Old Dec 08, 2012, 11:15 AM
Reflex1 is offline
Find More Posts by Reflex1
X-Ikarus
Reflex1's Avatar
United Kingdom, North York
Joined Feb 2003
Well done !
Reflex1 is offline Find More Posts by Reflex1
Old Dec 08, 2012, 01:04 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Agreed ^ would be totally happy with that.
A10FLYR is offline Find More Posts by A10FLYR
Old Dec 08, 2012, 05:23 PM
danstrider is online now
Find More Posts by danstrider
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
Working to fly this tomorrow. Pretty small! That's the stock case removed in the pictures. Pretty sure that a custom board run can literally fit inside the old case. 8-D
Anyone else flown a Rolf vario?
Dan
danstrider is online now Find More Posts by danstrider
Old Dec 08, 2012, 05:45 PM
Reflex1 is offline
X-Ikarus
Reflex1's Avatar
Joined Feb 2003
I've had 5 or 6 flights
but still poor weather here.
No real thermals to play in yet
Old Dec 09, 2012, 03:43 PM
jcabetas is offline
Find More Posts by jcabetas
Joined Oct 2012
Very good work!! I did a similar job but with the bmp085 sensor. The sensor has a inherent noise of +-1m, so the use of it for the variometer was challenging. Anyway it was very useful to locate and center thermals, until I installed an eagletree OSD with altitude sensor.
With this impressive work and seeing how well the sensor behaves, I will build another one right now and send the sound trough the video emitter of the FPV.
Thanks for sharing it!!
jcabetas is offline Find More Posts by jcabetas
Old Dec 11, 2012, 06:50 PM
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
Small enough?? :-)
Old Dec 12, 2012, 04:28 AM
Reflex1 is offline
X-Ikarus
Reflex1's Avatar
Joined Feb 2003
Dan
Dan. have you flown your FrSky version, how did it go ?
Old Dec 12, 2012, 10:37 AM
chiloschista is offline
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
Hi,
sorry for the OT, but I'm stuck.
Could someone point me toward a datasheet and connections layout for this tx please ?
What's the open blob meant for ? Maybe frequency choice ?
There is a similar free blob, seems for a capacitor, in this receiver.
What's meant for ?
Ric
chiloschista is offline Find More Posts by chiloschista
Old Dec 12, 2012, 11:39 AM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Well .... if they dont supply a data sheet .......
srnet is offline Find More Posts by srnet
Old Dec 12, 2012, 04:33 PM
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
Haven't been able to yet (bad weather last weekend and it's practically dark after work), but I should have an opportunity on Friday or Saturday. Will post some kind of report.
Dan
Old Dec 12, 2012, 08:38 PM
376782 is offline
Find More Posts by 376782
Near Kingston, Ontario, Canada
Joined Dec 2004
Intermittent Sound output.
Hi Everyone;
Just built up the Arduino nano and MS5611 sensor and amazed at how sensitive it is to change in height. However the audio output seems to breakup randomly which is somewhat annoying but don't see the data drop out at the input to the Arduino.. I put a scope on the output signal at D2 and for sure it does shut down randomly. I played back the video demo and noticed that it seems to do the same thing so was wondering if there is some program changes that could be made to eliminate this. It would be nice if the audio output would stay constant and only change frequency with change in altitude. Any ideas would be appreciated.
Dave
376782 is offline Find More Posts by 376782
Old Dec 12, 2012, 08:52 PM
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
Looking forward to hearing how your version works!
Question for you: when you move the vario down and get the non-intermittent tone, is that what you're after for up as well? Change if (toneFreq < 0 || ddsAcc > 0) to if (toneFreq < 0) and the intermittent beeping will go away.
Traditionally, I think the intermittent sound is used to provide a clue where the zero-point is. When the tone is constant, you're sinking. When the tone begins to make intermittent beeps, you're rising. Without that, you have to memorize the zero tone. The beeping gets shorter when you start rising faster as well as the tone changing frequency. This may not be as clear in the lab.
Dan
Old Dec 13, 2012, 09:25 AM
376782 is offline
Joined Dec 2004
Dan
Hi Dan. Thanks for the quick reply. At first I had expected to hear a steady tone with fixed height and just get an increase/decrease in frequency with changing height but I guess that is not the case even with a real variometer. That would be my preference but may work on this later. My programing skills are pretty limited so will probably have to have a friend give me a hand. For some reason software and me don't see eye to eye. I am more of a hardware type. It will be awhile before I get to try this out as winter has set in here and I am a fair weather flier. I have yet to try out the transmitter/receiver combination but will do so in the near future. I am going to try out the cheap Chinese 433/315 units firsts to see if they will be adequate and will let you know how they work out. I will also try out the micro Arduino units as well to try and reduce overall size.
Thanks again.
Dave
Old Dec 13, 2012, 01:18 PM
Reflex1 is offline
X-Ikarus
Reflex1's Avatar
Joined Feb 2003
You only have to memorize One tone.
Zero Sink . this will give a constant tone without interruption at a particular frequency (remember Zero Sink is actually Lift , as your no longer loosing height)
A Lower constant tone than Zero Sink means your loosing height.
A higher "interrupted tone" indicates Lift and height gain.
the faster it's interrupted the Higher the Lift.
It seems complicated at first but a little practice
and it will be second nature
That's the basics, however things are never quite that simple ....
With a Glider, Height can be converted to Speed, and Speed can be converted to Height
Elevator stick input will vary airspeed and give False Vario readings
e.g. Down Elevator increases Speed & Sink rate
so the Vario will respond appropriately with a Sink indication.
On the other hand Up Elevator on a Fast flying Glider kept above Stall speed
and the Vario will indicate Lift as the Glider converts Speed to Height.
On a simple Vario this is normal and the Pilot learns quickly
the effects of Stick inputs on Vario response.
A more sophisticated Vario also reads the Airspeed
and compensates Vario output as airspeed is varied
this is know as a Total Energy Vario. or T.E. Vario.
that I'll leave to someone else to explain,as I feel it best to learn to use a normal Vario first
before getting involved in the TE systems.
Old Dec 17, 2012, 08:23 AM
pprioverde is offline
Find More Posts by pprioverde
M Griffith
Ecuador, Tungurahua
Joined Jun 2012
Originally Posted by kapteinkuk View Post
Direct digital synthesizer Accumulator. It is used for the amplitude modulation of the vario sound and gives the intermittent sound when ascending.
http://en.wikipedia.org/wiki/Direct_digital_synthesizer
very clever, Thanks.
pprioverde is offline Find More Posts by pprioverde
Mini-HowTo DIY arduino twin video receiver diversity controller. Updates allways in post #1 Richard_s FPV Equipment 145 Mar 01, 2016 02:39 AM
Idea DIY Video Diversity with Arduino - Please Review! MayMayDay FPV Talk 3 Aug 22, 2015 09:27 AM
Discussion Arduino based IR tag module for combat sh4nce Combat 38 Feb 18, 2015 04:02 PM
New Product DIY OpenPilot based FlightControl (F4) lilvinz Multirotor Electronics 271 Jan 04, 2015 05:58 AM
Help! Engineering student and first arduino based build? cad2blender UAV - Unmanned Aerial Vehicles 3 May 17, 2012 07:59 AM
