x36, 0x19, 0x68, 0x47,
  0xe6, 0xc9, 0xb8, 0x97, 0x5a, 0x75, 0x04, 0x2b, 0xb1, 0x9e, 0xef, 0xc0, 0x0d, 0x22, 0x53, 0x7c,
  0x48, 0x67, 0x16, 0x39, 0xf4, 0xdb, 0xaa, 0x85, 0x1f, 0x30, 0x41, 0x6e, 0xa3, 0x8c, 0xfd, 0xd2,
  0x95, 0xba, 0xcb, 0xe4, 0x29, 0x06, 0x77, 0x58, 0xc2, 0xed, 0x9c, 0xb3, 0x7e, 0x51, 0x20, 0x0f,
  0x3b, 0x14, 0x65, 0x4a, 0x87, 0xa8, 0xd9, 0xf6, 0x6c, 0x43, 0x32, 0x1d, 0xd0, 0xff, 0x8e, 0xa1,
  0xe3, 0xcc, 0xbd, 0x92, 0x5f, 0x70, 0x01, 0x2e, 0xb4, 0x9b, 0xea, 0xc5, 0x08, 0x27, 0x56, 0x79,
  0x4d, 0x62, 0x13, 0x3c, 0xf1, 0xde, 0xaf, 0x80, 0x1a, 0x35, 0x44, 0x6b, 0xa6, 0x89, 0xf8, 0xd7,
  0x90, 0xbf, 0xce, 0xe1, 0x2c, 0x03, 0x72, 0x5d, 0xc7, 0xe8, 0x99, 0xb6, 0x7b, 0x54, 0x25, 0x0a,
  0x3e, 0x11, 0x60, 0x4f, 0x82, 0xad, 0xdc, 0xf3, 0x69, 0x46, 0x37, 0x18, 0xd5, 0xfa, 0x8b, 0xa4,
  0x05, 0x2a, 0x5b, 0x74, 0xb9, 0x96, 0xe7, 0xc8, 0x52, 0x7d, 0x0c, 0x23, 0xee, 0xc1, 0xb0, 0x9f,
  0xab, 0x84, 0xf5, 0xda, 0x17, 0x38, 0x49, 0x66, 0xfc, 0xd3, 0xa2, 0x8d, 0x40, 0x6f, 0x1e, 0x31,
  0x76, 0x59, 0x28, 0x07, 0xca, 0xe5, 0x94, 0xbb, 0x21, 0x0e, 0x7f, 0x50, 0x9d, 0xb2, 0xc3, 0xec,
  0xd8, 0xf7, 0x86, 0xa9, 0x64, 0x4b, 0x3a, 0x15, 0x8f, 0xa0, 0xd1, 0xfe, 0x33, 0x1c, 0x6d, 0x42
// ProMini pin 6 to D8R pin Rx, that's the important one
SoftwareSerial SerialTelem(5,6,true); // rx,tx,inverse
//!  initializations and setup
//!  returns nothing
void setup() {
  // for user to monitor
  Serial.begin(9600);
  Serial.println("FrSky vario airborne unit");
  Serial.println("Dan the man rocks your thermal\n");
  delay(2000);
  // setup led pin
  pinMode(LED_PIN, OUTPUT);
  // setup for FrSky telemetry data transfer
  SerialTelem.begin(9600); // FrSky ONLY speaks 9600 baud
  // setup altimeter sensor
  Wire.begin();
  setupSensor();
//!  main program loop
//!  returns nothing
void loop() {
  static unsigned long timer=0;
  unsigned long time;
  long pressure;
  unsigned int encodedVarioTone;
  // set loop timing
  time = millis();
  if (time >= timer) {
    toggleLED();
    // reference timer to millis() to get desired loop timing
    timer = time + 36; //ms
    // get pressure signal (oversampling is done onboard sensor)
    pressure = getPressure();
    // compute the vario tone and encode it for transmission.
    encodedVarioTone = computeVario(pressure);
    // send encoded user bytes
    sendUserBytes(encodedVarioTone);
//!  computes vario signal
//!  returns int of encoded tone freq to send
unsigned int computeVario(long pressure) {
  static boolean firstTime=true;
  static float toneFreq, toneFreqLowpass, lowpassFast=0.0, lowpassSlow=0.0;
  static int ddsAcc;
  unsigned int encodedToneFreq;
  // initialize filters
  if (firstTime) {
    lowpassFast = pressure;
    lowpassSlow = pressure;
    firstTime = false;
  // compute vario signal
  lowpassFast = lowpassFast + (pressure - lowpassFast) * 0.1;
  lowpassSlow = lowpassSlow + (pressure - lowpassSlow) * 0.05;
  toneFreq = (lowpassSlow - lowpassFast) * 50;
  toneFreqLowpass = toneFreqLowpass + (toneFreq - toneFreqLowpass) * 0.1;
  toneFreq = constrain(toneFreqLowpass, -500, 500);
  // direct digital synthesizer accumulator
  // int wrapping around is the trick here
  // loop timing definitely matters when picking these constants
  ddsAcc += (toneFreq * 100) + 2000;
  // create intermittent beeping tone for ascending
  // raise ToneFreq cutoff if it's beeping while sitting on the table
  if ((ddsAcc > 0) && (toneFreq > 30)) {
    encodedToneFreq = 0xFFFF; // represents a no-tone
    //on decoding end, use: noTone(TONE_PIN);
  else {
    encodedToneFreq = (unsigned int)((toneFreq+510) * 65); // max use of bytes
    //on decoding end, use: tone(TONE_PIN, encodedToneFreq/65);
  return encodedToneFreq;
//!  transmits user bytes
//!  make sure this follows 1200byte/sec FrSky max
//!  returns nothing
void sendUserBytes(unsigned int encodedToneFreq) {
  byte buf[3];
  // build a data word to run CRC on
  buf[0] = highByte(encodedToneFreq); // MSB
  buf[1] = lowByte(encodedToneFreq);  // LSB
  // compute CRC and add to message buffer
  buf[2] = crc_update(0,buf,2);
  // send everything at once
  SerialTelem.write(buf,3);
//!  read pressure from MS-5611 sensor
//!  returns pressure 10 to 1200mbar in 0.01mbar increments
long getPressure() {
  long D1, D2, dT, P, TEMP;
  int64_t OFF, SENS;
  // read digital pressure and temperature data, MS-5611 datasheet Fig 2
  D1 = getData(CMD_D1_ADC_4096); // resolution 0.012 mbar
  D2 = getData(CMD_D2_ADC_256);  // resolution 0.012 C
  // pressure and temperature calculation, MS-5611 datasheet Fig 2
  dT   = D2 - ((long)calibData[5] << 8); // -16776960 to 16777216
  TEMP = 2000 + (((int64_t)dT * (int64_t)calibData[6]) >> 23);  // -4000 to 8500 => -40C to 85C
  OFF  = ((unsigned long)calibData[2] << 16) + (((int64_t)calibData[4] * dT) >> 7);
  SENS = ((unsigned long)calibData[1] << 15) + (((int64_t)calibData[3] * dT) >> 8);
  // 2nd order temp compensation, MS-5611 datasheet Fig 3
  long T2=0.0, tmp;
  int64_t OFF2=0, SENS2=0;
  if (TEMP < 2000) {  // lower than 20C
    T2 = ((int64_t)dT * (int64_t)dT) >> 31;
    tmp = 5*(TEMP-2000)*(TEMP-2000);
    OFF2 = tmp >> 1;
    SENS2 = tmp >> 2;
  if (TEMP < -1500) {  // lower than -15C
    tmp = (TEMP+1500)*(TEMP+1500);
    OFF2 = OFF2 + 7*tmp;
    SENS2 = SENS2 + (11*tmp) >> 1;
  TEMP = TEMP - T2;
  OFF  = OFF  - OFF2;
  SENS = SENS - SENS2;
  // calculate pressure
  P = (((D1 * SENS) >> 21) - OFF) >> 15;
  //Serial.println(P/100); // 10mbar to 1200mbar
  //Serial.println(TEMP/100); // -40C to 85C
  return P;
//!  sends data requests to the sensor
//!  returns raw data
long getData(byte command) {
  long result = 0;
  twiSendCommand(ADDR, command);
  switch (command) {
  case CMD_D1_ADC_256:
  case CMD_D2_ADC_256:
    delayMicroseconds(900);
    break;
  case CMD_D1_ADC_512:
  case CMD_D2_ADC_512:
    delay(3);
    break;
  case CMD_D1_ADC_1024:
  case CMD_D2_ADC_1024:
    delay(4);
    break;
  case CMD_D1_ADC_2048:
  case CMD_D2_ADC_2048:
    delay(6);
    break;
  case CMD_D1_ADC_4096:
  case CMD_D2_ADC_4096:
    delay(10);
    break;
  twiSendCommand(ADDR, CMD_ADC_READ); // command ADC to read
  Wire.requestFrom(ADDR, 3); // ADC read should return 3 bytes, MSB first
  if(Wire.available()!=3) Serial.println("Error: raw data not available");
  for (int i=0; i<=2; i++) {
    result = (result<<8) | Wire.read();
  return result;
//!  reads calibration parameters from sensor
//!  returns nothing
void setupSensor() {
  commandReset();
  for (byte i = 1; i <=6; i++) // get calibration coefficients 1-6
    unsigned int low, high;
    twiSendCommand(ADDR, 0xa0 + i * 2);
    Wire.requestFrom(ADDR, 2);
    if(Wire.available()!=2) Serial.println("Error: calibration data not available");
    high = Wire.read();
    low = Wire.read();
    calibData[i] = high<<8 | low;
    Serial.print("calibration data #");
    Serial.print(i);
    Serial.print(" = ");
    Serial.println( calibData[i] );
//!  resets sensor and waits for it to restart
//!  returns nothing
void commandReset() {
  twiSendCommand(ADDR, CMD_RESET); // reset sensor
  delay(3);  // wait for the reset sequence timing
//!  two-wire interface sends a command to an I2C address
//!  returns nothing
void twiSendCommand(byte address, byte command) {
  Wire.beginTransmission(address);
  if (!Wire.write(command)) Serial.println("Error: write()");
  if (Wire.endTransmission())
    Serial.print("Error when sending command: ");
    Serial.println(command, HEX);
//!  turns LED on and off
//!  returns nothing
void ledOn() {
  digitalWrite(LED_PIN,1);
void ledOff() {
  digitalWrite(LED_PIN,0);
void toggleLED() {
  static boolean ledStatus = true;
  if (ledStatus) {
    ledOff();
    ledStatus = false;
  else {
    ledOn();
    ledStatus = true;
//!  8-bit CRC 0x97 appropriate for short messages with HD-4
//!  http://hacromatic.com/blog/2012/08/make-your-serial-protocol-robust-with-8-bit-crc-codes/
//!  returns resultant crc byte
byte crc_update(byte crc, const unsigned char *data, size_t data_len) {
  unsigned int tbl_idx;
  while (data_len--) {
    tbl_idx = ((crc >> 0) ^ *data) & 0xFF;
    crc = (pgm_read_byte(crc_table+tbl_idx) ^ (crc << 8)) & 0xFF;
    data++;
  return (crc & 0xFF);
Ground software:
Code:
// All code by Dan Edwards, Nov12-Jan13 except where noted.
// Uses hardware inverter for serial
// ProMini pin RX1 to DJT pin Txd
//_____ MACROS
#define TONE_PIN 9
#define LED_PIN 13
// FrSky constants
#define FRAMESIZE 11
#define SYNC  0x7E
#define USER  0xFD
#define STUFF 0x7D
//_____ DEFINITIONS
unsigned int encodedToneFreq=0;
//!  returns nothing
void setup() {
  // initialize serial port
  Serial.begin(9600); // FrSky ONLY speaks 9600 baud
  Serial.println("FrSky vario ground unit");
  delay(2000);
  // setup led pin
//!  returns nothing
void loop() {
  unsigned int varioTone=0;
  // do stuff once we find good user data
  if(getUserData()) {
    toggleLED();
    // decode encoded vario to make a tone freq
    varioTone = encodedToneFreq/65;
    // make beepy noises
    if (encodedToneFreq == 0xFFFF)
      noTone(TONE_PIN);
    else
      tone(TONE_PIN,varioTone);
//!  serial communications state machine, derived from:
//!  http://arduino.cc/forum/index.php?topic=30440.15
//!  vars made static to work if we come back to this function
//!  returns true if found a valid message
boolean getUserData() {
  static int counter=0;
  static boolean stuffFlag=false;
  static byte data[FRAMESIZE];
  // spool thru serial buffer
  while (Serial.available()) {
    byte b = Serial.read();
    //Serial.println(b,HEX);
    if ((b==SYNC) && (counter==FRAMESIZE-1) && (data[0]==SYNC) && (data[1]==USER)) {
      // looks like the end of a valid frame ... so let's parse!
      if (parseUserData(data)) return true;
    else if (b==STUFF) { // byte stuffing!
      stuffFlag = true;
      continue; // this byte only used as a flag, don't save
    else if (b==SYNC) { // start of a new frame. hopefully.
      counter = 0;
      //Serial.println("start");
    // handle byte stuffing
    if (stuffFlag) {
      b ^= 0x20;
      stuffFlag = false;
    // save current byte in the data array
    data[counter++] = b;
  return false; // not successful, boo
//!  this function parses the encodedToneFreq message
//!  returns true if no errors
boolean parseUserData(byte *data) {
  //showUserData(data);
  // error check size
  if (data[2] != 3) { // what is FrSky doing with my data???
    //Serial.println("size err");
    return false;
  // check crc first level
  if (data[6] != crc_update(0,data+4,2)) { // start at 4th position
    //Serial.println("crc err");
    return false;
  // reassemble encodedToneFreq
  encodedToneFreq = data[4]*256 + data[5];
  return true;
//!  this function just shows the user data array
//!  returns nothing
void showUserData(int *data) {
  Serial.print("user data (hex): ");
  for (byte i=0; i<=FRAMESIZE-1; i++) {
    Serial.print(data[i],HEX);
    Serial.print(" ");
  Serial.println();
//!  returns nothing
void ledOn() {
void ledOff() {
void toggleLED() {
  if (ledStatus) {
    ledOff();
    ledStatus = false;
  else {
    ledOn();
    ledStatus = true;
    data++;
Old Jan 29, 2013, 11:37 PM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Very nice work! I am reading this thread with great interest. Good audio vario sound. I need to study total energy probe.
For on board hardware, I could use something like attached. Not so compact like yours but smaller than Pro Mini and low cost at only $6.99, but it is 16MHz Arduino with I2C and TX/RX connectors.For other project, I connected 10DOF sensor and loaded MultiWii code fine.
I have been flying FrSky based vario for some time. Sensors and hardware have become really affordable.
Satoru
ssatoru is offline Find More Posts by ssatoru
Old Feb 01, 2013, 06:06 AM
MarLi is offline
Find More Posts by MarLi
United States, IN
Joined Jun 2011
Greetings,
anyone tried this vario approach on Hitec Aurora ?
cheers,
MarLi
MarLi is offline Find More Posts by MarLi
Old Feb 14, 2013, 09:04 PM
Phatburner is offline
Find More Posts by Phatburner
Joined Aug 2012
A friend helped me with the layout and a board house did the manufacturing. I populated the boards.
That is the FrSky D8R with the right angle telemetry headers removed.
Dan
Great work Dan and thanks for sharing your progress regardless of your answer to my query below.
Dan would you be willing to share your layout files or at least the board house name and run info so others could duplicate these boards? Over on the 9x forums we are doing almost identical (the firmware is different) and using the board in the tx to generate the audio. We may be able to flash our own firmware on your board as the openxvario is also based on the pro mini and the MS5611.
Joe
Phatburner is offline Find More Posts by Phatburner
Mini-HowTo DIY arduino twin video receiver diversity controller. Updates allways in post #1 Richard_s FPV Equipment 145 Mar 01, 2016 02:39 AM
Idea DIY Video Diversity with Arduino - Please Review! MayMayDay FPV Talk 3 Aug 22, 2015 09:27 AM
Discussion Arduino based IR tag module for combat sh4nce Combat 38 Feb 18, 2015 04:02 PM
New Product DIY OpenPilot based FlightControl (F4) lilvinz Multirotor Electronics 271 Jan 04, 2015 05:58 AM
Help! Engineering student and first arduino based build? cad2blender UAV - Unmanned Aerial Vehicles 3 May 17, 2012 07:59 AM
