Old Oct 25, 2012, 03:30 AM
Reflex1 is offline
Find More Posts by Reflex1
X-Ikarus
Reflex1's Avatar
United Kingdom, North York
Joined Feb 2003
Originally Posted by kapteinkuk View Post
Direct digital synthesizer Accumulator. It is used for the amplitude modulation of the vario sound and gives the intermittent sound when ascending.
http://en.wikipedia.org/wiki/Direct_digital_synthesizer
Great project
I have built the "front End" running an Arduino 168, and via an old PC amplified
speaker unit for testing. It works Very well
Is it possible to Mute the "Down Tone" and just
leave the "Climb" indication ?
or even better to have this Switchable via
a small PCB switch on the Arduino ?
Reflex1 is offline Find More Posts by Reflex1
Old Oct 26, 2012, 06:58 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Only sound in positive climb*:
Code:
  if (toneFreq > 0 && ddsAcc > 0)
    tone(2, toneFreq + 510);
  else
    noTone(2);
Original, or only sound in positive climb, switchable*:
Code:
  if ((toneFreq < 0 && digitalRead(switchPin)) || (toneFreq > 0 && ddsAcc > 0))
  else
    noTone(2);
*code is not tested in real hardware, only run through my "Brain-reality-simulator-2000-PRO Xtreme edition"
kapteinkuk is offline Find More Posts by kapteinkuk
Old Oct 26, 2012, 07:16 AM
Reflex1 is offline
X-Ikarus
Reflex1's Avatar
Joined Feb 2003
WoW. thanks Rolf
I'll try it later today
Software is not my strong point ...
I assume "digitalRead(switchPin))"
is which ever Pin on the Arduino is assigned
to this function ?
But. no matter, Indication on Climb only
is a great help
Old Oct 26, 2012, 08:33 AM
Reflex1 is offline
X-Ikarus
Reflex1's Avatar
Joined Feb 2003
Sound on positive climb only,
works fine see code below (copy & Paste to use) Thanks Rolf !
Yet to test the "switched" code
// All code by Rolf R Bakke, Oct 2012
#include <Wire.h>
const byte led = 13;
unsigned int calibrationData[7];
unsigned long time = 0;
float toneFreq, toneFreqLowpass, pressure, lowpassFast, lowpassSlow ;
int ddsAcc;
void setup()
Wire.begin();
Serial.begin(115200);
setupSensor();
pressure = getPressure();
lowpassFast = lowpassSlow = pressure;
void loop()
lowpassFast = lowpassFast + (pressure - lowpassFast) * 0.1;
lowpassSlow = lowpassSlow + (pressure - lowpassSlow) * 0.05;
toneFreq = (lowpassSlow - lowpassFast) * 50;
toneFreqLowpass = toneFreqLowpass + (toneFreq - toneFreqLowpass) * 0.1;
toneFreq = constrain(toneFreqLowpass, -500, 500);
ddsAcc += toneFreq * 100 + 2000;
else
noTone(2);
ledOff();
while (millis() < time); //loop frequency timer
time += 20;
ledOn();
long getPressure()
long D1, D2, dT, P;
float TEMP;
int64_t OFF, SENS;
D1 = getData(0x48, 10);
D2 = getData(0x50, 1);
dT = D2 - ((long)calibrationData[5] << 8);
TEMP = (2000 + (((int64_t)dT * (int64_t)calibrationData[6]) >> 23)) / (float)100;
OFF = ((unsigned long)calibrationData[2] << 16) + (((int64_t)calibrationData[4] * dT) >> 7);
SENS = ((unsigned long)calibrationData[1] << 15) + (((int64_t)calibrationData[3] * dT) >> 8);
P = (((D1 * SENS) >> 21) - OFF) >> 15;
//Serial.println(TEMP);
//Serial.println(P);
return P;
long getData(byte command, byte del)
long result = 0;
twiSendCommand(0x77, command);
delay(del);
twiSendCommand(0x77, 0x00);
Wire.requestFrom(0x77, 3);
if(Wire.available()!=3) Serial.println("Error: raw data not available");
for (int i = 0; i <= 2; i++)
result = (result<<8) | Wire.read();
return result;
void setupSensor()
twiSendCommand(0x77, 0x1e);
delay(100);
for (byte i = 1; i <=6; i++)
unsigned int low, high;
twiSendCommand(0x77, 0xa0 + i * 2);
Wire.requestFrom(0x77, 2);
if(Wire.available()!=2) Serial.println("Error: calibration data not available");
high = Wire.read();
low = Wire.read();
calibrationData[i] = high<<8 | low;
Serial.print("calibration data #");
Serial.print(i);
Serial.print(" = ");
Serial.println( calibrationData[i] );
void twiSendCommand(byte address, byte command)
Wire.beginTransmission(address);
if (!Wire.write(command)) Serial.println("Error: write()");
if (Wire.endTransmission())
Serial.print("Error when sending command: ");
Serial.println(command, HEX);
void ledOn()
digitalWrite(led,1);
void ledOff()
digitalWrite(led,0);
Old Oct 27, 2012, 06:02 PM
Reflex1 is offline
X-Ikarus
Reflex1's Avatar
Joined Feb 2003
Thanks KK , I have tested the "switched" Down Tone
I added a movable link to the Arduino ,enabled the "Pull Up" on pin 9
and it's easily to turn the Tone On or Off now.
digitalWrite(9, HIGH);
if ((toneFreq < 0 && digitalRead( 9 )) || (toneFreq > 0 && ddsAcc > 0))
else
noTone(2);
Old Oct 28, 2012, 02:57 PM
thnilsen is offline
Find More Posts by thnilsen
thnilsen's Avatar
Norway, Hordaland, Os
Joined Nov 2004
Rolf,
Very interesting project this. Would it not be possible to hook up a simple accelerometer to provide a "poor mans TEC"? by looking at the attitude of the X axis (following the length of the fuselage). If the X is more than let say 5 or 10 degrees down or up you could assume it would be because of stick input rather than lift. I know it wouldn't be exact, but would it not give a somewhat better control of lift when stick input is interfering?
- Thomas
thnilsen is offline Find More Posts by thnilsen
Old Oct 28, 2012, 03:36 PM
chiloschista is offline
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
Originally Posted by thnilsen View Post
Rolf,
- Thomas
Thomas, sorry if I chime in, but I don't think such a simple implementation could be useful. There are too many variable which could play against. When the plane is banked while spiralling how is pitch working ? There should be a 3 axis sensor for sure etc.
But I chime in mainly because in a project where I was involved there is airspeed and 3 axis wind speed estimated by accelerometers. In this project, navigation takes account of TEC this way to manage speed and height. I guess then that with accelerometers and a bit (a great amount) of coding and testing it should be possible to have TEC estimated. But at this point I wonder which advantage would it be : not having a pitot tube around, other ?
In this video you can have an idea of "estimated" TEC working, watching at values on the right you have from top estimated vertical speed, height, Z axis estimated wind speed and potential height.
On the left you have estimated air speed and GPS speed.
Best regards,
Ric
chiloschista is offline Find More Posts by chiloschista
Old Oct 28, 2012, 05:34 PM
Taurus Flyer is online now
Find More Posts by Taurus Flyer
The Netherlands, OV, Almelo
Joined Nov 2010
For who is interested, "Old School" TE compensation with use of a venturi,.
In my video of post 28 ( http://www.rcgroups.com/forums/showp...2&postcount=28 ) time 0:46 and 0:51 you see the effect of TE compensation realised by the TE venturi, resulting in a positive signal of tone pulses at constant (flight) level on moments of acceleration of airspeed.
The accelertion is simulated by blowing in the ventury.
TF
Taurus Flyer is online now Find More Posts by Taurus Flyer
Reply With Quote  (Disabled)
Old Oct 29, 2012, 05:15 PM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
Your input is most certainly appreciated Ric.
I'm no maths or electronic wiz so I can't really verify if it is at all possible to make a light TEC version without knowing speed. However, with a 3 axis accelerometer it should be possible to tell if the nose is pointing up or down above a preset threshold. Calculating this tentative X axis should be possible to do even if the plane is banking/spiraling etc. The body lengthwise on a glider in a thermal would stay pretty much at normal flight angle, would it not since the entire plane is lifted in a thermal? At least that's what I remember when doing full size gliding - but it has been a few years now so my memory might be a bit off.
I guess the pros of going with an accelerometer and not having to hook the unit up to a venturi would allow the unit to still be pretty small without too many external connectors. Makes it easy to move between models etc. But as you already know, such a solution would be less accurate compared to one that adds speed into the equation. The cost of a 3 axis accelerometer is also very low these days which is another pros.
But as I said I'm no maths or electronic wiz, so there might be very good reason that this might not work.
- Thomas
Old Oct 29, 2012, 06:09 PM
Switzerland
Joined Feb 2008
Thomas,
I disagree on one point of your post. Estimated airspeed and 3 axis wind speed are very accurate in our project. This is an implementation of Bill Premerlani, a scientist of General Electric, also the founder and main guru of the project.
At this moment I can't find a link, but will come if I can recover some papers.
Best regards,
Ric
Old Oct 29, 2012, 08:47 PM
Joined Nov 2010
About the total energy variometer!
A total energy variometer (TE compensated vario) does need the exact input of altitude (potential energy) and speed (kinetic energy) of local circumstances of the air the plane is flying in.
Both measurement have to be real time and dynamic balanced!
There are several proven methods for that.
The speed is as important as the altitude and the calibration of both has to be done over the whole speedrange of the glider. For calibration there are special instruments.
Signalprocessing of speed / altitude variations can be done pneumatic, electronic or software. Easest method of course is the TE tube (google for that!) but I prefer one of the other methods so I can adjust the TE compension, also over- and undercomp., or switch it off.
Keep in mind there are several different vario's too, the TE compensated isn't the only one but most basic. For more complicated vario's the calibrated airspeed measurement is needed. For the normal vario the TE tube can be the best choice and can be interesting for the thread starter, Kapteinkuk.
The photograph does show the pitot and static tube (Prandtl-Rohr) of one of my gliders. The static tube (connection) is used for altitude (variations) and pitot connection for speed measurement. The vario is a (relative) netto variometer with pneumatic calculation and hardware electronic signalprocessing, so no Arduino.
Taurus Flyer.
Old Nov 19, 2012, 05:42 PM
stilp is offline
Find More Posts by stilp
Australia, QLD, Logan
Joined Aug 2011
I'm keen on getting one of these and hooking it up to my fpv cularis. If anyone here has a spare or would like to sell me one, please pm me. Just to add another twist to the equation: my hang glider vario makes no sound while its elevation is constant. This would be my ideal as I only need to be prompted if lift/sink conditions exist ( Normal glide ratio would be silent). Also, the sink sound is important in my opinion: Commonly, speed is increased in proportion to sink.
stilp is offline Find More Posts by stilp
Old Nov 20, 2012, 10:23 AM
danstrider is offline
Find More Posts by danstrider
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
building my own...
Thanks kapteinkuk for posting code! I ordered stuff to make my own :-)
The MS-5611 is a pretty cool little package. Shame it doesn't have a nipple for attaching tubing. I had some thoughts of a little plastic cap that could be glued around/over the sensor to provide a tubing connection point, which would also allow using a TEK nozzle to get airspeed compensation (http://www.rcgroups.com/forums/showt...0#post17912800).
If you haven't seen the inexpensive FrSky telemetry equipment, they include an RS232 downlink at 4800 baud that looks perfect for removing the transmitter hardware from the airborne unit. Here is a picture of the receiver and side plug for RS232 at TTL: http://www.rcgroups.com/forums/showp...3&postcount=16 RENATOA was really involved in one of the FrSky threads; maybe he'd be willing to chip in?
Reading through the MS-5611 datasheet (http://www.meas-spec.com/downloads/MS5611-01BA01.pdf), I see there is a 2nd order temperature compensation for improved accuracy below 20C. Considering winter is coming and to have something to do while parts ship, I thought it useful to add this. This code has not been tested on hardware:
Code:
// original code by Rolf R Bakke, Oct 2012
// modifications by danstrider, 20 Nov 2012
long getPressure()
  long D1, D2, dT, P;
  float TEMP;
  int64_t OFF, SENS;
  D1 = getData(0x48, 10); // resolution 0.012mbar
  D2 = getData(0x50, 1); // resolution 0.012C
  TEMP = (2000 + (((int64_t)dT * (int64_t)calibrationData[6]) >> 23));  // -4000 to 8500 = -40C to 85C
  // 2nd order temp compensation, MS-5611 datasheet Fig 3
  float T2=0.0;
  int64_t OFF2=0, SENS2=0, tmp;
  if (TEMP < 2000) // lower than 20C
    T2 = (float)((dT*dT) >> 31);
    tmp = TEMP-2000;
    tmp = 5*tmp*tmp;
    OFF2 = tmp >> 1;
    SENS2 = tmp >> 2;
  if (TEMP<-1500) // lower than -15C
    tmp = TEMP+1500;
    tmp = tmp*tmp;
    OFF2 = OFF2 + 7*tmp;
    SENS2 = SENS2 + (11*tmp) >> 1;
  TEMP = TEMP - T2;
  OFF = OFF - OFF2;
  SENS = SENS - SENS2;
  // calculate pressure and temperature
  P = (((D1 * SENS) >> 21) - OFF) >> 15; // 10 to 1200mbar with 0.01mbar resolution
  TEMP = TEMP / (float)100;  // -40 to 85C
  return P;
Will post back when I have something to show for myself.
Dan
danstrider is offline Find More Posts by danstrider
Old Nov 20, 2012, 06:30 PM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
I have been thinking the same with using the FrSky telemetry units. However, I believe the LDC panel provided by FrSky only provides 3 tones all together, so you would be limited on indicating levels of lift/sink. Please correct me if I'm wrong as I'm having a hard time not pressing the BUY button on one of those DIY FrSky units...
- Thomas
Old Nov 20, 2012, 06:35 PM
Quad Whisperer
Joined Jul 2008
My vario only sends sound, so I doubt it will work through that FrSky down link, unless the link is hardware at lowest level (Mark/Space).
The vario only uses fast relative changes in pressure as input. So an absolute accuracy is not necessary.
Code:
long getPressure()
  long D1, D2, dT, P;
  float TEMP;
  int64_t OFF, SENS;
  float T2=0.0;
    tmp = TEMP-2000;
    tmp = 5*tmp*tmp;
    OFF2 = tmp >> 1;
    SENS2 = tmp >> 2;
    tmp = TEMP+1500;
    tmp = tmp*tmp;
  TEMP = TEMP - T2;
  OFF = OFF - OFF2;
  return P;
Dan
Mini-HowTo DIY arduino twin video receiver diversity controller. Updates allways in post #1 Richard_s FPV Equipment 145 Mar 01, 2016 02:39 AM
Idea DIY Video Diversity with Arduino - Please Review! MayMayDay FPV Talk 3 Aug 22, 2015 09:27 AM
Discussion Arduino based IR tag module for combat sh4nce Combat 38 Feb 18, 2015 04:02 PM
New Product DIY OpenPilot based FlightControl (F4) lilvinz Multirotor Electronics 271 Jan 04, 2015 05:58 AM
Help! Engineering student and first arduino based build? cad2blender UAV - Unmanned Aerial Vehicles 3 May 17, 2012 07:59 AM
